Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool Washes and rinses...but does not spin dry or drain
    Novelist:
  • 131 Answers
If the motor makes no noise in the spin cycle only, it sounds like you need a lid switch.
Unplug the machine. Remove the end caps on both sides of the console by putting a flat screwdriver in the top of the end caps from the back and gently prying up. Remove the two Phillips screws holding the corners of the console down. Lift the console and gently fold back. Unplug the lid switch. That's the 3-wire quick disconnect below the timer. (If you have a high price model, you'll have three hoses under a plastic cover on the left. disconnect those hoses before going further.)
Using a flat screwdriver remove the gold clips holding the cabinet to the back. Place the blade of the screwdriver in the indentation closest to you and tilt the handle of the screwdriver back.
Open the lid. Lift and tilt the entire cabinet toward you. Look down through the hole to the front bottom edge of the cabinet. It is hooked under the front edge of the washer frame. Remove the cabinet and place it in a position you can work under it.
The lid switch is held in lpace with two Phillips screws on the right edge of the hole. There is also a 5/16 in ***** holding the ground wire to the cabinet. Install the new switch using all the clips and screws that were holding the old switch in place.
Pick up the cabinet, hook it under the front of the frame, and tilt it back into place. Push the sides of the cabinet in as you are tilting it back to make sure the hooks in the frame (back, sides) line up with the cabinet. You can know it's in place when the edges of the cabinet line up evenly with the edges of the back.
Re-install the gold clips. Hook them into the back panel, put them into the slots in the cabinet, and push down until they snap into place. Re-connect the lid switch. Lower the console. Replace the screws. Replace the end caps - bottom first, then snap them in at the top.
Happy washing!
Posted on Mar 11, 2008
Machine washes but won't spin or rinse
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 18, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Not spin drying the clothes
check to make sure the pump is not restricted or drain hose kinked.
May 20, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
My washer will not rinse.
If it spins and drains and washes but will not rinse then you probable need a new timer but check the lid switch first.
May 12, 2009 | Washing Machines
The washer will not spin
my washer will not finish spin and reins cycles please HELP ME
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
41 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
