Toshiba TP55D80 rear projection has sunburn
I have a Toshiba TP55D80 rear projection TV. The set had been working
untill a couple of weeks ago, albeit with an orange-red cast and a slighly soft picture. It was turned on one day, and the sound was still working, but there
was no picture. The entire screen was red.
Even a relativley small LCD set is on the expensive side. I had been
thinking in terms of a 32" or 37" of which there are a couple of brands that would cost just under $1000.
Would it make sense to fix it? The size is better than what I would want
to spend in a new set.
Thanks.
  • stealneil Mar 11, 2008
    I hear you!
    However, Id be curious to know what
    you would cite as the probable cause of the failure.
    Also, would you know what section of the yellow pages I should look at to find someone to haul it away?
    Thanks
  • stealneil Mar 12, 2008
    Thanks. Actually, as cause of failure I had meant which component. Just guessing myself
    as to the source of the color shift some months ago I had been looking at the price
    of projection lamps and saw that they were expensive.
    Thanks. I don't intend to repair the unit. I'm just curious.
    Genius:
  • 3,587 Answers
Nope...get a new one, my call..unless you like to do this a lot..
Posted on Mar 11, 2008
  • Patrick Michaels
    Patrick Michaels Mar 12, 2008
    recycling electronics dealer..
    causes of failure?
    power interruptions..
    age
    humidity
    thankya for using fixya
  • Patrick Michaels
    well, even if I was on your doorstep, I'd need lab level diagnostics in my briefcase. Doing it online, through a chat would be an Act of God(smiling)..hope you find this good enough to rate when you're done.
Tv goes off after about 5 seconds
Bulb replacement is a good try, I would also have them come out to look at the set again as I am sure there is some kind of warranty on the parts.
Apr 17, 2010 | Toshiba 51H83 51" Rear Projection...
Picture Problems!!! TOSHIBA TP55D80 REAR PROJECTION TV.
Look up your user manual, it sounds like your zoom feature has been activated to the max. I have a Zenith backlit LCD TV and it has a zoom feature you control from your remote. You could open up your on screen menu and find the place to reset the TV to factory settings that should clear up the problem.
Sep 28, 2009 | Toshiba Televison & Video
Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
problem is bad hyper module or can have tech repair it with capacitors
Feb 05, 2009 | Toshiba 40H80 40" Rear Projection...
Could you tell me how to get into the service menu of my toshiba rear projection tv?
Most TV repair shops have a warranty 30, 60, or 90 days. Call him back. You probably have a convergence IC failing or a resistor changing value in the green convergence output circuit.
Jun 04, 2008 | Toshiba 57H81 57" Rear Projection...
Humming/buzzing sound
That could be either the ballast, or colorwheel. Does the sound get louder at the rear of the tv or louder in front. let me know I may be able to help you.
Apr 08, 2008 | Toshiba 46HM95 46" HDTV
Resetting convergence daily on Toshiba 43h70
Hi Mark, tough call without putting a scope to the circuit, either the convergence IC`s are going bad, signal from DCU is going bad (digital convergence unit), or possibly bad solder somewhere in the convergence circuit, I`m afraid your going to need a tv tech for that problem, BMW Rider
Jan 02, 2008 | Toshiba 43H70 43" Rear Projection...
Convergence has to be set daily
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic are going replace them before you have more problems
Dec 12, 2007 | Toshiba 43H70 43" Rear Projection...
No picture but have sound
Toshiba 57H81 57 in. Rear Projection Television Go to above under solution for tip on fixing your problem.
Jun 22, 2007 | Toshiba TP50H50 50" Rear Projection...
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
