Washing Machines Logo
Posted on Mar 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water leaking from machine during wash cycle . started useing machine after being gone for a few days and the floor was covered with water with soap from machine . looks like the whole thing mt out.........
Gerry Harvey
Level 3:
Genius:
  • Washing Mach... Master 1,482 Answers
  • Posted on Mar 22, 2010
Gerry Harvey
Level 3:
Genius:
Answers
1482
Questions
0
Helped
378914
Points
4533
Check door boot seal. holed
1helpful
Water leaking on fast spin
hi Eamon.
this is what i found from the internet.
Washing machine leaks on spin Last updated on February 6th, 2017
Sometimes a washing machine leaks on spin, but not before. If this is the case, either it's going into spin with too much water inside, or something may only be leaking under the pressure and tub movement caused by spinning.
If you can see water running out of the soap drawer during spin it's probably gone into spin without pumping the water away properly. If it wasn't pumping water out at all it would not go into spin, but a partial obstruction can reduce the flow enough to allow a spin with the water unable to escape fast enough. This causes water to be forced up into the drawer or out of the steam vent at the back. If you suspect this check the last section of this article - Washer leaks from drawer
If water is coming from underneath when it spins then it's more likely to be caused by something leaking only under pressure. Check the door seal all around inside for slits and small holes, especially higher up, which may only open up and let water out when the washer is bouncing around on spin.
Other possible causes are hoses inside the machine which have small holes which open up during spin or which leak where they connect to the tub under spin conditions. These type of leaks often leave tell-tale rust or dry detergent marks. After that there could be a crack or small hole high up in the plastic outer tub which only gets exposed to water when it's forced around the tub during spin.
You are looking for something that is moving and allowing water out when the tub bounces around under load, or something high letting water out when it gets thrashed around the top half of the machine on spin. If you can't see anything obvious get a washing machine engineer
More articles about leaking washing machines Why does my washing machine leak only during the spin cycle
and if you want to read up on some more then try this link.
washing machine water leaking on fast spin cycle Google Search
Intermittent leaking during wash cycle
is the dishwasher leaning foward,are you useing to much soap?start the dw with out anything in it let it run a few minutes open the door and see if there are suds in it if so way to much detergant
My washer is spewing water everywhere sometime during its cycle. The floor is soaked! It seems to be coming from the soap dispenser area. I cleaned the dispenser really well but still water everywhere.
The only way to determine where the problem lies is to take off as many covers as possible then run your usual wash cycle. The problem could be a leaking or blocked pipe or a rubber seal that leaks etc etc. Have somebody in the know open up your machine to determine where the leak comes from.
Best wishes,
Graemevm
1helpful
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
4 mo. old. leaking water and suds all over floor. using he detergent.
If its leaking by that amount there will almost certainly be a pipe that has pulled loose somewhere at the soap box due to the soap suds leaking over the floor. To see the workings, remove the top lid and start a cycle and observe. Go from there.
2answers
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Miele g841sc dishwasher leaks
Typically the machine only uses 5-6 quarts of water, If you're floor is getting 1 or 2 quarts check for a loosly connected intake or drain hose. I've never seen any overflow drain on a Miele. It only fills the bottom of the tub. The machine uses a logic program that continuously checks the level of fill and drain by water pressure weight so it always runs with proper amount, even if your intake pressure is weak. Now, If you add too much soap then the bubbles can carry a few ounces over a worn door seal. If the seal is damaged then more spray arm water can run down the front of the machine into the float pan. But after it gets less than a pint of water the drain float will start thr drain pump and shut-off the machine controls and alert you. It won't let you run the machine until the water ( and the problem) is gone. Call Miele for help.
2answers
Intermitant water leak.
Put a newspaper under the machine, it will help you to find out from where does the water leaks. Good luck!
Top Washing Machines Experts
john h
