Question about JVC HD-56FN97 56" Television
AUDIO I can not receive any audio thru mu surrond sound system. I have an hdmi cable from cable box to TV. I have tried everyting I can think of to get audio thru my surrond system but have had zero luck.Any suggestions..
  • glen24km Dec 03, 2008
    Same thing, no sound to surround sound like I had before. But I just bought a sony ps3 and a logitech universal remote and did the hdmi from the cable box. Don't know if it's related or not.
  • George Robinson Aug 05, 2012
    usually a jack plug into the earphone socket and then to surrond sound works fine
This TV ONLY transfer audio OUT to a ANALOG SYSTEM THRU AND ANALOG SIGNAL. That is, TV will play sound fine in your surround system but any digital (HDMI) wont sound.
Posted on Feb 01, 2010
No audio when watching HDTV and the home theatre receiver is set to cab/sat. HDMI cable is run from the receiver to the TV. Cable is run from the cable box to the receiver. Tried using "y" audio...
If your TV has HDMI in and digital optical out, run your HDMI cable via HDMI out on box to, HDMI in on TV then, run digital optical ouyt from TV to digital optical in on reciever. Your reciever has video pass through but, not the best option. Video components should run to TV then out to reciever. If you do not have digital optical out on TV, you may be able to use RCA.
Jun 24, 2011 | Insignia Audio Players & Recorders
I have the phillips system. i didnt get a manual with mine. so im hooking it up with out one. ok i have a cable running off of my hdmi cable and ps3 on hdmi. i took my ps3 off and pluged the blueray up to...
I don't recommend doing things without a manual when one is available...
http://www.p4c.philips.com/files/h/hts5580w_f7/hts5580w_f7_dfu_aen.pdf
Think about where you TV audio originates. Unless you have an antenna on your TV, everything IT hears comes from an external audio device like a cable/sat box which almost certainly has a digital audio output and/or HDMI.
I would recommend you carefully utilize your limited connections this way:
Using Page 10 as a guide.
IF your TV has 2 HDMI's or one HDMI AND one Component input:
Cable box (Component Out and Analog Stereo RCA) or HDMI Out to corresponding TV In's if available.
Cable Box coaxial audio to the HTS (3). This way the best broadcast TV multichannel audio goes to the best electronics and speakers.
HTS HDMI Out (9) to TV Component In (if available), otherwise use Component Out (7). I recommend saving the highest quality video delivery path for your native BD because broadcast Hi-Def video is always bandwidth compromised while BD is the best video available today.
Composite Video Out (6) to Composite Video In on TV for HTS management functions.
You still have both Aux In (4) pairs).
Jan 25, 2011 | Philips HTS5580W/F7 Theater System
How do I get tv audio out of my surround sound HT3550U. I have HDMI cable in and function turned on TV audio. I also have LG TV. Any Ideas ???
What is the TV source?
If you have a coax (antenna or some cable systems) to the TV, then you need to connect the surround sound system to the audio out of the TV. Depending on the TV, the output could include Digital audio, RCA audio (red/white) or a headphone jack. Without knowing which LG TV model, I can't be sure which ones you have. Get the best cable for your TV/receiver system and connect that. Then set the TV to use the external speakers.
If the source is a set-top box, then the cables should run HDMI from the box HDMI out to the receiver HDMI in and then from the HDMI out of the receiver to the HDMI in on the TV. (Most TVs do not have HDMI out.) If the unit still doesn't play the audio, first try new cables and make sure the correct source is selected (some receivers have multiple HDMI in). Make sure the speaker cables are all connected (if they have separate connections) and that everything has power. (One of the usual speaker system problems in my house is loose cables from someone knocking against the back of the entertainment center and pulling.)
If you need more help, please provide more information on your equipment. I will do my best to help you diagnose the problem.
Nov 11, 2010 | Audio Players & Recorders
HDMI signal cuts out for a few seconds constantly from receiver to television. It does it when switched to cable box and the roku box. Onkyo TX-SR606 Scientific Atlanta Cable box thru HDMI Roku Box...
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
Sep 08, 2010 | Onkyo TX-SR606 Receiver
WD-73837 73 in. HDTV TV: hook up the coaxial cable from the tv to the recei...
7.1 surround sound will not work with a coax connection OR Composite (yellow video with Red and White audio). You either need to use an HDMI cable or the Component connection (Red, Green, and Blue connection along with the Red and White audio or the optical audio connection).
May 18, 2010 | Mitsubishi WD-73837 73 in. HDTV
Getting Audio to work with our Cable Tv
The HTR-6130 does not decode the audio from the HDMI inputs. It only acts as a switcher. You will need a separate audio connection from the cable box to the HTR-6130.
Dec 27, 2008 | Yamaha HTR-6130 Receiver
How do i connect my tv and my hd cable box to the home theatre system so that the audio is heard thru the theatre system?
The best way to do this is to run all hdmi cables from the source to the receiver (i.e. from the cable box to the receiver). Then run a single hdmi cable from the "out to tv" or "video/audio" out jack on the receiver to the television. Turn the tv on and select the input you put the hdmi cable in, then on the receiver select whatever you want to watch, i.e. cable.
Dec 24, 2008 | Samsung HTZ-510 Theater System
Setting up Cable with HDMI
Yes, the firmware on your hdtv box has an old firmware, I switched my old hdtv box with a newer one box and the problem was solved. It seems that it can't work if your hooking up with DVI to HDMI cable to your receiver to tv. Your hd box must have an HDMI out otherwise it causes problems. I also have rx-v661 and i finally hooked up everything HDMI to the receiver and then to the tv and it was having the problem you speak of. After I switched out the hd box for a newer one everthing worked fine.
May 13, 2008 | Yamaha RX-V661 Receiver
Sony surround sound hookup
In short, the answer is: Hook up all three to each other. I have a Samsung DLP HDTV, and I was trying to hook up a Sony DAV-HDX500 home-theater system and a Comcast HD set-top box, but I found that the Sony user guide is helpful only for setting up the speakers. Most of what it had to say about HDMI and getting the TV sound or cable sound to go through the speaker system was wrong (or, at least, it didn't work for me). So, here's what I did. I connected Component video cables (Y/Pb/Pr out) from the Cable box to the TV (Y/Pb/Pr in), audio cables from the Cable box (audio out) to the Sony system ("SAT/Cable" audio in), and an HDMI cable from the Sony system (HDMI out) to the TV (HDMI in). This allows me to 1) watch DVDs with surround sound through the TV's HDMI source (when the "DVD" format is selected on the Sony system), 2) watch cable with surround sound through the TV's Component source (when the "SAT/Cable" format is selected on the Sony system), and 3) watch cable WITHOUT the surround sound, as I did before I ever had the Sony system. One item of note: When watching a non-HD channel with the surrond sound on, the audio is slightly out of synch with the video; thankfully, there's no such problem on HD channels. Anyway, I hope this helps. It drove me crazy for two days straight!
Dec 31, 2007 | Sony DAV-HDX500 System
Connect PS3 for playing/viewing blue-ray thru surround sound
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
JVC HD-56FN97 56" Television Logo
147 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
