Electronics - Others Logo
Joseph Hwang Posted on Mar 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jsph just asked: how do i unlock my file which i filed in my USB were write protected? and I don't remember where did i get or copy the protected file. can i reformat the whole USB unit of 8G? and delete the all files inside.
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 113 Answers
  • Posted on Mar 23, 2010
Anonymous
Expert
Level 2:
Mentor:
Answers
113
Questions
0
Helped
30867
Points
300
Before formatting you can try an option of dowmloading "Jet flash recovery' tool from transcend website and recover the files.
Please come back and rate my solution if it turns to be helpful for you. Thnx
I forgot my SD card password.
Problem with the Removable Media
  • Open it with linux OS...tried with Ubuntu 10.10
  • The steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, http://fexplorer.en.softonic.com/symbian/download#pathbar
2. After finished downloading, install it to your mobile phone.
3. Insert the mobile memory card into your mobile phone. Remember, don't access the memory card through phone at this moment.
4. Run FExplorer and open the following location C:\system.
5. From the location C:\System, you will see a file named as mmcstore. Rename this file as mmcstore.txt.
6. Copy the file mmcstore.txt. and paste it to your computer. Now, open that file in notepad.
7. When you finished the above steps, you will find the password of that file
  • if above option will not work the sd card have to be formatted by Nokia n series mobile....it will be helpfull
When I copy file from computer to USB, the message is the disk is write-protected. How can I remove the write protection
Might have to reformatt it:
http://www.quickonlinetips.com/archives/2005/08/fix-format-usb-flash-drives/
If you're on a mac go applications -> utilities -> disk utility and reformat it from there
Should be fine after that!
Remember to save all the files from it first!
Hope this helps!
When trying to format,copy files into flash,deletinf files,i get the message "remove write protection". so how can i remeve it?
One of two things:
Either your flash drive/card has a hardware copy protect on it (usually in the form of a little tab) Just be sure that it is turned off.
Or
You've somehow managed to tick the "read only" box on your files. Highlight the files, right click, go to properties, and unclick the checkbox for "read only". This may have to be done as administrator.
I'm really opting for the first one, Most people don't realize that their card or stick has copy protection on it and wonder why they can't delete files.
If nothing else works, you can always use a software program called unlocker - http://www.softpedia.com/get/System/System-Miscellaneous/Unlocker.shtml
It integrates into windows explorer and allows you to delete files in use, locked files, etc, etc.
1helpful
I forgot my memory card password Nokia 5130, how can i unlock it? Help me please :((
Your can store your personal information or documentation of your mobile memory card. To protect your files or documents, you need to give a password on the memory card. It's a common mistake of human that most time they set password and forget that password. So, what to do then? Do you need to contact the mobile phone service center? It's a costly solution. Moreover, you have to spend enough time and effort to do that. All the peoples do their best to unlock the memory card and to recover the data. It's really a great annoying thing. But you can do it by yourself very easily. You just have to follow some steps to unlock your password protected memory card of your mobile phone. This page tells you the process of unlocking any password protected mobile memory card.
Steps to Unlock a Password Protected Memory Card of Your Mobile Phone
1. To unlock your mobile memory card, you need a file explorer. You may use FExplorer. To download FExplorer, click here to download.
Do your own risk..don't blame me try this links-
http://hubpages.com/hub/How-to-Unlock-a-...
http://www.mobilecubix.com
Apr 30, 2011 • Cell Phones
1helpful
I forgot my memory card password.i want to unlock it.my phone model is Nokia 2700Classic.plz help me.
Steps to Unlock a Password Protected Memory Card of Your Mobile PhoneThe steps to unlock a password protected memory card of your mobile phone, is described below. Please follow the steps:
  7. When you finished the above steps, you will find the password of that file.
Feb 15, 2011 • Cell Phones
2answers
How can unlock memory card
Rate me if this is helpful. Good Luck :)
1helpful
How to unlock memory card
I have seen such a case when one my friend forgot the password of his memory card of his mobile phone and he have some very important data in the memory card which he want to recover, he tried almost everything then he lost hope and then asked the mobile phone company to find the way to recover the data from the memory card. But you don?t worry if you are having the same problem?as now there is a much simple and easy way out. Requirement: You need a file explorer like FExplorer that u get from www.google.com Read more: http://www.mobiletipstricks.com/how-to-unlock-the-password-protected-memory-card-of-your-mobile-phone/#ixzz0QGFLtxQP Method 1: Insert card into your phone but don?t access it through phone. Run FExplorer and Open the path C:\system. You will find a file called mmcstore ,rename the file mmcstore.txt Copy that file(mmcstore.txt) to your pc and open that file in notepad. You will find your password in that file. Read more: http://www.mobiletipstricks.com/how-to-unlock-the-password-protected-memory-card-of-your-mobile-phone/#ixzz0QGFWvvU6
66helpful
5answers
Unlock code for huawei eg162g usb modem
idea uses huawei eg162g data card to unlock this you need to edit the deviceinfo.xml file
go through it and where ever it is written "<item name="WCDMA" Alias="" SMMode="PDU" ProductNet="WCDMA" SimUnlock="Y">" change it to <item name="WCDMA" Alias="" SMMode="PDU" ProductNet="WCDMA" SimUnlock="N">
and save the file remember it is right protected file. to overwrite this save the edited file to some other location and then copy and paste in the program files/idea net setter/
close your idea net setter and restart net setter now you can use any sim cards
False write protect on an EMPREX 8GB Flash Drive
hiii martin....
dis type of problem comes when sm files inside d folder which iu want to copy restricted allowing files to copied...
u can copy it by fallowing procedure....
first open urs folder and select some of urs files not all of them and copy it to flash drive by makin a new folder....and similarly copy other files in that new folder..
if u do like that u can copy all files eaisly......
if it creates ore problems ask me.......
also available for live chat....
thankss
Top Transcend Electronics - Others Experts
NOEL
NOEL
Larry
August Brown
August Brown
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
