Question about Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop
No power WHEN THE COMPUTER IS TURNED ON THE GREEN LIGHT IN BACK WILL COME ON, BUT WHEN YOU PRESS THE POWER ON BUTTON IN FRONT THE LIGHT GOES OUIT AND THE SCREEN STAYS BLACK. WHEN THE SCREEN WENT BLACK IT WAS ON AND WORKING. IT MADE KIND OF A SNAPPING ,CRACKLING NOISE AND IT WENT BLACK. WOULD THAT BE THE POWER SUPPLY AND IF SO, HOW WOULD YOU ORDER ONE? FINDING THE CORRECT NO. ETC. THANK YOU
COMPAQ SR1103WM POWER SUPPLY CONNECTION TO MOTHER BOARD. THE PLUG IT SELF.I PLUGED AN UNPLUGED THE 24 PIN CONNECTOR TILL THE GREEN STAYED ON ON THE POWER SUPPLY. MAYBE SHORT ON MOTHERBOARD STANDOFF. TRY AT OWN RISK.
Posted on Sep 05, 2008
  • 68 Answers
Hi Emjo,
Did I understood correctly?
1. You turn on the main switch and the indicator come on (shows that there is electricity present)
2. You push the power button than electricity indicator went off.
- On this position, screen is black but computer is working.
- Than a noise heard and its turned off?
Is that the situation?
Except the part of "the noise" thing, it seems like your PSU (power supply Unit) faulty.
But the noise is another issue; generally, computers have few noise sources; all moving parts, namely, cooling fans and hard drives.
I suggest check your fans first.
There should be one for CPU, one or more mounted on back and front panels (sometimes they mounted on side panels/doors -depending on the type of computer case) sometimes little fans on graphic card and main board. And the one big fan generally located inside the PSU, but I dont recommend to deal with it, instead of trying to fixing internal fan of PSU, it is better to change the PSU with new one.
Next source is hard drives. If the noise characteristics is more mechanical like metal to metal knocking, like a hitting a metal box with a little hammer, if so, this is bad news. But there should be another symptoms accompanied with this like freezing moments etc..
Warning: Safety first.
And be careful what you do, there is high power on PSU, and there maybe a leak, check first if there is high voltage on the case or not(with a voltmeter).
Before to attempt to open the case of your computer, its better to ground yourself first with touching with one hand on the bare metal of the case to avoid static shock on electronic parts.
Back to PSU, you can find a data plate/sticker side of your PSU. Check the specifications and order new PSU from your local dealer. I am sure you can find many source to buy on the internet as well.
PS: If you use many USB devices and few hard disk, you can consider to buy higher wattage PSU.
Good luck & Regards
-halotheracer-
Posted on Mar 12, 2008
  • 4 Answers
Press the num lock key light .....
if the light doesn't blink Ram is the fault...
Remove the Ram and Take white Eraser and clean Ram pins and
fix the ram .. Mostly it will work....
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
Computer wont turn on
Make sure the tower is getting power. There will be a green light on the back of the tower where the power cord goes. Make sure the cord is snug and that it is securely plugged in to your power source - I'm hoping it is a power surge strip and in which case, make sure the surge strip didn't get unplugged or turned off. If you have it plugged directly in to the wall then make sure that outlet has power by plugging something else in to it that you know works. After doing all of this, make check to see if there is a light on the back of your pc. If not, unplug the power from the back of the tower, wait 30 seconds at least, and then plug it back in. Hit the power button on the front just once, if it doesn't power up, press and hold the button in for a 2 seconds and release. If that doesn't work, your power supply may have gone bad. That happens from time to time. Good luck, hope this helps!
Jan 20, 2013 | Thermaltake Computers & Internet
Printer error 5200
Well it seems like the waste ink pad error. You can override it but it will need changing or the printer will leak ink from the pad eventually.It needs a service now and the waste ink pad changing but you can reset it yourself by following some simple steps -
1. Plug in the power cord of printer.
2. Press Resume button 2 seconds then press the power button until the green light on (when pressing the power button, Resume button).
3. Then release the resume button, but do not release the power button.
4. While the power button is still pressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange.
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow green.
7. And the computer will detect new hardware, just ignore
8. Press the power button again then the printer will flash.
Check your printer again now it's ready.
Regards
May 07, 2012 | Canon PIXMA MP610 InkJet Printer
No power to my desktop computer HP A1330N and no green light in the back of the power supply
You replaced power supply and your made sure you plugged everything back into the motherboard snuggly and in it's proper place? If so it might be your motherboard is bad.
Make sure you have the new power supply turned on. Sometimes there's a O/I switch on the back of the power supply. Flip it and try to boot and see what happens. You might have another bad power supply.
If so your motherboard might be burning them out.
Try removing the power cord for 30 seconds and press and hold the power button. After 30 seconds put the power cord back in and press the power button to see what happens.
Do your fans work when you press the power button? Do you hear any fans running?
Mar 23, 2012 | Computers & Internet
HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-43507-1&lc=en&dlc=en&cc=ca&lang=en&os=228&product=1841849 and restart the computer .
Apr 15, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
Power goes green then back to standby
It sounds like this one needs component-level troubleshooting, probably in the power supply section.
Dec 29, 2006 | Mag Innovision LT765b 17" Flat Panel LCD...
Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop Logo
234 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
