Question about Maytag Atlantis MDE7400AY Electric Dryer
Difficult to start dryer - must pull control **** VERY hard
It has gotten harder and harder to start our dryer (maytag atlantis MDE7400AYW). we must pull the control **** out so that you can see the front panel pulling forward. just pulling till it clicks does not start it. we are not sure what part or parts might be implicated, or if this is something that we can fix without a service call. advice would be appreciated.
  • 2 more comments
  • coachp May 01, 2008
    sometimes the dryer won't start when we pull the button. We arrange the clothes or we have to take out a lot of clothes so it will start to turn.
  • Hattiemay May 19, 2008
    I have the same problem with my Maytag Atlantis 6400 model. Any solutions would be appreciated. Thanks
  • Budduh May 27, 2008
    When I pull the button to start dryer, it runs for about 10-15 seconds then stops. I can hear the timer mechanism working. Is this also a timer problem, or is there other problems?
  • Anonymous Mar 18, 2014
    Dryer doesn't start when control dial is pulled out.
    Novelist:
  • 131 Answers
You will need a new timer. Unplug the machine. The console has four Phillips screws across the top. After removing those, use a tiny screwdriver to remove the large white disc on the timer ****. Behind that is a square clip holding the rest of the **** in place. There should also be one or two 1/4 in screws holding the timer to the console. Grab the sides of the console and rotate the top down toward you. Now you can reach the quick disconnect to the timer and the plastic tab holding the timer in position.
Posted on Mar 11, 2008
SOURCE:
My maytag atlantis MDE7400AYW keeps tripping my breaker. Trying to hook up a 3 wire cord.
best call an electrician then only a person with hands on ability can fix it .
Jan 07, 2017 | Maytag Dryers
My Maytag Atlantis MDE7400AYW does not start when I pull the knob and I cleaned the sensor and connection and pulled the panel and checked the connection on the board the damp indicator light comes on but...
There are a few different scenarios which would cause the dryer not to start. First, make sure you door switch is functional. Second, the white thermal fuse, located on the exhaust housing may be open. Worst case scenario would be a defective timer or motor. Either of these may not be cost-effective to replace.
Mar 06, 2014 | Maytag Atlantis MDG7400AW Gas Dryer
Hi, My Maytag Atlantis MDE7400AYW is making a noise. It is the front of the drum ribbing on the front of the laundry opening. I pull back on it a bit and the rubbing noise stops. I ran it with the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 19, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
THE SELECT CYCLE KNOB IS GETTING HARDER AND HARDER TO PULL ON. THAT MAKE THE DRYER START. WHAT TO REPLACE?
Here is the part that you need...
http://www.appliancepartspros.com/part_details.aspx?part_id=4043083
heatman101
Nov 24, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
The start knob doesn't engage when pulled. Do I just need to replace the knob assembly? Is it difficult?
Take the knob off and try using pliers to pull the stem. Don't pull any harder than you would with the knob. If it works, you just need a knob. If it still won't engage, you need a timer.
Dec 07, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I pull the knob on dryer Maytag MDE7400AYW and it won't start.
yeathe start switch is bultdirrectly into the timer assembly youll need to replace the timer.
Feb 17, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer mde7400ayw won't run
I believe this last one has it right. the timer may be bad or worse, the board could be bad.
Jan 15, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Won't turn on when you pull the knob.
replace the timer it has a bad contact in it
May 19, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Removing Timer Knob on Maytag MDE7400AYW dryer
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Mar 03, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
455 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
