Question about Nokia N95 Cellular Phone
On and off
When making a call it turns off and turns on then goes into searching mode then it goes off. Please assist
  • 85 Answers
Check ur battry and flash ur set from technician
Posted on Mar 16, 2008
I have a LG 22inch LCD monitor it goes on but only stays on for about 5 min then turns off. If I press the power button it goes on but now only stays on for about 15 seconds please help
First of all, you need to detached the monitor power connection and re-attached it after 5 minutes and check if the monitor works fine.
If issue persists, you need to make sure if any custom settings are made for monitor display power saving mode. To help you find these, please follow the steps mentioned below:
- Click the Start button. Select 'Control Panel' from the Start menu pane.
- Type 'power options' into the search box. Click 'Power Options'.
- Click 'Show Additional Plans' in the 'Select a Power Plan' section.
- Click and enable the 'High Performance' radio button.
- Select the blue 'Change Plan Settings' link next to the High Performance setting to open the plan settings editor window.
- Change the setting beside 'Turn Off Display' to 'Never' under both the 'On Battery' and 'Plugged In' headings. Change the setting beside 'Put the Computer to Sleep' to 'Never' under both headings.
- Click 'Save Changes' to implement the setting.
If issue persists, it is recommended to contact LG Support Center for further assistance from the link given below:
http://www.lg.com/us/support
GuruAid.com
May 08, 2016 | LG Computers & Internet
HOW CAN I ENTER SERVICE MODE? ANYBODY PLEASE.
Without knowing what make and model you are referring to, it is very difficult for the volunteer Fixya experts to focus in on the problem and then assist you.
Google search your manufacturer make and model and the words service manual. If one is available, you can find it in the search results.
Apr 21, 2015 | Office Equipment & Supplies
Screen remain only on for about 2 seconds than goes blank
Many cameras have a power save mode that turns off the screen (to reduce the power drain on the batteries), check if your camera does this, Please post you make & model for further assistance.
Ron
Apr 20, 2012 | Sony Cameras
Im havn a problem with connect it to my HTC Hero. I lost my instruction an just need a little assistants
Try to put your headset in pairing mode, prior to trying to pair it with your phone. To do it, begin with it turned off. Then, if it is the first time it is being paired, just by turning it on (i.e. by pressing and holding the call button for some 2 seconds), it should enter the pairing mode. Otherwise, keep holding the call button past the turning on phase (a total of some 8 seconds), until its indicator light is flashing in red and blue, thus indicating it is in pairing mode. Either way within the next 2 minutes, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode.
By the way, if its user guide happens to be missing, feel free to download it from this location.
Please, let me know if I can help you any further.
Regards,
Carlos
Mar 06, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Having trouble pairing
Have you already tried to put your headset in pairing mode, prior to trying to pair it with your phone? Anyway, starting with it turned off, press and hold the call/end button, as if you were turning it on, but now don't release it until the indicator light is alternately flashing in red and blue (some 8 seconds). It is in pairing mode now. Then, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (indicatior light flashing in blue).
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out soon.
Otherwise, please, let me know if I can assist you any further.
Regards, Carlos
Jan 04, 2011 | Jwin JBTH130 Bluetooth Headset
I have a motorola blue tooth and I need to pair it to my htc evo.... How can I do that?
Ok, I'll give you a default procedure to put a blueetooth headset in pairing mode: starting with it turned off, press and hold the call button as if you were turning it on, but keep pressing the button until the indicator light is either steadily lit, or flashing rapidly, sometime in more than one color. This is usually achieved by holding the button down for some 6 to 10 seconds. Then, make your phone's blueetooth application search for new devices. After a while, your headset should appear on-screen. Make the application connect to it. If a pairing code (or passkey, or PIN), is requested, enter '0000' (four zeros). If the pairing process is successful, your headset's indicator light should flash some times, and enter the stand-by mode (normally flashing every couple of seconds). Your phone should also indicate that a headset is connected. However if the pairing process fails, after a couple of minutes your headset will quit the pairing mode, Turn it off, by pressing the button until the light goes off, and start the whole process again, firstly trying '0000' one more time, then changing it either by '1234' or '8888',
Hope you are able to sort your problems out soon, but, please, let me know if you further assistance.
Regards, Carlos
Sep 14, 2010 | Motorola Mobility Bluetooth Hands Free...
Radio goes into search mode when selecting pre-set stations
it is merely making the exact set connection
Aug 27, 2009 | 2006 Volvo S60
LXI tuner not working
Unfortunately without the make and model, there is little that we can do to assist you. There are too many tuner designs to be able to give you any useful information. Please try the unit in mono mode and with any "muting" turned off. If you receive stations with the muting and stereo modes turned off, the problem is with an I.F. amp stage. If you receive nothing, that is informative as well.
Please investigate a bit more and post the make and model and I should be able to assist.
Thanks,
Dan
Mar 13, 2009 | Audio Players & Recorders
New digital box from comcast, codes listed not work for their remote, search mode turns no code either. TV model #CM19022S, Serial #3CDT703826H assembled July 2002...don't if it comcast box or tv....this...
Hello!
I'd be happy to get you in touch with the right team to assist you with your remote. Please email our team at We_Can_Help@cable.comcast.com.
Regards,
Melissa Mendoza
Comcast Customer Connect
National Customer Operations
Oct 09, 2008 | Televison & Video
Continuous Channel Searching & Power Button Issues
What source are you using? If cable, you should only be able to pickup channel 3 or 4 if you're using the box. If there is no antenna, that would be the only other answer if the set checks out...accordianman
Mar 20, 2008 | Audiovox FPE1078 7.8 in. TV/DVD Combo
Nokia N95 Cellular Phone Logo
26 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
