Have a buddy turn the key on run while you get down by your fuel tank and listen for the fuel pump. If you don't hear anything try hitting it while the key is still on run. Sometimes this helps. Still get a new pump even if that helps. Trust me! If the fuel pump works, check to see if there is fuel pressure in the rail.
If it is a spark issue, take out an easy to reach spark plug and reattach the wire. Lay it on the plenum of the motor so the threads are touching metal. Have someone turn the engine over while you look to see if the spark plug is sparking. DO NOT TOUCH ANYTHING WHILE SOMEONE IS CRANKING! Just make sure the threads are properly touching metal before cranking. If no spark is seen you can try to relocate it but just make sure it is not being cranked while you are touching it. Be careful! That will at least help you find out if it is lacking fuel, or spark.
