Check that the clutch is working properly and that your gearbox is full of the correct grade of oil. Usually a thinner grade makes selection easier.
The clutch probably needs to be tightened up a bit that is if you can i dont know if it has a cable or is hydralic
if it has a cable then tighten it untill you have a little free play you can feel when you depress clutch pedal
if hydrolic then you may have air in system or master/slave cylinder may be going bad
also if you have recently had the gear oil changed they may have put in to thick an oil or the wrong type
