Question about Oasis Hunter 54' Ceiling Fan
WIRING OF 3-WAY SPEED SWITCH FOR HAMPTON FAN
CAN YOU PROVIDE ME WITH A WIRING DIAGRAM FOR MY HAMPTON BAY THREE WAY SPEED SWITCH. THE LEADS HAVE PULLED OUT OF MY MOTOR, SO I DONT KNOW WHICH COLOR CONNECTS TO THE MOTOR VS THE CAPACITOR, ETC.
THANKS,
***** JIMENEZ
214-331-0905
  • 3 more comments
  • Anonymous Aug 06, 2008
    was going to replace fan switch.when i took out the old switch the wares came out. have not been able to get wires back like thay shoud be.this is a 3speed /4wire switch.sure need your help. nthanks delwin jones seminole tx.
  • Anonymous Sep 05, 2008
    same problem
  • Anonymous Sep 25, 2008
    same as above
    3 speed, 4 wire switch--need color cobo please
  • Anonymous Nov 13, 2008
    same isse
  • Anonymous Jan 04, 2009
    I have the same problem
1 - Red/Pink
2 - Purple
3 - Yellow
L - Black
Posted on Jun 20, 2009
Had to disassemble a Hampton Bay ceiling fan to install a new light pull switch. Hung from a paperclip while fixing but it dropped and disconnected a number of wires. Rewired by my best guesses and now fan...
If you bought the switch from Lowes, most likely it's the wrong switch. Even if it looks the same on the outside, it could be different on the inside. As for the other wire, push it into the empty slot of the switch & see what happens. There has to be 4 wires in the switch. Black usually goes to L
Jan 04, 2015 | Hampton Bay Dryers
Tip
Fan speed switch wiring
If your are replacing the fan speed switch on the Hampton Bay San Marino mfg # 67353, this is the correct wiring pattern...L-white, 1-yellow, 2- blue, 3-black. I have been searching for this answer for 2 days. Thought I'd post for others with the same problem.
on Jun 01, 2008 | Hampton Bay 36 In. San Marino in Brushed...
Replacing Hampton Bay 3-speed pull chain fan switch. I do not have the original wiring diagram. I have a new ZINGEAR pull switch and need to wire L, 1, 2 and 3 with available wires: black, white and b
L-Black 1-Gray 2- Brown 3- Purple
If this doesn't work you have the wrong switch. It might look the same on the outside but that doesn't mean it's the same on the inside. You might want to check your capacitor to make sure it's not going bad!
Oct 14, 2014 | Hampton Bay Dryers
20 year old Hampton Bay fan requires new 3-speed pull chain fan switch replacement. I did not copy the wiring pattern for the L, 1, 2 and 3 positions. There are 3-wires: black, white and blue.
Typically AC wire protocol designated black = line voltage (means \'death\') and white is neutral (cold).
The blue one will be a switched line to the motor and a meter capable of checking continuity should allow you to determine the proper wiring.
No wiring diagram with fan ( hampton bay three speed fan with light)
white to white, black to black, blue to red, & green to ground.
If you don't have a second hot house wire(red), then put black & blue from fan to house black.
Nov 29, 2010 | Hampton Bay 52 In. Cameron II Plus Ceiling...
I am replacing the three speed pull chain switch on my fan. The switch broke in the brass housing b4 I could ID where the 4 wires went (L,1,2,3). I could see black was L, but don't know where to put the...
You may just have to guess and try it. As long as the L is right, you'll be fine. My guesses, however, would be 1-brown, 2-gray, 3-purple. I don't have a wiring diagram, those are just based on years of wiring. Good luck and have fun experimenting.
Mar 22, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Jun 08, 2008 | Dryers
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Oasis Hunter 54' Ceiling Fan Logo
8,943 people viewed this question
Top Oasis Dryers Experts
Are you an Oasis Dryer Expert? Answer questions, earn points and help others
