Question about Brother P-Touch 2200 Thermal Printer
Labels are not printing correctly
Our Brother P-Touch 2200 is starting to stall a little bit while printing make some of the text squished together. For example, "Fisherman Life", Fisherman may print out fine, but then the "I" might be squished with the "F" in "Life". We thought the batteries were running low and it did not have enough power, but we tried all new batteries and it still prints like that. I also tried cleaning the rollers. Any suggestions?
  • Mary Lou W Mar 19, 2008
    I have exactly the same problem. I started using the power cord instead of batteries - problem still there. Sometimes it gets better when I change the font to Brussels.
Brother P-Touch tape label maker doesn't print right.
I believe it's a faulty tape. I put in a new tape, reset the machine and it's now printing fine. It wasn't the reseting - I tried that before.
Posted on May 21, 2008
P touch QL 560 wont work with new paper
brother touch ql 560 Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on brother touch ql 560 related issues. ...i just set up a new computer with the vista windows and i have a brothers ql-500 p touch the install disk will not work with the vista what can i do go ... QL 550 won't print I have a Brother PTouch QL550 that won't print anything on the label.
[PDF]Creating Labels - Top Edge Engineering
www.topedge.ro/info/USER-GUIDE/.../OL-500-560-650-1050.pdf
pe nd ix. Software User's Guide. QL-500. QL-650TD. QL-560. QL-1050/1050N ..... This manual describes how to create labels using the P-touch Editor software .... want to create a new label layout or open an existing label. .... When this check box is not checked, labels won't automatically be cut ..... Used to select the paper.
Oh Brother! - Compatible Brother Labels saving you money
www.ohbrother.co.uk/
Compatible with Brother P-touch QL-500, QL-550, QL-560, QL-570, QL-580N, ... Thermal Quality Grade A Paper with Strong Adhesive and Sharp Print. ... Oh Brother! you won't find Brother replacement labels any cheaper on the internet.
brother QL-560 - Oh Brother! - Compatible Brother Labels ...
www.ohbrother.co.uk/index.asp?search=QL-550
Feb 03, 2016 | Office Equipment & Supplies
Why is the text printing on Zebra LP 2844-Z label incorrectly spaced?
Zebra printers are not really made to print PDF files, if the only option is PDF I'd recommend switching to print on a laser. Also open the PDF and see if they are correct in the original doc
Oct 06, 2015 | Zebra Office Equipment & Supplies
Brother p touch 1100/1800
Often a label printer sticks after a lot of use, especially if you have had a jam. Remove labels and preferably with a vaccum cleaner clean out any dust and bits left in. Turn it upside down and try again.
Then try printing a 'blank label' with no labels in and see if the motor starts. There may be a sensor that prevents this - if so clean sensor
Mar 08, 2014 | Office Equipment & Supplies
Instructions for brother p touch 1000
Instructions1 Turn on the device by pressing the power button. If this is the first time that the machine is being turned on, select a language with the arrow buttons and press the return button. Select a unit with the arrow buttons and press return. Set the date and time with the keypad and the return button.
2 Type in the text for the label using the keypad. Correct mistakes by pressing the "Backspace" key and retyping. Press the return button when the text is ready.
3 Select the appropriate styles and features for the label. The device will provide you with a wide range of choices for the size, style and width of the text. Simply select which feature you would like with the arrow buttons and press the return key to move on to the next option.
4 Print the label by pushing the "Print" button. Make sure there is paper in the device. It may be necessary to press the "Feed" button to align the label within the device. Print as many labels as necessary. To erase the text, simply press the backspace button until the text is gone.
5
Turn off the device by pressing the power button.
Mercedes Custom Parts
Jun 06, 2012 | Brother Office Equipment & Supplies
Too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Jan 04, 2010 | Brother P-Touch 1180 Label Printer
Printing envelopes
Open a MS Word Document, select 'Tools' then 'Letters and mailings' then 'Envelopes and labels...'
Envelopes and Lables dialogue box opens - ensure you are on the 'envelopes' tab
Then type your recipient address in the larger white box
for standard letter envelope (DL 220m x 110mm) - Insert envelope into Brother HL-2030 manual feed, with print side up, gummed flaps down and to the left side (bring gray plastic guides in close to secure).
Then select print.
I have found that during the feed, one end of the envelope gets a little bit crumpled but overall it's still a little bit more professional looking than my handwriting.
Jan 12, 2009 | Brother HL-2030 Laser Printer
Ptouch weak printing
You need to take a q-tip dipped in alcohol and clean the printhead. Let me know if this helps.
Lou
Sep 09, 2008 | Brother P-Touch 1180 Label Printer
To reset brother p-touch 1000 e-mail lmtheron@icon.co.za
Hi - You can download the manual by clicking the link underlined in blue below:
PT1000
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Jun 13, 2008 | Brother PT-1000 Thermal Label Printer
Brother P-Touch 2200 Thermal Printer Logo
363 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
