Car Audio & Video Logo
Posted on Mar 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to know the functions to all buttons for
I want to know what the button with the letter ( s ) stand for the left button on the transmission stick .. and the other buttom on the top left by the sunroof button . it has a cone on it if you can plz let me know ..
Anonymous
Level 3:
Guru:
  • Master 513 Answers
  • Posted on Mar 22, 2010
Anonymous
Master
Level 3:
Guru:
Answers
513
Questions
0
Helped
214659
Points
1589
This is a car question.
I believe you are asking about the S-(shift) indicator button. A button with a pyramid is your emergency flashers.
A shift indicator button turns on the shift light when you are shifting the car to help you shift at the right time.
A flasher button turns on the four way flashers.
A better idea is to provide the model of the car, Auto or manual transmission and it year. A picture of the interior of the car could help, showing the buttons. This will help a lot. Thanks!
In the dashboard of my 1993 model nissan serena i noticed a button E-AT which alledgedly stands for electronic automatic transmission, may i know what is its function?
it acts like a( tow asst )is used under heavy acceleration by keeping the transmission in a lower gear longer for power and faster pick up
The LEFT KEY on my mouse is doing the functions of the RIGHT KEY (the drop down window) and the RIGHT KEY is doing the
Try going into the Control Panel and navigate to mouse properties. There is an option there to reverse the button functions.
I want to know how to use the function button
The function button, or FN button, is used just like the shift key or ctrl key. Hold the FN button down and press the key with the pre programmed function you desire to use. For instance, on an HP 1245 the function or short cut key to put the computer in sleep mode is FN+F5. The Keys with functions have that feature indicated by a symbol for the function in a squared circle. Most of these are your F keys at the very top row of the keyboard. Some are on the number pad keys.
1helpful
Is there a guide of how to use this calculator i do not under stand how to work this
Here's a link to a pdf of the manual. The basics are that you have 12 white keys near the bottom, which include the 10 digits, a decimal, and the negative sign. On the right, you have the four operating keys, division, multiplication, subtraction, and addition. You also have the Enter key which will solve the expression. You'll notice that the buttons have blue and green lettering above them, and those are for the 2nd and alphabet functions. So if you press the 2nd key on the top-left, then the on key in the bottom left, then it'll turn it off, because it also functions as the off key. The Alpha key is used to input letters which are in green above each number. Good luck!
On a Dell Inspiron 1525, what do the indicators between the Power Button and the Dell Media Button stand for?
enrqnclr+9vf0cbtxmmoud30eaaaaasuvork5cyii= Turns on when the numeric keypad is enabled.
v+wx0ewt9wgrugwqgtcaaaaabjru5erkjggg== Turns on when the uppercase letter function is enabled.
xiui1fdqaaaabjru5erkjggg== Turns on when the scroll lock function is enabled.
3helpful
2answers
Dont know what button on dashboard that is lettered ETC DOES on a1996 toyota rav4
The ECT button (which stands for "Electronically Controlled Transmission")
changes the shift points for the automatic transmission. When engaged,
the transmission shifts later, allowing the engine to get to a higher
power level and accelerate faster. Gas mileage is usually reduced in
this mode. Use it when you need to get up to speed faster; for example,
to merge into fast moving traffic. The normal position for this switch
Hope this help (remember comment and rated this post).
is OFF.
MSIU100 Built in webcam? How do I start it?
Generally in notebooks, there is a function button, can be seen as "FN", on the left bottom corner, either on the left of the "Ctrl" button or on the right of it. You can press and hold that button, then while holding it you can find the "F#" (# is from 1-12, but you should find the correct one with a small webcam icon on the top of it, and you should only press that one) button that stands for webcam function and press it while pressing the "FN" button. Doing this process again will close that function again. And when you open the webcam, you can test it simply by going into "My Computer" folder.
9helpful
Automatic transmission "s" and "w" buttons
Hello there.
The W/S mode button stands for Winter and Standard. Winter mode increases torque and thus adherence when starting. I believe that under normal conditions, standard mode is to be prefered as it improves acceleration and makes the ride more comfortable.
The ACR button inhibits the electronic drive assistance. This again might be necessary when driving under certain winter-conditions (snow, ice), but should normally be let active.
Hi im jen , can u help me to fix my screen laptop acer 5100 i need to adjust the brightness but i couldnt find teh settings where to adjust it
Hold down the function button and press one of the arrow buttons (probally the 'up' button). The function button is the one with the letters 'Fn' on it, on the left side near the bottom.
Good luck, and please rate my answer.
Letter key button on my acer aspire laptop does not function
with a compressed air can be sure to clean everything inside the keyboard.
Let me know if it's enough and don't forget to rate the solution.
thanks
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
