Home
My Products
Sign In
Back to:
All Products
Toshiba
DKT-2010 Corded Phone
Troubleshooting
Tags
Voicemail
voice mail
NO RINGER
intercom
number of rings
Ringer (by 2 users)
posted by
ELSH
on Mar 11, 2008
Report abuse
how do I change the number of rings before the voice mail message begins?
Solve This!
I have the same problem.
X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
1 Other User Has The Same Problem
Comment by
tsom
, posted on May 21, 2008
How do you change the number of rings before the voicemail comes on?
Solution #1
posted on Jul 28, 2008
mitelmike
Rank:
Guru
Rating:
93%, 46 votes
If you are using Call Frwd No Answer use code # 603 or if you are using Call Frwd Busy/NAns use # 604 in the following set up.
Press " Intercom/ PDN " plus above code ( #603 OR #604 )
Enter Destination ( Usually Voicemail Access Code )
Press " Speed Dial "
Enter time delay ( 08 - 60 sec )
Press " Redial "
Time delay is default at 12 sec ( 4 ring cycles )
Was this solution helpful? Show your Appreciation by rating it:
Inappropriate
Thanks for Trying
Helpful
FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on ringer:
I don't want to Accept this solution
Done
Suggest a new solution for this problem
Can you Help with these Phones problems?
Toshiba DKT-2010 Corded Phone
How do you mute a conference call?
I have a Toshiba DTK 2010SD phone. Is there a way to mute...
Answer This...
msg button flashing
the message button flashes eventhough when i go into the...
Answer This...
Toshbita DKT-2010 main phone message
Hello, I have the right codes for our voice mail but can't...
Answer This...
DKT 2020 ST
When a call is transfered to a certain extention and is...
Answer This...
not to sure
not to sure what the (PCOU2A)card does?
Answer This...
Let Our Experts
Solve
Your Problems
Ask!
Loading problems.
Bogda
Guru
Let FixYa Experts
Solve Your Problem
Ask!
Repair Service
Find Phone Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
No
Yes
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
