Ink line on back side of paper - Computers & Internet
    Sergeant:
  • 349 Answers
This sometimes happens when an ink cartrage has been over filled ,ink gets on the roller, clean the roller
hope this help you
Terry
Posted on Mar 12, 2008
SOURCE:
Fax is not going through. says there is an error. If making copy, it is very dark on right and left sides of the paper. Any sugggestions?
What you are probably experiencing is the fax machine is not getting a dial tone from your line, thus giving you a error.
Many times things get moved, paper runs out, ink runs low or the line gets unplugged. We suggest you check the line making sure it has a dial tone, checking your ink would be another great step.
Many times these machines get dirty with would cause the black ink run on the sides of the paper. You could clean that out with a can of compressed air. You would do this by opening the machine as you where to change the ink in it. You would give it a couple blast of air at the exit paper trail.
The other thing is this is thermal meaning the ink is super heated onto the paper, if there is any residue of ink this would cause this issue.
Now the error message you did not give us, I would be interested it knowing the error code before I can make further comment on how to proceed with the sending issue. Many reasons are:
1. No dial tone
2. Paper jammed inside the machine
3. OCR scanner errors
Please let us know what the error code is so we can give you a great solution on what to do from there. We do Thank You for using Fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 01, 2011 | Sharp UX 108 Roll paper Thermal Fax
Cannon MP500, new ink now printing black line on back page
Got to Printers and Faxes in Start, Right click on the icon for the printer, click properties, click maintenance and try cleaning the backing plate from there.
Jan 19, 2010 | Canon Pixma MP500 All-In-One InkJet...
Solid black ink line on the back of any page copied, so heavy it bleeds through the paper
Hello. When you get ink on the back side of the paper that indicates that the printer roller [or platen] is dirty. To clean it get some paper towels and some rubbing alcohol. then, dampen a paper towel and start cleaning the roller. Carefully work your way from one end to the other and then all the way around the entire roller.
Dec 01, 2009 | Ovens
MP830, how to retrieve faxes in memory to my PC
- A margin appears
on printouts.
2 B Paper feed
Improper paper
feeding:
- Multi-feeding
- Skewed paper
feeding
- Paper jam
- Paper feeding from the
ASF
- Plain paper
- Highest print speed
(Custom setting to 5)
- In the high temperature
and high humidity
environment
- In the low temperature
and low humidity
environment
- With the maximum
amount of paper set (13
mm)
and high humidity
environment, paper
becomes wavy; in the
low temperature and
low humidity
environment, paper
curls significantly.
When the maximum
amount of paper is set
in the ASF, and if the
paper-return tab fits in a
wave or curl of the
paper, the tab slips and
does not catch paper
properly, causing paper
feed problems.
- Reduce the amount of
paper set in the ASF to
half (approx. 5 mm
high).
- Multiple sheets of
paper feed at the
same time.
- Paper feeds at an
angle.
- A paper jam
occurs.
3 C Print results
Skewed paper
feeding (at the
level of +/- 1%)
ASF
- Credit Card size
Since coaxial tolerance
between the pinch roller
and the LF roller, which
determines the paper
feed alignment, is
0.2mm, skewed paper
feeding can occur.
However, according to
the field data of current
models, the skewness
level caused by the
coaxial tolerance of
0.2mm is within the
criteria of +/- 1%, thus
the phenomenon is left
as is.
- Align the paper guide to
the paper edge tighter
than usual.
- Paper feeds at an
angle.
- A margin appears
on printouts.
4 A Print results
Soiling on the
back side of paper
(lines or streaks
parallel to the
paper feed
direction)
- After continuous
borderless printing of
small sized paper (such
as 4 x 6), when a larger
sized paper (such as A4)
is printed.
- With Photo Paper Plus
Double Sided or
postcards, the
phenomenon is likely to
be noticeable and to be
complained of by users,
as printing is performed
on both sides of such
paper.
In borderless printing,
printing is performed to
the size slightly larger
than the paper size, and
ink off the paper is
absorbed by the platen's
ink absorber. Absorbed
ink may attach to the
platen rib(s) after
several dozen sheets are
printed, causing soiling
at the leading edge of
paper or on the back
side of paper.
1. Perform Bottom plate
cleaning (from the
MP driver or via the
operation panel) up to
3 times*1.
2. If soiling on the paper
still remains after 3
times of Bottom plate
cleaning, wipe the
platen rib(s) and their
surroundings with a
cotton swab.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
Soiling on paper in
automatic duplex
printing (lines or
streaks
perpendicular to
the paper feed
direction)
- Automatic duplex
printing (Photo Paper
Plus Double Sided,
postcards, plain paper)
On the rib(s) inside the
sheet feed unit used for
duplex printing, ink
mist may accumulate,
smearing paper.
Temporary operational
solution:
Cancel automatic duplex
printing, and manually
print each side of paper.
Cleaning by user:
cleaning (from the
3 times*1.
- Paper gets
smeared.
- The back side of
paper gets
smeared.
- Even after Bottom
plate cleaning
was performed,
and the platen
ribs were cleaned
with cotton swab,
paper gets
smeared.
2-10
Oct 12, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannon Pixma MP500- I get a solid black line on the reverse side of a printed page. Went through all the cleaning procedures and new cartridge, no change.
For some reason, the printer is designed to dump ink into the bottom of the tray before feeding on the paper. The paper is then dragged over the ink, leaving the black line. This is a software issue, not a hardware one. I'd advise that you update all of your print drivers, as well as your firmware.
A temporary fix is to clean the rollers and base plate of the printer for ink spills.
Check for any bits of paper or debris that may be caught in the printer. Be careful to feed in the paper perfectly straight, as this printer does not have good rollers, and it will cause paper to break off and cause problems. If any debris has caught or absorbed ink, it will cause the back of the paper to smudge, and you have black lines.
Jun 23, 2009 | Canon Office Equipment & Supplies
Canon MP950 - strong black line on back side of the paper. It looks like it just spreads black color on the back side of the paper while printing. Even when i just use "clean heads" options - it still...
The problem is most likely your ink catcher, it is a sponge that catches any ink when it is being cleaned. you need to remove it and clean it then put it back in. there will be instructions in your manual.
Jun 21, 2009 | Canon Pixma MP950 All-In-One InkJet...
Black ink cartridge is leaking and black line is running down back of page
if you do your own refill the ink u are using is of the wrong density, get the right ink
May 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
I have a black line of ink on the back side of the paper when I print anything. It fade through to the front. The line goes down the middle of the paper and is about 1/4 in wide
Cause: Possibly a leak in an ink cartridge. Pull all of your cartridges and inspect for leaks....it will be obvious and you will probably get it all over everywhere if you are not carefull, so be prepared to immediately toss it in the waste bin.
Solution: Sounds like you have ink (wet?) inside the paper path on one of the rubber rollers. It sounds like it is so saturated with ink that this will continue for a long time until it either runs out or you replace the roller.
Look for the roller that is where this line appears. Using another piece of paper or a paper towel soaked with alcohol (rubbing), touch it and see if ink doesn't appear on the paper. If it does then you might be able to clean it by continuing to soak up the ink on scrap paper by pressing it out of the roller. It won't completely fix the problem and it won't do it right away but it will get it started.
Jun 21, 2008 | Office Equipment & Supplies
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
problem is when the printer does a head clean dumps large amount of black ink on to rollers. Replacement head is almost £100 and not certain to fix fault
Apr 12, 2008 | Canon Pixma MP800 All-In-One InkJet...
Printing
No black line while you scan, but it only appears while you are printing?
Mar 18, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Open Questions:
Brother Printer CUSTOMER service pHoNe:~{-l85522l4867}-}nUmBeR USA USAiary Brother Printer CUSTOMER service Number +l85522l4867}}USALogin Repair service center to resolve all Brother Printer tEcH SupPoRt pHoNe nUmBeR products. Brother Printer ROUTER is an American multinational company which was founded by Michael Brother Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Brother Printer ROUTER support number, and selling of computer-related services and products. Brother Printer ROUTER Tech Support Phone Number Recently, Brother Printer ROUTER has been named the number Brother Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, Brother Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a Brother Printer ROUTER Service Tag or a Brother Printer ROUTER Get Brother Printer ROUTER Technical Support Phone Number and Customer Services. Brother Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 21, 2019 | Brother Computers & Internet
Computers & Internet Logo
26 people viewed this question
Ekse
Marvin
Marvin
