Question about Panasonic CT-32HL43 32" TV
Keeps blowing fuse
I have a Panasonic CT-32HC43 TV. Recently it started blowing the fuse on the board when I turn it on. Been trying to find an answer to the problem. Can you help, please. Thanks.
Ron
  • Anonymous Jul 02, 2008
    portable CRT television keeps blowing power fuse.
    Scholar:
  • 104 Answers
It has a short circuit somewhere...
Not sure if this is a CRT, LCD or Plasma TV but the two common causes of shorts for CRT's are the Horizontal Output Transistor (HOT) and/or the Flyback Transformer (Could be both). As a general rule if the flyback has visible cracks in the case they should be replaced. It is also a good idea to replace the HOT if you're replacing the flyback as it could be weakened and may not last much longer itself.
Other areas to check for all types would be any Diodes in the Power Supply Circuit. If a diode is open it can cause the fuse to blow. Note that a diode itself will not short, but an open diode can cause a fuse to blow.
Posted on Mar 12, 2008
Where is the fuse on a Panasonic CT-32HC43. It just won;t turn on. It was working great and then nothing.
The fuse is located on the power supply board. It looks like a small glass tube with metal caps at both ends like the ones in the image below on the board next to it you will see a small marking that says the specifications of the fuse. Ex: 10A(Read 10 Amperes), 120V. The replacement you are gonna purchase should be of the same specifications. Make sure you unplug the tv from the power supply before replacing it so that you will avoid the risk of electric shock.
A positive rating for the advice provided will be highly appreciated and I will be glad to assist you further if you need more help.
Sai.
Mar 29, 2010 | Panasonic CT-36HL43 36" TV
My panasonic tv went out this morning. it's a ct-32hc43. The picture is fuzzy and the tv shuts off after only being on for a minute. Are there any troubleshooting tips anyone can offer?? Please Help!!!!!
Ur hight voltage FBT,the flyback transformer is dead.The big block of plastic with a red wire with a cap that hook to a CRT.U know how to solders?Replaced the FBT well solved ur problem.But the FBT it hard to find this day,because tv compannies don't manufactures parts small CRT tv anymore.Ur only luck is find it on Ebay.com.
Feb 12, 2010 | Panasonic CT-32HL43 32" TV
Panasonic CT-32g19j
check The B+ of your tv. If no b+ Check the input AC voltage. If Ac i/p are ok but no B+ Volt maybe your IC in power supply has problem.
Jun 01, 2009 | Panasonic CT-32SL14 32" TV
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Won't turn on
Once you take the back off there is a glass gma fuse withing a few inches of where the power cord plugs into the board at. This should be a 6.3 or 6.5 gma fuse. Very common to blow in your model because the degausing coil is a little to big for it. There are other reasons for it to blow but 99% of the time you change change it and the set will work again. Let me know if you need more help or info!
Tim Nolan
Sep 11, 2008 | Panasonic CT-32HX41 32" TV
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Won't turn on
Follow AC cord in to clip-in glass fuse....replace with SLOW
BLOW 6.3 amp ( T-type) Panasonic factory correction...T.
Dec 19, 2007 | Panasonic CT-32SX31 32" TV
Checking the 6.3a slo-blow fuse
if you open your tv , you have to put back the board, there are 2  clips
one on left other in the right that keep the board to the case of tv( you have to disconnect  the cable AC before open the tv)
you can see the fuse easely ( if  i remember good there is only one
fuse about near the switch on /off
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
Tv will not turn on
This set has a common problem with th main fuse opening for no other apparent reason... One of the few exceptions to my corner-stone statement that a fuse is never the cause only a symptom..
Don't replace it though with the same type grade, use a 6.3a slo-blow gma type - available at Radio Shack... Try that and if everything works you're back in business.. If not we nee to find a cause...
Bill
Fuse blows.
Please check for shorted diode or condenser at power section.
May 29, 2006 | Panasonic CT-27G14 27" TV
Panasonic CT-32HL43 32" TV Logo
247 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
