Question about Maytag SkyBox MBV1976A Beverage Dispenser
Replacement for Skybox compressor
I need to replace the compressor in my Maytag Skybox. It has a Zel GVY40Ad compressor in it. Can you suggest a replacement for me. Thanks, Roddy
  • 2 more comments
  • Anonymous May 27, 2008
    I have the same issue. I called Maytag and they were like too bad, we don't make the compressor anymore so it can't be fixed. What a disgrace!!
  • tepcavazos May 31, 2008
    MY COMPRESSOR CLICKS ON FOR A FEW SECONDS THEN CLICKS OFF, IT OVERLOADS. DO YOU THINK THE PROBLEM IS THE COMPRESSOR OR COULD IT BE THE STARTER RELAY OR STARTING CAPACITOR? ANY SUGGESTIONS WOULD BE OF GREAT USE....THANK YOU.
  • Gary Davd
    Gary Davd May 11, 2010
    plz repost the model # the one you gave is
    not coming up >>Zel GVY40Ad
  • Marilee Glover Aug 02, 2012
    Check out compressors for water coolers. I am pretty sure they are teh exact size you want. I found this out after giving up trying to find a compressor and getting rid of my Skybox. :(
    New Friend:
The solution is too change refrigertants, Enbraco makes the PW4.5hk11. its a little over sized and you'll need to switch to hot shot.
Posted on Jan 29, 2010
    New Friend:
Spec book on ZEL compressors http://www.zeltj.com/zeltjen/ZEL_Catalogue_ZR0100.201403.pdf
GVY40AD is a little ways down on the left side
Posted on Mar 28, 2016
Service manual on the sky box can you please send to [email protected] ... thanks for your time...
Posted on Apr 13, 2008
SOURCE:
Our Coke machine door was accidentally left open for days. Because of this, the compressor is shot. $800 is a lot to throw away over a $130 compressor. Help !!!!
I would contact tecumseh refrigeration compressors. It will still cost a pretty penny to replace. Proper diagnosing tel if the compressor is shot or there is a bad part that keeps it from running
Nov 02, 2015 | American Retro AR-15002 1930s Coca-Cola...
Display com., start,and run terminals on ZEL GVY40AD refrigeration compressor
0 run 0 start
0 common
or----------------------------------------------------------------------------------------
0 common
0 start 0 run
The 0's replicate the compressor pins .
Jan 01, 2010 | Electrolux Refrigerators
Removing compressor from skybox
Maytag never offered a replacement compressor for the SkyBox units. It was not a cost effective repar to make. If you are sure the thermostat is supplying 120VAC to the compressor, you can install a Supco URCO410 relay/capacitor/overload kit. This part should only be installed by a qualified service technician.
Feb 22, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Removing compressor from maytag skybox machine
Maytag never offered a compressor as a replacement part for the SkyBox. It simply was not cost effective. If you are sure the thermostat is supplying 120VAC to the compressor, then have a qualified service technician install a Supco URCO410 relay/capacitor/overload kit on the compressor. As with any sealed refrigeration system, the US Environmental Protection Agency requires that a certified refrigeration technician recover the refrigerant charge before accessing the sealed system.
I hope this helped.
Maytag Skybox
good to hear another skybox lives...thanks for the kind words. alex
Dec 10, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
(Overload and relay switch)
hey Louie -- I had the same problem -- maytag is a waste of help unless it still is in warrant
you need to replace the overload relay --- the kit cost $26.00
go to appliancezone.com
part # 4387835
email me with any more questions
Dec 02, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox parts
you need the numbers off the compresser to get the BTU of it before that question can be answered. But your right this is a non replacement part (you cant buy it) it may cross but need cooling capacity first
Jul 28, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox Compressor
cant replace it it is a thow away model go to www.apdepot.com do a search for your model you will see here is the Service Manual check your email
May 05, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox MBV1976A Beverage Dispenser Logo
4,289 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Bailey's...
Bailey's...
Steve Allison
Steve Allison
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
