Question about Canon PIXMA MP460 All-In-One InkJet Printer
Pulley belt when the belt came off it got trapped behind the ink ports cant get fingers in to pull on belt to release it to put it back on the drive end how do i release it
    Genius:
  • 3,587 Answers
Try long tweezers...
Posted on Mar 11, 2008
SOURCE:
How do i remove and add a serpentine belt for a 1994 pontiac bonneville
There's a pulley called idler it moves up and down with the belt. Sometimes there's a square hole or you can use the bolt on the pulley. Front wheel drive pull the tool you use towards the back of car. Rear wheel drive pull tool towards passenger side won't move a whole lot. Side belt from under pulley release pulley and remove the belt just repeat the steps it took to remove belt put reverse order
Nov 10, 2014 | Cars & Trucks
How do I release tension to put fan belt on
If you have the v-belt type, you have to loosen the alternator or power steering pump.
If you have the serpentine belt type, follow these directions:
Serpentine Belt
  1. On all models except the 7.4L engine with A.I.R. pump (California emissions only), use a 1/2 in. breaker bar with a socket placed on the tensioner pulley bolt, rotate the tensioner to relieve belt tension.
  2. On all 7.4L engines with a A.I.R. pump (California emissions only), use a suitable wrench on the pulley axis bolt to rotate the tensioner clockwise to relieve belt tension.
  3. Remove the serpentine belt.
To install:
  1. Route the belt over all the pulleys except the tensioner.
  2. On all models except the 7.4L engine with A.I.R. pump (California emissions only), place the breaker bar and socket on the tensioner pulley bolt and rotate the tensioner to the released position.
  3. Install the belt and return the pulley to its original position.
  4. On all 7.4L engines with a A.I.R. pump (California emissions only), use a suitable wrench on the pulley axis bolt to rotate the tensioner clockwise to relieve belt tension.
  5. Install the belt and return the pulley to its original position.
  6. Check that the belt is properly seated in each pulley
Jan 17, 2011 | 1991 Chevrolet K1500
How do i fit a new belt in the washing machine
Hello,unplug appliance, remove lid and back plate, place belt on motor and carefully on drum pulley, turn pulley to pull belt onto its, its quite tight to do but is possible, watch out for trapping your fingers.
Thanks
May 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do I install the altanator belt
The belt on these cars are a serpentine belt. One belt drives everything. To change it you first need to locate the belt tensioner. Will look like a small arm with about a two to three inch pulley on the end running against your belt. On the lower side of the arm below the pulley you will se a bolt head onthe tensioner about 13mm or 15mm(cant remember which) put a 1/2 inch drive rachet or a long wrench on this, longer is better for leverage because its spring loaded, and as you turn the head it should release the tension on the belt by pulling the tensioner back. If the bolt starts to come loose you are going the wrong way. Once the tension is released you should be able to remove the belt and replace it. Start tword tthe bottom pulleys when routing the new belt as it will be easier to pull back the tensioner again and put it on the top last. Hope this helps.
Mar 26, 2010 | 1994 Chevrolet Beretta
How do i get the tension of the drive belt to change water pump?
If it is a serpentine belt they all have a tension wheel. It looks like a pulley but is attached to a tension arm and will have a nut on the pulley center. Take a big ratchet or breaker bar and push/pull on the pulley arm to release the tension. Don't pinch your fingers. The same process to reposition the belt. Look at how the belt goes around the pulleys before removing to not get confused on putting the belt back.
Mar 11, 2010 | 2005 Dodge Grand Caravan
Hi Can any advise how i add a new belt to a hotpoint 9324 dryer ? Is it from the from or rear & if possible the configeration how the belt goes around the pulleys at the bottom. Thanks Graeme
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly.
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
Sep 10, 2009 | Hotpoint Dryers
Belt is off my audio-technica turntable at-pl50
WASH YOUR HANDS FIRST! Any oils on the drive belt may cause slippage.
This is from the manual:
A) Remove the record mat from the turntable platter
(Fig. 10a). Through an opening in the
turntable platter, visually inspect to see if the drive belt
is around the motor pulley (Fig. 10b).
B) If the drive belt is not around the motor pulley: Lift
and remove the turntable. Place a thumb into each of
the left and right openings on the turntable platter; and,
using the fingers to press down on the turntable housing’s
surface, pull the platter straight up (Fig. 10c).
Avoid pressing on the tone arm.
C) With the turntable platter bottom side up, place the
belt along the outside wall of the turntable platter's
drive rim, making certain that the belt is smooth and
flat all the way around (Fig. 10d).
D) Put the turntable back on the center spindle, make
certain it is fully seated, and align one of its openings
over the motor pulley position.
E) Through the opening, carefully hook the turntable
belt with a finger or with the original red ribbon (never
use a sharp object) and pull the belt over the motor
pulley (Fig. 10e). Make certain the belt is not twisted
between the pulley and the platter’s drive rim.
F) Put the record mat back on the platter.
G) While holding the tone arm in its rest position,
slowly turn the platter by hand clockwise at least 10
rotations to clear the mechanism’s automatic cycle.
Apr 24, 2009 | Audio Technica AT-PL50 Turntable
I cannot get the drive belt back on.
Hi.
Asuming you have the correct belt, then you will really have pull and stretch it hard to get it on.
It is the case that the new belt wiill not appear to be the right size.
Just persist, mind you do not trap your fingers!!!
Nov 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
Replacing the Drive Belt
I am not an expert but I do have a Hotpoint 9334 Tumble Dryer which I guess is similar to the 9314.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly. (This is a bit scary as you have to hit them quite hard and the fingers look fragile)
Sep 16, 2007 | Hotpoint TDL14 Electric Dryer
Belt came off
Remove the rubber mat and you will see two holes in the turntable. Put your fingers in these holes & using equal force pull up to release the turntable. The drive belt goes around the metal disk you will see below and around the drive pulley. Most likely it has just jumped off the pulley so hook it back over. Replace the turntable and gently rotate it a couple of revolutions, you can see the belt through the holes in the turntable. If all is seated OK power up & enjoy! You can download the manual from the link below: http://usa.denon.com/DP29F_DFU_ownersmanual.pdf This shows the procedure as per original install. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 13, 2007 | Denon DP-29F Turntable
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
127 people viewed this question
Clive
Clive
old marine
old marine
Ekse
