??Windows won't start on Acer Laprtop Travelmat 290 running WIndows XP (1 & 2) It keeps saying start windows in safe mode, safe mode with networking, safe mode with command prompt, last known good configuration. I guess it's the hard drive that has crashed??? How difficult is it to buy a new (bigger faster) hard drive and re-install windows? The laptop didn't come with a Windows CD and I have my data backed up, so haven't lost anything.
    Sergeant:
  • 349 Answers
Give the "last known good configuration" a go if you have not already ,or the safe mode ,
if that is no good
when the pc try's to boot up it should show a key ,such as (F11) that needs to be hit to enter the recovery stage ,what ever it is do it and follow the prompts,this should recover the laptop to its delivered state ,when it finishes you can restore your backups.
however if the drive does not have a recovery partition you will not be able to do it.
So:
it may be that the hard drive is ok but the operating system files have been corrupted in some way,
as you have no windows disc you will need to obtain one to either recover the operating system or re install windows, and you may have to go to the Acer website afterwards for some drivers when you have finished.
good luck
Terry
Posted on Mar 12, 2008
SOURCE:
I have a Dell XPS 419 and receive STOP: 0x00000024 (0x00190203,0x8AD31CA0, 0xC0000102,0x00000000) on the BSOD. Any ideas what it is or where to start?
Stop: 0x00000024 generally occurs due to the following reasons
1. The file system or partition structure is corrupted.
2. A driver compatibility issue exists.
1.Try boot the computer in last known good configuration. You may refer the link for steps: How to start your computer by using the Last Known Good Configuration feature in Windows XP: http://support.microsoft.com/kb/307852
2.Run chkdsk tool from Windows recovery console. You may refer the links for description of the Windows XP Recovery Console: http://support.microsoft.com/kb/314058
How to perform disk error checking in Windows XP: http://support.microsoft.com/kb/315265
May 02, 2014 | Computers & Internet
Tip
How to boot up in safe mode from Windows XP
Showing the steps to boot up in safe mode from Windows XP.
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
1.If the computer is running, shut down Windows, and then turn off the power.
2.Wait 30 seconds, and then turn the computer on.
3.Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. 4.To resolve this, restart the computer and try again.
5.Ensure that the Safe mode option is selected.
6.Press Enter. The computer then begins to start in Safe mode.
7.When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
1.Close all open programs.
2.Click Start, Run and type MSCONFIG in the box and click OK
3.The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
4.The computer restarts in Safe mode.
5.Perform the troubleshooting steps for which you are using Safe Mode.
6.When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer.
Select your steps to boot up into safe mode to your Windows XP System.
Other relative articles: Crack windows password from system SAM files
How to reset Windows administrator password if forgot Windows Xp/2000/2003/2008/Vista/7
on Apr 16, 2010 | Computers & Internet
I have an Acer one aspire that won't start. I keep
Dear user,
Please try to restore it to factory mode or re-install OS
Aug 22, 2012 | Acer Aspire One PC Notebook
Okay, so I'm not even close to being savvy with computers. Anyways, my netbook keeps on restarting and won't let me go on to the desktop. Safe mode, safe mode with networking, and all those other...
Do a Windows repair by following below steps:
1- Boot up form the CD
2- Windows installer will start loading some files to your hard drive, when it finishes go for "To set up Windows XP now, press ENTER" so press ENTER
3- Press F8 to accept the License Agreement
4- Now Windows installer will search for installed Windows OSes on your hard drive and should find yours and lists it at the bottom, highlight it, then press R
Wait for the repair process to finish. I hope this solves your problem.
May 11, 2011 | Microsoft Windows XP Professional With...
Acer Veriton m460 keeps rebooting running windows xp pro. Ran e-recovery now the system will not start in windows. just says error press any key to continue. when you press a key it just keeps coming back...
try booting in safe mode. then scan for possible virus. then restart and login in (not in safe mode). if it still wont work, reformat the drive then do the fresh installation of windows.
Apr 11, 2010 | Computers & Internet
Make sure your scsi disk is turned on refer to manualwhen installing windows xp pro, acer travel mate 290. then states use another partition but comes with the same message one of your disk is damaged...
yes indeed nowadays laptops are designed for windows vista and better versions as these are equipped with SATA harddisks. to install windows xp in these systems u need to change SATA settings in bios which can be done by 1->pressing F2/DEL key during the starting acer empower people screen which v get once v switch on the laptop 2->in the BIOS screen go to MAIN tab by pressing right arrow 3->scroll down till u get SATA mode->press enter .two options ll be available 1.AHCI 2.IDE 4->select IDE and press enter. 5-> go to exit tab and select save and exit 6-> now try installing xp pro!!
Jan 11, 2010 | Acer TravelMate 290 Notebook
My Acer Aspire 1 gets stuck when the Windows XP logo apears and just keeps booting, what can I do?
Hard Drive error on the Disk most likely... Try to go to Windows "Safe Mode"... pressing F5 before you see the XP Logo and after you see the system information screens. Once in safe mode... run ScanDisk.
Open My Computer | Right Click C Drive | Left Click Properties | Tools Tab Run Check Disk for Errors... also check mark both boxes.
Reboot
Jan 01, 2010 | Acer Aspire One Netbook 8.9" Notebook
Windows will not open up
Insert your install disk and select Repair Windows. Hopefully, this will fix the start-up issue you are having, which may be linked to a driver or a multitude of other possible problems.
Sep 23, 2009 | Acer Aspire One PC Notebook
I am trying restore windows vista on my ACER Aspire 5100 but a message keep coming up saying that Windows cannot open the required file D:SourcesInstall.wim. It also says the file does not exist and to...
This error is due to....
  • The default security provider in Windows XP, or
  • the System drive letter
  • To solve dis issue.. try one of the methods
    1)Reset Windows XP Default Security Provider
    1. Open Start menu, select Run, type regedit and then press Enter.
    2. In the Registry Editor window, locate and delete the following registry keys:
      HKEY_USERS\.DEFAULT\Software\Microsoft\Cryptograp hy\Providers
      HKEY_USERS\S-1-5-20\Software\Microsoft\Cryptograp hy\Providers
    3. Exit the Registry Editor and restart your PC
    2)Reset The System Drive Letter
    1. Start your computer in Safe Mode-turn on the PC, and press F8 during startup. Next, when the Windows Advanced Options menu is displayed, scroll down and select Safe Mode.
    2. Open Start menu, select Run, type regedit and then press Enter.
    3. In the Registry Editor window, locate the following registry keys:
      HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
    4. Edit this key to change the value of the system drive.
    5. Exit the Registry Editor and then restart your PC
    Mar 20, 2009 | Computers & Internet
    Windows wont open
    need to re-install windows
    Oct 20, 2008 | Acer Aspire 5100 Notebook
    Open Questions:
    Computers & Internet Logo
    Ekse
    Alun Cox
