Question about HP Photosmart 3310 Printer
Ink System failure error message
I have an HP 3310 all in one photosmart printer which has failed. It was purchased in Oct of '05 & is out of warranty by several months. Prior to receiving the following error message:Ink System Failure Oxc 18a 0106 I had not problems with the printer. I used email HP support & did everything they suggested but nothing worked. I even searched on google trying resets suggested; held down OK, cancel, black & color buttons several times which caused machine to go thru OVM reset with machine then going thru device maintanence, but each time it then displayed the error message again.
  • GLevine Apr 02, 2008
    Same problem. Ink System Failure messaged received right after replacing magenta cartridge. Have only used original genuine HP Vivera cartridges in the machine. Followed steps of power down, remove and replace all cartridges, but did not help.
  • Rick Kasper May 11, 2010
    I think HP need to start refunding peoples money for those, I had the exact same issue. Talked and was online with them for hours. I finally just threw mine away.
    If you come up with an answer let me know. I have a couple of other friends with the same printer, same problem.
  • 4 Answers
Amigo, só para ajudar a divulgar aos usuários de Bulk. Se o código de erro 0xc18xxxxx ou 0xc19xxxxx do sistema de tinta da impressora HP Photosmart C6180 for exibido no painel dianteiro, faça o resete da seguinte forma:
1- aperte a tecla com sinal "jogo da velha" e o número 9. Segure as 2 apertadas ao mesmo tempo.
2- desplugue a impressora da energia,
3- ligue (com as teclas ainda apertadas) e espere uns 15 segundos até a impressora desligar.
4- Aí é tudo normal, liga novamente ela pede as configurações iniciais, configuração da linguagem, faz a limpeza e OK!
A tinta preta original da impressora C6180 é pigmentada e as demais corantes. Contudo para o bulk-ink é melhor utilizar só tintas corantes que possuem melhor fluidez, evitando entupimentos e problemas. RESOLVI O PROBLEMA DO MEU BULK-INK SUBSTITUINDO A TINTA PIGMENTADA - QUE VEIO COM O BULK - POR TINTA TIPO CORANTE.
Posted on Feb 01, 2009
  • 14 Answers
Refer to NateOcean's solution at http://www.fixya.com/support/t297123-ink_system_failure. My Photosmart 3310 also had the loose plastic gear problem at the ink pump. Seems that all the HP inkjet printers use the same mechanical system and that gear can just slip off over time. My printer was two years old. NOTE: You have to remove the black and white gear with belt to replace the white gear that slips off. Remove the belt first by slackening the tensioner pulleys. Then there is a very small white clip against the axel that prevents the large gear from being pulled off - lift the white tab carefully with something sharp and the gear should slip off easily. The culprit gear then just pushes onto the hex shaft.
This operation should be possible by just opening up the left hand side of the printer.
Posted on May 01, 2008
    Novelist:
  • 188 Answers
Hi Suzie,
Please click on the web link given below and perform the steps given in the web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&cc=us&lc=en&dlc=en&product=439491
For more information on this issue, you can contact HP chat support on the web link given below, Chat support is free of cost.
http://welcome.hp.com/country/us/en/contact/chat_1.html
Have a great day!
Posted on Mar 25, 2008
SOURCE:
Ink system failure
I have a message on my printer
Ink System Failure
ink system has failed -unable to copy, receive faxes,or print.
Refer to printer documentation
error Oxc19a0107
Feb 10, 2011 | HP Photosmart 3310 Printer
0xc18a0106 error from hp 3310 printer.... ink system has failed
That error code indicates a Ink system failure error message. Ink system failed mainly caused by your cartridge spitting extra inks into the copper contacts inside the printer. All you need is to remove all cartridge, clean the copper contacts at the back of it, clean also the contacts inside the printer (cartridge slots). Insert it back in after cleaning, unplug the power cord without turning off the printer, wait for 1 min before plugging it back in. Let me know the result.
Nov 23, 2010 | HP Photosmart 3310 Printer
Have a hp 3310 it says ink system failure error 0xc18a0106 it wont print,scan,copy and it does have enough ink. thank 4 ur help
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't clear the error then you may need to re-prime ink through the system to clear the error. There are good instructions for doing this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Feb 20, 2010 | HP Photosmart 3310 All-In-One InkJet...
I am getting an error message on my HP Photosmart 3310 as per below: INK SYSTEM FAILURE Ink system has failed. Unable to copy, receive faxes or print. Refer to printer documentation. error: 0xc19a0013...
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Nov 24, 2009 | HP Photosmart 3310 Printer
Can't print on Photosmart 3110 all in one
This is a result in a print head failure or the use of non HP ink ether or there right you need to service the unit part will be needed if the maintance does fail. If your using non HP ink stop its use and purchase HP ink you be glad you did!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 17, 2009 | HP Photosmart 3310 Printer
Error message oxc18a0001 ink system failure
Go to HP website, I recall some info there on this
Apr 25, 2009 | HP Photosmart 3310 Printer
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
Photosmart hp 3310xi - ink failure???
Perform the steps given in the below webpage and if the issue persists then contact HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00551397&cc=in&lc=en&dlc=en&product=439491#top
Jun 05, 2008 | HP Photosmart 3310 Printer
HP Photosmart 3310 Printer Logo
3,199 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
