Question about Philips SA5125/37 MP3 Player
Mp3 player i sync my cdmusic thaat has alyssa lies on it and my mp3 player just says file fromat not supported. but i have enough room to have it ,but it won't let me play the song at all on it. my mp3 playeer is a phillips GoGear 2GB SA6025.
  • Anonymous Feb 26, 2009
    the iq sound player i got as a gift, i selected a list of videos i wanted to load and when i plugged my player to my pc it downloaded every song and video it could fit, but i can't find them on my player.
When I switch on my MP3 player I can only play the last two albums I loaded. ...yet when I go onto my computer and click Library I have a list of all the others I have added,...yet I cannot play any of them ??
Please help
Posted on Mar 15, 2008
  • 476 Answers
Make sure the Philips Device Manager has been installed, and run it.
Press and hold the [VOL+] button on the player whilst connecting to the PC. Device Manager will go into repair mode. Follow the on-screen prompts. This will format the player, removing all files, and re-flash the firmware.
When finished you will need to re-start the player once, and a second time when it shuts down.
Open Windows Media Player. Go to the Tools menu and select options. (You may need to right click the top bar to access the Tools menu.)
Click the Rip Music tab. Select the file type you wish to use (SA6025 supports .MP3 and .WMA)
Make sure the "Copy protect music" box is not ticked.
Click apply then ok to return to the main program.
Insert your CD, and select the tracks you wish to transfer and click "Rip".
Your CD will be converted and saved in the My Music folder.
When it has finished transfer the files to your player using the Sync option.
Posted on Mar 12, 2008
SOURCE:
Sakar 50009: When I plug in my daughter's music player, I see that my itunes songs are there, but they won't play...When I searched for this, I saw that they are not MP3 files. How do I change my...
Download a current version of windows media player on your pc and open it. when it opens it will ask if you want to search for music on your pc - choose yes or ok. The media player will locate any music files on your pc and bring them into it so you can see them. use the "sync" function to convert the file formats to mp3, then connect your player to your pc using the cable and transfer the music to it. the sync function should convert the files to mp3 format first and then when they are converted - it should sync or transfer them to a useable version on your mp3 player.. Be patient, the sync feature is sometimes slow.
Jul 17, 2011 | Sakar MP3 Player
I have an AA file that I downloaded from audible.com, it's a book. When I try to sync it to the Sony Walkman from Windows Media Play, I get an error. The error says "Windows Media Player cannot sync...
The "AA" file type is not supported in the NWZ MP3 players. However, you are still able to place audiobooks onto your player if you convert the file to one of the supported file audio formats: MP3. WMA, AAC-LC, and PCM. Remember that there are several iterations of MP3, such as variable bit rate and frequency range and the player does not play some of them.
What I do is that I pull the file into Audacity and convert it there. Another option is that if you can burn the audiobook onto a CD, you can then rip to WMP and then sync it to your player. That is how I get my language audiobooks onto my player. The last option, which I have never tried, is to get it into ITunes, then sync it to your player that way. ITunes will automatically convert the file before syncing it onto the player.
Hope that helps.
Jan 07, 2011 | Sony Walkman NWZ-E344 Digital Media Player
File Format not supported
You have to be sure that the files are all mp3 files, or wma (windows media audio). Check the rip settings in Windows Media Player. If you rip CD's in a format other than mp3 or wma you will not be able to sync the files to your player. I would suggest sticking with mp3 - as mp3 files are compatible with any player, including ipods.
Apr 06, 2009 | Philips GoGear SA3245/37 Digital Media...
File format not supported
You have to convert all the music from windows media player to MP3 file format bfore you sync to the player. you can search mp3 converter in google.com
may this help,
melnavz
Feb 13, 2009 | Philips GoGear SA178 MP3 Player
MMP8575
you should upgrade the player with firmware but first erase the memory by going to the settings and click on fromat it will then click play and it will erase.
Aug 09, 2008 | Memorex MMP8565 MP3 Player
File transfer Problem
Ok, I figured out a solution on my own.
Remarkably simple - all I did was reformat the player again and then reinstall windows media player.
Although in my travels I came across an article which may help users with a similar problem: http://support.microsoft.com/kb/911091/en-us#appliesto
Apr 20, 2008 | Toshiba gigabeat S MP3 Player
Mp3 player severe help
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Mar 09, 2008 | iLO MP3 Player
Not enough room for music database please free 4 mb
The device needs at least 4MB of free space.
You need to keep deleting files until there is 4MB less than the total capacity of the device.
Its not syncing because the device is too full.
If removing the 4MB doesnt work. Try formatting the device thru My Computer>Device Name (m200)>Right Click and select FORMAT.
Best of Luck.
Please RATE my solution BELOW.
Nov 20, 2007 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Can't put new music on player
Hi Raxter. As long as you can save files to the player (seems like pictures and video work just fine, right?), then the player is not experiencing any corruption or firmware issues. Perhaps the issue lies with the songs you're synchronizing to the player. There are several reasons why you would encounter errors when synchronizing songs to the player: (1) File type is not supported by the player -- MP3 (with a bit rate of 128 Kbps) and WMA files (with a bit rate of 64 Kbps) are the only supported music file type. MP3 music normally converted via iTunes is not guaranteed to work on this player. (2) Windows Media Player 10 is the only tested Microsoft player version to work on this player (trust me, I've had my bouts with other Windows Media Player versions lol.) Version 11 works, but I have had issues with the player experiencing errors when syncing songs. (3) If the songs are licensed or subscription, it's probably best that you use the subscription provider's media software to "synchronize" the songs into the player (like Rhapsody or Napster player. Music Match often causes the player to "restart" -- I have no idea why, better call them). Some music providers are unable to actually support the player (or recognize it for that matter). It would be best if you contacted the subscription provider to give you instructions on how to synchronize the songs from their website. If your songs are non-licensed songs (like songs from ripped audio CDs, Limewire, etc), then it's best to switch the player's mode to MSC and transfer the songs by simply "Dragging and Dropping" or "Copy/pasting" the songs to your player. To switch your player's mode to MSC, navigate the Menu as follows: Menu >> Settings >> USB Mode I hope that would resolve the problem you're encountering with your player. There is another way to reset your player, but I'm hoping these options would actually let you transfer files successfully. Let me know the results.
May 16, 2007 | SanDisk Sansa e250 MP3 Player
Can't sync file
Try formatting your unit and reinstall your playlist it will work.
Jun 21, 2006 | SanDisk Sansa m250 MP3 Player
Philips SA5125/37 MP3 Player Logo
46 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
