Question about Dacor Preference RSD30 Gas Kitchen Range
Replace RSD30 oven control
The "lights went out" on our RSD30 front panel. We called the Dacor parts supplier and they said we needed a new oven control. We just got it (part no. 62692 -- has the display unit attached) and I started to install it but found that it is not obvious how to get inside to remove the old one and replace it with the new unit. It looks like I need to remove the top of the stove, but rather than undo the wrong screws (nuts) by trial and error I would like to get some advise. What (and where located) should I remove to reach the oven control unit. Once I get into the stove, the actual replacement of the old unit looks pretty straight forward. Any help would be greatly appreciated.
Thanks, Bob
  • 1 more comment
  • Bob580 Mar 12, 2008
    Thanks bromikl, very helpful and I'll give it a try. I also called Dacor tech help and they said there is a special tool to take off the brass ring nuts under the burners and that this would give me some access to the panel from the top. I ordered the tool so I'll wait until I have that so I have plenty of access options. Thanks again!
    The tool is part number 86007C and costs $14.78 which comes to $21.73 with tax and shipping. After this job I will keep the tool since it seems to be the key to the kingdom for getting into the stove. Hopefully I won't need it again, but it will be there just in case. I started to try the two screwdriver approach but the rings are on pretty tight and i didn't want to risk damaging them. Thanks again.
  • thecollinscl Jan 21, 2009
    I have a similar problem. Nothing lights up on the display - the stove elements don't heat up - but the oven light comes on. Is this also the oven control?
    Thanks,
    Grant
    Novelist:
  • 131 Answers
This is one of the hardest stoves to get into. Turn off the breaker.
Pull off the burner knobs. This should reveal four large plastic nuts holding the console in place. You can turn them gently with channel locks straight on - not from the side. After you've got the console loose, everything else is downhill. There's lots of screws behind console, and across the bottom of the console (just above the door.) Remove just the ones you need, or face the wrath of Dacor!
Be careful about the rubber strip across the top of the console. It often stretches during a repair. You might have to cut off 1/4 to 1/2 in to get it to fit again.
The large plastic nuts are very east to get cross threaded when replacing them. I recommend turning them counterclockwise until you can feel the threads line up.
Posted on Mar 11, 2008
  • Michael Grimshaw Mar 12, 2008
    Sorry you have to go that route. I had to remove those brass rings once in a built in gas cooktop with a stainless surface. i was wishing I had one of those tools the're sending you. I finally did it with two flat screwdrivers and some penetrating oil (and a hammer tapping at some points.)
    I didn't imagine you'd have to do that for the electronic oven control on the model pictured above. Good luck!
    (BTW, what do you plan to do with that tool afterwards?)
SOURCE:
DACOR RSD30 RANGE . NO CLOCK OR FUNCTIONS SHOWING
Turn breaker off and on control may reset and work if not
you need control witch is not available
option 1 we can do upgrade to covert control to newer dacor system
cost is around $1400 can if you are in our service area
option 2 other than that you can have control sent out for rebuild they can not always repair
option 3 call dacor they may offer you a discount on new range as parts are no longer available
good luck hope breaker reset works
Sep 18, 2017 | Dacor Kitchen Ranges
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Regards,Richard
Oct 17, 2011 | Dacor Ovens
Describe your dacor rsd30 new oven door Problem - the glass is broken in the window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Nov 26, 2010 | Dacor Preference RSD30 Gas Kitchen Range
Dacor RSD30 beeps and displays F1 warning... do I need a replacement panel?
You need a control board replacement. This will require taking the panel off, just be sure to kill the power and replace wire for wire. Its fairly easy once you have the panel off. Just reassemble in reverse order.
Oct 27, 2010 | Dacor Preference RSD30 Gas Kitchen Range
Oven does'nt stay on.
SOUNDS LIKE TERMOSTAT REPLACE THIS AND OVEN SHOULD WORK.
Oct 13, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
The display panel for the oven control of our Dacor Model RSD308 Duel Fuel Range suddenly stopped displaying correctly. The display panel shows parts of numbers and letters so you cn't read temperatures or...
Once the display board stops showing the numbers and functions, you have to replace it. You could try and turn the breaker off to it. Sometimes this will reset the main board unit.
Feb 26, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Control Panel Problem
Sounds like a membrane issue and I would certainly call dacor corp and maybe they will assist in the costs. That is if you provide repeated service part replacements.
Apr 01, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Dacor Preference RSD30 Gas Kitchen Range Logo
861 people viewed this question
Top Dacor Kitchen Ranges Experts
Steve Allison
Steve Allison
Jaime Hernandez
Ekse
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
