Keyboard One button will not work on keyboard
  • 1 more comment
  • frotuss Mar 11, 2008
    Just doesn't seem to making any contact at all? I think the keyboard may need replaced?
  • frotuss Mar 12, 2008
    is there a program that will run a diagnostic of the keys and possibly provide and overwrite without having to replace the keyboard? just a thought
    TampaNative
    Thank you so much for the hardwork and excellent soloutions to my problems, I am begining to understand that there really is only two ways to go and you have provided both. Once again thank you and maybe I will pose another problem for you to solve in the future.
    Sergeant:
  • 349 Answers
Just replace the keyboard much quicker without frustrations, so cheap these days
good luck
Terry
Posted on Mar 12, 2008
  • terry Mar 12, 2008
    i agree with your last statemant TampaNative you done a great job.
    President:
  • 778 Answers
Hello Frotuss,
You can pull the key off (carefully pry on the edges of the key until you feel one side snap up and work around it until it's off) and check to make sure the micro switch under that key is making and breaking contact (by pressing the small round button on the switch and making sure you can feel it click), if it's not clicking when actuated, it may just need cleaning (you can use a non residual, non petroleum based contact cleaner and spray it directly into the switch while pressing and releasing it to try and clean it), and if you decide to clean the switch, unplug the keyboard to be safe. If cleaning it doesn't work you'll probably be better served to replace the keyboard rather than replacing the switch, as the other switches will probably follow the same path as the one in question.
I hope this was helpful and Good Luck.
Posted on Mar 11, 2008
  • 2 more comments
  • Frank  Fernandez
    Frank Fernandez Mar 12, 2008
    Yes I would agree with replacing the keyboard.
  • Frank  Fernandez
    No there are no such diagnostics and even if there was it wouldn't fix a physical problem, more than likely it is the micro switch and the only options I can see are replacing the switch (again, not worth the trouble), or obtaining another keyboard (you can buy a used one for 5 dollars or so on ebay or other auction sites). The simplest solution would be to buy a working used keyboard, I see them all of the time at thrift stores and good will stores for a few bucks all of the time, so give those suggestions a try. I am sure that is the most economical and quickest solution.
    Ok, here's a solution that will cost you nothing, but will take a little getting used to. Go to start, then Accessories and then Accessibility and you will find "On screen keyboard" and you can use that with your mouse to type, and you won't need your physical keyboard. You can even just keep that on screen keyboard just to use for the key that isn't working on your keyboard (I have used this to work around a laptop that I was working on that had a bad "V" key, so when I needed to type a V, I just used the On screen keyboard for just that letter until I replaced the laptop keyboard. I know of no other solutions for your issue.
    I have stuck with you on this (and will until you are satisfied) and have spent plenty of time doing so and I think I deserve a higher rating than the one you gave me, if you don't mind, as I am working for free/ratings here, what do you think?
    Thanks in advance.
  • Frank  Fernandez
    Frotuss,
    You're welcome, and glad to help.
    Thank You.
  • Frank  Fernandez
    Frank Fernandez Mar 19, 2008
    Thank You Twk2201!
Num lock not working. number keypad not working. keyboard numbers are working.
Press the num lock button - usually the top left hand button on the keyboard numbers on right hand side of keyboard.
Mar 02, 2016 | Logitech Computers & Internet
Keyboard stopped working, tried it in notepad, tried removing battery,
Check in the Device Manager for the Keyboard presence. If the keyboard does not appear it means that the keyboard doesn't commuicate with the mainboard anymore. If the keyboard appears installed and ok in the device manager, open on-screen keyboard from accesibilty and press every button on the keyboard, you should see on the computer display if any of the buttons work. If some buttons work and others don't it means that your keyboard is broken and only service can help you.
Nov 02, 2010 | HP NB199UA Pavilion Notebook
Cordless keyboard not working.
there is a button under neath the recerver and the keyboard, hold the button under the recever and then hold the button under the keyboard
wait for a few secounds each time u hold this button then release and it should find it self then
Dec 03, 2009 | Logitech Cordless iTouch Keyboard/Cordless...
My desktop doesn't recognize my keyboard
Try a different keyboard on your computer.
If that works, try your keyboard on a different computer.
If it fails, then replace the keyboard.
Sep 10, 2009 | Gateway 2520915 Keyboard
Logitech CE0560 keyboard and mouse; first keyboard
First put new batterys in the mouse and key board. if you don't have a tester use a flashlight. pen light. push the remote pickup. light will blinknext push key board button and the mouse next. then try it and see if it works.
sometimes do the mouse first, Then the key board
Aug 10, 2009 | Computers & Internet
Wireless Keyboard not connecting
I opened up the Logitech Mouse and Keyboard Settings, turned my keyboard off, changed out the batteries and turned it back on. It then detected the Keyboard and asked for a password, I entered in the password, it said it was rebooting it and asked for another password which I entered (both passwords were given to me in the Settings). Now it is working just fine! Not sure if you have tried this but it might work for you.
Jan 04, 2009 | Logitech EasyCall Desktop? Keyboard and...
Stoped functioning
Normal 0 Turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
If your having trouble with the mouse also,
turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps. Bud
Dec 03, 2008 | Microsoft K5100141 Keyboard
Wireless mouse and keyboard inoperatab le
The keyboard and mouse both must be configured in order to work. Check on the top or bottom of the IR transmitter for a button that must be pushed. on the keyboard there are corrisponding buttons, these must also be pushed. do either keyboard or mouse first by pressing the controller button first and then the keyboard button, controller LED should blink to verify linkup. Repeat for mouse
May 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Keyboard problm
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Jan 12, 2008 | Logitech Inc Cordless Desktop LX 300...
Connecting wireless keyboard for L3600
There is a button on the bluetooth dongle that needs pressing to get the mouse & keyboard operating, I think I got them to work when the little long blue light on the dongle (there is one) it flashes for a brief time when pressed. I think if the mouse or keyboard button is pressed while its flashing it picks them up. Good luck, it was very tedious, I agree.
Nov 09, 2007 | Acer Wireless WIL-152 91.84R07.152...
Computers & Internet Logo
David Payne
David Payne
