My HP C4180 printer won't print.It will make copies but won't print self-test report. There are two small icons at the bottom left of the printer screen; but they are so small I can't make out what they are. I have been printing regularly until this past Sunday when this occurred. I have checked all connections and they are secure.
  • 3 more comments
  • richhow Mar 11, 2008
    I have only tried to print the self test page from the printer and I can't get it to work. I jsut noticed something else (not that it means anything but the screen on the printer used to stay lit the whole time the printer was on. Now it goes dark if not used after a sort period.
  • richhow Mar 12, 2008
    The jobs get stuck in the queue but I delete them before trying again. There are no flashing lights or other signs.
    I have checked the ink cartridges. They are OK. I have switched the USB cable to another port with no results. Can a cable go that quickly? It had not been touched since operating OK.
    Nothing happens. It does not grab paper. The printer screen shows "Print Report" Self-test Report".
    Just where do I get another cable compatible with this printer?
  • 4,889 Answers
  • 13,433 Answers
Hey, lets see.
First, have you tryed to print from your pc? Do the jobs get stuck in the job queue?
Do you see any error messages or are any lights blinking?
Posted on Mar 11, 2008
  • 818 Answers
1) check the usb cable is conect corretly, exchange it for see it works. 2) see also if you have termineted the ink of the printers.
Sergio
  • 2 more comments
  • Sergio Scalfaro
    Sergio Scalfaro Mar 12, 2008
    for me his your cable, change the port of usb where you conect the printer and see if work.
    Sergio
  • Sergio Scalfaro
    do you have the possibility of printer in other computer for see this?
    it's important. if not work you must exchange the cable.
    Sergio
  • Sergio Scalfaro
    can you exchange the cable?
    Sergio
  • Sergio Scalfaro
    you can buy from your vendor of your printer. no cost very much.
    Sergio
    Master:
  • 555 Answers
Manuals and new drivers for your printer can be found here.
If you try to print a self-test page from the printer itself via the control panel, and it fails, then it doesn't seem like a driver issue.
What happens when you try to print a self-test from the printer itself?
  • 1 more comment
  • Matt Jurach
    Matt Jurach Mar 11, 2008
    What exactly happens when you follow these steps to print a
    self-test page?
    1. Press
      Setup
    2. Press
      or
      until Print Report
      displays, then press
      OK
    3. Press
      or
      until Self-Test Report
      OK
    Does it just do nothing? Does it try to grab paper, and then stop? Or can you not even get to that menu item?
  • Matt Jurach
    Arrows didn't render. Should be:
    1. Press
      Setup
    2. Press <
      or >
      until Print Report
      OK
    3. Press <
      or >
      OK
  • Matt Jurach
    Matt Jurach Mar 12, 2008
    It's not the cable. You're right- cables don't just up and die, especially in such a short period of time.
    If your printer will not do a self-test page, the problem is clearly internal to the printer, not between the printer and your computer.
    You should try resetting the printer.
    1. Make sure that the unit is on, and unplug the power cord from the back of the unit.
    2. Wait 30 seconds
    3. On the unit keypad, press the OK and the Help keys simultaneously and hold both keys down while plugging the power cord back in.
    4. The Semi-full Reset message will appear on the unit display.
    5. Wait until the unit initialization process is complete. The unit will have recovered its original settings.
    Genius:
  • 3,587 Answers
My 2175 All-In-One printer will not print a document from my computer. The LED readout says "1 Copy / 100%". The push-button "copy" icon is lit up. It will print a "Self-Test Report" OK. I have...
Check to make sure that when you give the print command that the HP 2175 is the printer the document is aimed for...not XPS or some other printer on your system.
good luck
Feb 22, 2010 | HP PSC 2175 All-In-One InkJet Printer
Screen showing the message "remove and check right cartridge". Have done this several times and still can't print
I've had the same error:
Hold down the following keys:
Photosmart Express, Photo Fix, Reprints, Print Photos and then Help.
You'll get the message: "Enter Special Key Combo"
Press OK.
Scroll over to Reports then self test: and press ok, it should print. a selftest report.
If you get an error Pen in Chute 1, or 2, has tsr failure: Call/Chat with an HP technician.
Jan 19, 2010 | HP Photosmart C4180 All-In-One InkJet...
Where is the serial number on an HP Officejet J6480 All-in-One printer
Usually the serial number can be found either in the back or in the bottom of the printer.
If your printer is working you can print a self diagnostic page which would have the serial number.
To print the Self-Test Diagnostic Page
• Device control panel: Press Setup, select Print Report, select Self-Test Report,
and then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print a Test Page.
Sep 09, 2009 | Office Equipment & Supplies
Won't Print and says that it is out of paper
Hi Salson !
Salson, you have only mentioned that the printer won't print, but plz be clear about the issue, so that I can help you in the best way.
If you are receiving an error "Out of Paper" on the printer, then it will considered as a Hardware malfunction problem. If it on your computer (Under the printer icon) then it will be a software issue.
However, to check the hardware functionality of the printer, perform the below steps on the printer to print a self test report.
By looking at the pic of the printer, it seems that you are using PSC 2500 printer, so perform the below steps on the printer itself.
On the front panel of the All-in-One, press Setup then press 1 and then press 4.
It will work for both
HP PSC 2400 seriesHP PSC 2500
If you are unable to print a self test report, then try to make a copy from the front panel of the printer, by placing a text document on the scanner glass and then press color copy button.
If the printer prints a test report or makes a copy , then it confirms that the printer is working fine. The issue is with the software part.
If printer fails to print and then error message displayed on the printer LCD screen, then perform the steps given in the blow link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00786157&cc=us&lc=en&dlc=en
The hardware issue may or may not be resolved. Hoewever, if the error message is on your computer, then try to run the print diagnostic utility if the printer is connected to the computer via usb cable and check for the result.
Here is the web link to donwload the print diagnostic utility.
ftp://ftp.hp.com/pub/softlib/software10/COL21389/mp-56143-3/IJS_PDU0104_NN_W32_U_WW.exe
Hope this will helps you.
With regards.
Mike.
Jun 29, 2009 | HP PSC 1610 All-In-One InkJet Printer
Printer not printing
check to make sure cables are securly fastened and if it's a laser printer make sure it is set to online mode and not offline mode. Check to make sure not out of toner or ink. Make sure no other print jobs are in the way, Reset the printer. Try a printer self test and make sure the settings on the printer and computer are both set to the same. If none of this works you might have a hardware problem that needs to be fixed. if you have a warranty on the printer call the warranty company as they will fix the problem for you.
Mar 02, 2009 | HP Officejet 6310 All-In-One InkJet...
HP All-In-One Printer
I think that the Drivers have failed to communicate.Just try the steps below.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP Photosmart c4100)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Mar 12, 2008 | HP Photosmart C4180 All-In-One InkJet...
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
Slow Printing
Hi, The slow printing issue can occure even if the cartridges are out or low in ink try to check the print function by the stand alone unit by printing a self test page Here are the steps to print a self test page: On the front panel of the product, press Menu (or Setup) . Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK . Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK . If the self test page takes less time to print and if all the color blocks and black block print fine the ink level are fine. if the time for self test is also more try to clean the cartridge contacts and replace the cartridges if needed this will fix the issue. If the printer works fine as stand alone self test and copy try to performe the steps in the below webpage: ========== http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00093466&lc=en&cc=us&dlc=en&product=2512010&rule=10185&lang=en ========== If the issue is still un fixed try to set the print directly settings in the printer properties Click on start >> control panel >> printer and faxes >> there look for the HP printer icon with the check mark and right click on it and select properties and then click on advance tab and under it select the print directly to printer and click on apply and ok to save the settings. Once done try to print and check with the issue. Hope this will fix the issue. Regards, Barret.
Sep 03, 2007 | HP PSC 2175 All-In-One InkJet Printer
Computers & Internet Logo
127 people viewed this question
David Payne
David Payne
