-   APOS A TROCA DO COMPONENTE SPLIT , DIVISOR DE ALTA PARA OS CINESCOPIOS, O APARELHO DEU IMAGEM COM O QUADRO REDUZIDOM GOSTARIA DE RESSETA-LO; COM ENTRAR NO MODO DE SERVICO.
TEL 55 031 25262244 OU 55 31 97258833 OLIMPIO-   Guest
everytime i put it on it comes back off.the green light comes on and then then the red light stays...
(More)
everytime i put it on it comes back off.the green light comes on and then then the red light stays on with no pic on the screen.
My PSP doesn't resume from sleep mode properly. It goes to the main menu instead of the game. The...
(More)
My PSP doesn't resume from sleep mode properly. It goes to the main menu instead of the game. The only thing I can think of is that this happened after I upgraded the firmware about a month ago. The PSP doesn't let me upgrade again. Anybody know how I can get the previous version which worked fine?
Hi, we have a problem with our tv. It is Pioneer SD-P50A3-Q model projection tv, and the standby...
(More)
Hi, we have a problem with our tv. It is Pioneer SD-P50A3-Q model projection tv, and the standby light will turn on when you turn the main power on, however the monitor will not turn on, and the standby light does not turn green.
T.V. "clicks" when I trie to turn it on but will not turn on, nor will the green power...
(More)
T.V. "clicks" when I trie to turn it on but will not turn on, nor will the green power light come on.
I have a pro-710 hd...will not power on...I replaced a 6.3amp fuse on the power board and it worked...
(More)
I have a pro-710 hd...will not power on...I replaced a 6.3amp fuse on the power board and it worked for a few minutes ..then power down and will not turn back on but the fuse did not blow
