Question about Dishwashers
Whirlpool dishwasher - how do i remove timer ??
I am trying to replace the Timer on a Whirlpool 2000 semi integrated dishwasher. I have found the timer OK but just cannot see how to remove it from its mount
  • bathrooms Mar 12, 2008
    This doesn't sound like my dishwasher and I may have given you the
    wrong info. The dishwasher has Generation 2000 on the front. The model
    no is 8511 342 15540.
    It is def a mechanical timer but I can't seem to turn the **** backwards.
    I can access the control panel by undoing the Phillips screws on the
    back ofthe door. This reveals all the electrics and timer which are
    mounted on a plastic panel which is inside the aluminium fascia, but I
    cannot access the front of the plastic panel.
  • Anonymous Mar 27, 2014
    I believe my timer is broken I have a 10 year old dishlex 100 is it practicle to fix it or do we need a new dishwasher? if I keep moving the timere it sometimes works ok for a few washes.
    Novelist:
  • 131 Answers
When I looked up a Whirlpool 2000 dishwasher, it shows an electronic timer. For a mechanical timer, see last paragraph.
First, turn off the breaker for the dishwasher. Then you'll need to remove the Phillips screws around the inside of the door. The inner door panel lifts up, leaving the electronics in place. Disconnect the vent motor and the dispenser motor wires. Place something heavy on the outer panel to keep it down and prop up the inner panel. Remove the plastic cover over the timer - it should pop off. Remove the wires to the circuit board. The electronics are held on with one or two screws.
Mechanical timer: Turn the timer **** backwards. It should come off along with the pointer. This should reveal a 1/4 in ***** holding the timer in place.
Posted on Mar 11, 2008
  • Michael Grimshaw Mar 12, 2008
    Sorry, I'm not finding that model number listed anywhere. The Whirlpool model numbers usually start with something like G2PD......
    If it's a mechanical timer, turning the dial backwards shoud get the dial off.
My whirlpool gold quiet partner II will not change cycles it just keeps running. What can I do?
Hello there and thank you for choosing fixya
This is a fairly common issue with these dishwashers the problem usualy stems from the timer itself the timer tells the machine to switch to the next cycle after a given amount of time and when it quits working then the timer needs to be replaced
So what you will want to do is first try a different load cycle or even try them all to see if it changes if so then this is a true sign of the timer being bad ok so if it does work in lets say a light cycle but not in the normal cycle this means that the normal cycle part of the timer is bad ok?
Please try these first and post back to to what you have discovered andi can continue to help you form there ok?
Best regards Mike
Aug 03, 2011 | Whirlpool DU1055XTSD 24 in. Dishwasher
Whirlpool dishwasher stopped in mid cycle still had water in the bottom and will not operate. No lights will come on
I know this may sound like the obvious but have you checked the electrical circuit breaker to see if it is tripped? If you have and the breaker is not tripped the next most likely problem is the timer. A new timer along with a good tutorial on replacement can be found at http://www.repairclinic.com . Just enter your model and any other information asked for at the home page search engine, find your parts and order. Replacement videos are available on the site.
Thanks for using FixYa and for the great rating.
hardrocko
Oct 13, 2010 | Whirlpool Dishwashers
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
Timer dial not advancing; will run at any point, but not move.
Most likely your timer motor is bad. Some models just the motor can be replaced and some you have to replace the whole timer. If you want to try to fix yourself let me know.
Ken
Mar 17, 2010 | Whirlpool 24 in. DU850SW - Multiple Color...
Washer continues to run but the timer stops at 42 minutes
OK I see it.
Most likely problem is the timer. The timer tells the machine what to do and when. Yours is sticking at the 42min mark.
I do not see the model number so I'll take an assumption.
Digital timers are integral to the control panel and can be replaced as part of the panel.
Rotary dial timers are easily removed and replaced.
Switch the breaker off. Do not touch the control panel without first having done so.
To remove the control panel there are screws around the outside of the door frame and on some units from inside the machine on the door frame. Remove them and the control panel will be exposed.
If you have a rotary dial timer remove the control knob (pulls off) and the screws retaining the timer inside the control panel. You can sometimes "fiddle" with this style timer and get it going again. It is usually just dirt struck in the mechanism stopping it turning. But it is not expensive and I'd just replace it.
Digital is another system. If you can remove the timer section as a unit then you can replace it. Fist I would get the model number and go to your local parts dealer. Ask it you can get just the timer. If so replace it. There are no serviceable parts in an digital timer.
I hope this helps you. Please rate it is it helps clarify for you.
Mar 10, 2010 | Whirlpool Dishwashers
Whirlpool dishwasher wont change cycles
wow, good move with the heating element. most folks don't know about how that relates. if that stuff is good, it must be the timer. or at least the small motor which turns the timer. good luck
Nov 07, 2009 | Whirlpool DU1055XTSD 24 in. Dishwasher
How do you remove the timer on a Whirlpool washer
You have to unscrew the knob and remove the screws that are under it, some have just a center nut with a locating tab that goes into a hole to hold it straight.
Oct 24, 2009 | Whirlpool Washing Machines
Whirlpool gen 2000 makes right noises on start up
check only the water inlet because it maybe weak then a timer of inlet stop after this time
thanks
Jun 10, 2009 | Whirlpool Dishwashers
Apparently you didn't read the info I included with my question.
ok,If you need any info regarding the parts for your model just click on the below link,select your model and you can browse the sub components and the components including the diagram.
http://www.searspartsdirect.com/partsdirect/retrieveModelActionHome!retrieve.action;jsessionid=QQl3xkV8qbK7Dv-GyNIKtQ**.shcapp3305?modelNumber=DU1055XTP+&pop=flush
Aug 07, 2008 | Whirlpool 24 in. DU1055XTP Built-in...
Dishwashers Logo
413 people viewed this question
Top Dishwashers Experts
