Ryan,
The loose or broken connection may be possible since the ground wires in the DVD cable are so fine that it was difficult to solder the much heavier ground wires in the component cable to ithem If I can get it working as is I think what I do is to revert to the other fix to solder the component wires directly to the flat and non-flat strands of the component input jack. This will be easier to insure a good contact. I understand this should have the same effect as connecting them to the DVD cable.
In regard to the remote code I used the cable remote to search for a program code for the TV since the 3 codes they had for Mintek did not work.and finally found one that turned the TV off. However in trying to turn it on again it would only put the TV in standby and I had to push one of the side buttoms to get it to come on fully but still no picture.
I'm now going to undue the first fix and solder the component wires and ground directly to the flat and non-flat strands of the component input jack and see if that works. The problem seems to be that the TV doesnt want to come out of the DVD mode whenst it was originally frozen when I started the fix.
Mike
The TV needs to remain in DVD mode. Please correct me if I'm wrong but from my understanding you're hooking the TV up through a standard coaxial cable. You'll need to connect you cable box to the TV using component RCAs, not regular coaxial cable.
Since the DVD player sends component video to the motherboard of the TV, that's the only thing you can send through the new connection you just made.
I was going to post pictures tomorrow however I loaned my sister my digital camera a few days ago and she won't be able to return it until the end of the week. I can try using my cell phone and bluetooth... I'll see how it goes.
Let me know how it goes
Ryan
Rating Locked! (?) Bintzi has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Mintek Fix:
