If you have the system restore CDs or a restore partition you can try to do a repair install of windows through that. Let me know if you have the media or a partition and I can assist you further.
NOLA Tech
Have you added any new hardware or updated anything?
Try pressing F8 before it boots to the Windows splash screen and see if you can get the boot up options to come up. If so, you should try to boot with the last Good Configuration that worked, and then if that doesn't work try to boot into safe mode and uninstall the webcam and norton. Probably just the Norton first, as it is the most current thing to come about. NOTE: You should remain offline while doing this and if it works go online and immediately download an alternative antivirus program.
Good Luck,
NOLA Tech
SOURCE: My Acer Aspire AM5641 had the blue screen pop up
your video has failed . on this unit I work on this exact unit every day. the video is what we call integrated and there is a big problem with this there is no video card it is integrated on the mother board . the problem is the motherboard is almost impossible to find. my company services the whole united states and if your unit brakes and you have a secondary warranty i am the first line of contact . and the motherboard for this unit I can rarely fin . if it helps the part number is mb.sam09.001
Can't find any of the original discs...Just turned the computer on again, monitor says no signal and the computer doesn't even beep, just initially winds up and thats it...? Motherboard gone..? Thanks
Actually disconnected the two discdrives and the graphic card as well and tried a reboot, and still no different response. Thought this may help seeing as the initially warning from Microsoft was that a hardware problem was identified and it was forcing a shutdown...Any idea of costs for either a motherboard or a potential popwersupply, if that could possibly be the mess up here. Thanks guys! Aaron
I did add a logitech webcam installed about two weeks before it went down. It was a completely new unit out of the box from Best Buy. Other then that, this has just been a home used unit with minimum running time. Thanks
Unfortunately I didnt't get the code for Microsoft shut down as I thought it was just something temporary..
Sorry, I did install Norton 2 year Security as well about four days before it went down.
