Question about Yamaha Audio Players & Recorders
Motorcycle i have a 1988 fz600 motor cycle and ive have had it to bits to respray and engine overall and when i put it together it started first time and for the next 3/4 times after that ticked over lovely and then it stoped dead and i have no spark to the plugs, changed the spark plugs and the coils and nothing tryed 2 other cdi units and nothing,tryed also the pick ups and a new battery,we have also changed the brushes in the altonater nothing changed and cheacked the wiring loom and handel bar swicth, tested the omhs from the alternater and brushes and they where fine and still no spark fuses fine redone earth lead and live leads still no spark, engine turns over still nothing help
    Problem Solver:
  • 5 Answers
Try the ing. switch
Posted on May 01, 2010
I have a lexmoto xtrs 125 2012 the starter spins fine now Ive cleaned it up. I benched tested spins fast and free. And I took the plate of the engine opposite starter motor. Chogs all good . Seems like...
put the starter motor back together wrong
dc motors are polarity sensitive so reversing the main power wire will reverse the rotation of the armature
Jun 16, 2017 | Motorcycles
Carb adjustment screw idle
Hi, Anonymous for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1987 Yamaha FZ 600 Where is the idle control located Google Search
86 fz600
Yamaha FZ600 1986 1988 Workshop Repair Service Manual PDF Download Manuals... $10
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Dec 29, 2013 | 1987 Yamaha FZ 600
Engine light flashing
The flashing lights are a code. go to a Yamaha dealer and they will tell you what the cause is.
Apr 25, 2013 | Yamaha WR 125X Motorcycles
1988 GMC pickup 4x4 350 engine its hard starting and will not idle i gave it a full tune up even a new fuel filter ive checked and changed all sencors on the motor
Do a compression test. The pistons and rings may not seal enough anymore. Try push-starting it in 2nd gear. When you push it ,it will turn the engine faster and build up more compression, enabling combustion to take place. Aslso check if the fuel pressure regulator is not leaking through the vacuum hose, causing it to flood.
Apr 30, 2017 | 1988 GMC C1500
1988 honda shadow vt1100, wont start, put new battery, new starter solenoid, new brushes in starter, solenoid clicks when I go to start it but nothing happens, fuses are fine. What is happening?
Hi, sounds like you are getting insuficiant power getting to the starter, assuming you have checked the engine turns over freely and is not seized, the switch circuit you have proved is working (as the clicking noise at the solenoide indicates this) as the solenoide switches the battery power to the starter motor, i ask myself if either the battery is suffiantly charged, or the leads from the battery to the solenoide/starter motor and earth leads are making good contact,
At the solenoide join together the both leads bypassing the solenoide using a pair of insulated pliers and the engine should turn over if the battery contains 12-14 volts, this can be done either with the ignition switch in the on/off position when ignition is off the engine will turn but will not start
Sep 04, 2011 | 1988 Honda VT 1100 C Shadow
Doesn't start up , and oil light is on my 1986 yamaha fz600
The oil light wont go off until there is oil pressure ie: it has to start first.
" Doesnt start up" is not really enough info to offer any ideas,
it has an oil light so the battery has some voltage.
Does the starter motor turn it over?
What happened when it stopped?
When did it last run?
Has it sat unused for a long time?
Will it roll start?
When was it last serviced?
Apr 18, 2011 | 1988 Yamaha FZ 600
1988 Buick Century, not getting gas
by pass relay to see what happens.
Apr 05, 2010 | 1988 Buick Century
Engine wont turn over from starter motor...
my dad works for a starter and alternator repair shop, and as for the solenoid clicking really fast, means that battery is to dead, one click and no movement of starter also in dicates low baterry or starter is stuck in a "dead spot". have you taken the staret apart?? if so , were the brushes longer that 3/8 of an inch? and check the internal grounds, sometimes they get loose. my email addy is ryan_78_ohearn@hotmail.com. if u have any more questions or for more details, e mail me and i can help ya out.
Mar 20, 2009 | 1988 Yamaha FZ 600
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
