Question about Sony NWZ-B103FBLK MP3 Player
Turns off when press play!!!
I just downloaded the new firmware and my mp3 player is finally recognised by the computer. thanx a lot! UNFORTUNATELY, there was another problem. Whenever I press play it POWERS OFF then turns back on without pressing anything!! PLEASE HELP ME!!!
I knid of figured it out myself! I solved it by pressing PLAY while inserting to the computer! pulled it out and WAAALLLLLAAAAA! It worked! Thats before I found the solution from drake101!
thanx anyway ! I just can't stop smiling today ! thanx FIXYA ! You were my last hope ! Saved me from spending another $250 bucks to get another one !
Posted on Mar 12, 2008
    Problem Solver:
  • 5 Answers
If it is fairly old or often used then the battery life might be running out and that might be the problem so if it isn't too expensive then i would try going somewhere to buy a new battery for it
Posted on Mar 11, 2008
NWZ-B135 stuck on 'Walkman' logo, but won't go to play mode.
U need to upgrade the firmware,you need to download the firmware from here: http://support.sony-europe.com/dna/downloads/firmware/firmware.aspx?site=odw_en_GB&m=NWZ-B135&f=FRM_NWZ_B13x_f after downloading,run it and then connect the player to system while holding the "volume -" button...it should be detected and the firmware would be restored.
Aug 18, 2009 | Sony Walkman NWZ-B135 MP3 Player
My RCA Opal again...
I had the same problem too. I was about to give up and throw this RCA player away but I it is only 5 weeks old, I got it for christmas and would feel terrible letting it go because of this stupid problem. I noticed soo many other people had this same problem, and since I spend over an hour and got it fixed, I had to share my solution and hopefully help others. I must have tried bwelliver's solution 10 to 20 times before I finally figured out the pattern to doing it. Unfortunately, i should have gone down and noticed what clklause has recommended, which was to ensure that the power is turned off before plugging in the RCA mp3 player.
All I did was download the firmware from the link that bwelliver linked to, unplugged and turned off my RCA M4208GR-8 player, then 1) I ran the firmware software 2) held down the Play(center button) on the RCA mp3 player that the power is still TURNED OFF, and 3) plugged in the player to the USB plug right after starting the firmware program. I watched the firmware program on the screen and noticed it would go from "searching" to "initializing" and I immediately released the Play(center button) on the RCA player and sure enough, the RCA player would begin initializing, and I was able to click Start on the Firmware program from the PC.
Hope this helps
Jan 17, 2009 | RCA M4204 MP3 Player
Creative zen mp3 help please
You will need to put the Zen into recovery mode and erase the firmware, then reload the firmware. Follow these steps:
To Erase the Firmware:
1. Get a paperclip and straighten it out.
2. Hold down the Play/Pause button, and put the paperclip through the reset hole. Release the paperclip while continuing to press the Play/Pause button until you see the screen change.
3. Select "Reload Firmware."
To Load the new Firmware:
Go to www.Creative.com/support --> downloads. Click through the navigation and download the latest Zen Touch firmware. Reboot your computer, then plug in your Zen via USB cable. Double-click the firmware icon and then click upgrade.
Apr 02, 2008 | Creative Labs Zen Touch MP3 Player
Rca opal M4008A mp3 player
Hi, you can try to upgrade the player's firmware, you can download it from the RCA Website (http://support.rcaaudiovideo.com/downloads.aspx?product=187), the firmware it's the second app listed.
If your computer doesn't recognize the player, you'll have to turn it off and keep "PLAY" pressed for 10 seconds while connecting it to the USB port, then update the firmware.
Feb 08, 2008 | RCA OPAL M4001 MP3 Player
Help?
Feb 07, 2008 | RCA OPAL M4001 MP3 Player
YP-U2J - Need download - Didn't come with CD
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
CLICK Here to Download : Firmware Update
In case u have WMP 11 and player not working, this error is common after installing Windows Media Player 11
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Jan 27, 2008 | Samsung YP-U2X Digital Media Player
Cannot use my player-device manager problem/deleting files
This error is common after with Windows Media Player 11
Jan 01, 2008 | Samsung YP-U2X Digital Media Player
How do I f/w update??????
Here's the site with the firmware upgrade download: http://www.samsung.com/support/productsupport/download/Model_Select.aspx?type=Digital+Audio+Player(YEPP)&typecode=200600&subtype=Yepp&subtypecode=200601&model=YP-U2JQB/XAA&filetype=FM&language= although I'm sure that the f/w updater is within this program here: http://www.samsung.com/support/productsupport/download/Model_Select.aspx?type=Digital+Audio+Player(YEPP)&typecode=200600&subtype=Yepp&subtypecode=200601&model=YP-U2JQB/XAA&filetype=SW&language= That should help you with your problem. First download and install the first link, then use the tools that are within that program. Once finished, update it with the firmware update and you should be alright.
Apr 01, 2007 | Samsung YP-U2X Digital Media Player
Sony NWZ-B103FBLK MP3 Player Logo
43 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
