Question about Canon IMAGERUNNER 6570 Copier
Scanning image in landscape
We scan multipage documents to a remote site. The page images are all oriented as landscape when they should be oriented as portrait. How can we fix this?
Also, the scanning resolution is very low, probably 200X200. How can we default the scanning to a higher resolution?
Thanks
  • Canon Expert
  • 287 Answers
Hello jimpoe. I have bad news. I am not a formal representative for Canon, but our company recently (last 2 years) began to sell Canon equipment as a wonderful addition to our traditionally Savin oriented company. One of our customers (they bought 19 Canon devices) found the same limitation regarding image orientation and so we basically "donated" a Savin device that MR.Customer uses when they need to overcome this limitation. We have learned that although the Savin copier can "auto orient" the documents as they are scanned, the Canon devices cannot unless you puchase a rather expensive app that they don't mind selling as a stand alone app. All were pleased(not). My company has expressed its displeasure strongly. Think about it. Longtime customer......buys new equipment......changes from Savin to Canon......OOOOPS. Your second question regarding the dpi settings I can assure you can be changed and be made as your default. I will have to get in front of one to give you the specifics, and i will do that very thing and get back to you. I will gladly give you a step by step. Give me a day ok? Or perhaps some one may beat me to the punch, thats ok too. The object is to help you.I will grab a 6570 and write down the steps for you. If you get impatient though, it IS in your documentaion regarding the use of the SEND feature. I will get you hooked up tho. Take care...speak soon.................SPINAL
Posted on Mar 12, 2008
Epson scanner gts50 orientation is set to portrait but scans landscape
It may show as landscape on the screen but printer properties will have to be set to landscape if you want to print that way, the rotation is not automatically controlled.
Jul 16, 2015 | Epson Office Equipment & Supplies
Hi, I have multifunction printer (Ricoh Aficio 1515MF) I want to use it to scan many pages to a folder in my pc, unfortunately I didn't found any way to make that, the only way I found by email, then I set...
If the printer came with operating software you should use it to scan the document. Even without the manufacturer software (but not the drivers) you can use Acrobat or Word Perfect or LibreOffice to scan to the application then save the scanned file either as pdf, image format, or as text (OCR).
There are some free scanning software available on the Internet: freeOcr, pdfViewer, Paperscan Free edition They are usually able to send the file to an application or save in a specific format. If they are not able to scan a multipage document you will have to scan one page at a time then assemble the pages
Oct 11, 2013 | Ricoh Aficio 1515MF All-In-One Laser...
Change orientation on canon dr-7580 scanner
Two step process, scan and save the image, then print and select landscape
Sep 13, 2012 | Canon DR-7580
Dual sided scanning - how?
From the scan section, chose your recipient(s) first.
Then go to Image Settings > Auto/Original >
Choose 2-sided booklet or tablet, choose portrait or landscape orientation. Then scan as usual.
I believe you can also make this a default under System
Settings > [Admin Login] > Image Send Settings
Jun 30, 2009 | Sharp MX-2700N Color Copier
Canon DR-9080C Duplex Rotation issue
Scan in portrait mode only. Of course this takes more time as compared to Landscape mode. The top module 'reads' left to right as we see it and the botom module 'reads' right to left, if you look from top. So if you scan in landscape mode and rotate, the back side is rotated by another 90 degrees and hence you see it upside down. If you are using PDF file and have Adobe Acrobat, you can specifically rotate odd or even pages.
S. Mohan, Chennai, India
Jun 23, 2009 | Xerox DocuMate 252 Path-Through Scanner
Problem scanning multi page document
You do not say which software you are using but if you can afford PixEdit you can save to multipage tiff, Pdfs and so on. Also combine singlepage and mulitpage documents to one mulitpage and vice verca.
May 05, 2009 | HP Scanjet 8350 Flatbed Scanner
Cannot view second or subsequent pages in multi-page tiff format
Check your settings, you must have selected multipage option. With multipage tiff, you need to view it with an appropriate software by pressing pageup/pagedown yu can view all of them. Windows Fax viwer can also used. To clear your doubt, scan only one page and check the file size. Then sacn a set of documents containing the same image. If the file size is more, then you can deduce that all te images are available.
Dec 11, 2008 | Fujitsu Office Equipment & Supplies
Images upside down and backwards
The ADF does nothing more than feed the document into a position to be scanned, and has nothing to do with print issues " stripes" on print? Can you provide more details.
Typically you will find an icon near on the tray of the ADF which will display the proper orientation for the item to be scanned. If this is correct, then your software is somehow manipulating the image to a different orientation. You may want to check the scanned image before printing, and check the printer settings. More likely a printer problem, than a scanner problem as I have understood the issue thus far.
Nov 19, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Kodak i260 Scanner
This is practically impossible. This can happen only when the file is over written! Check your software settings. May be you have selected 'multipage' option. Try scanning one page and two pages (same sheet). If the file size is different, then it means two files are scanned.
Reload your Driver and check your scanning software. I am assuming you are usning winXP/Win 2000.
S. Mohan
Jul 30, 2008 | Kodak I260 Captiva IA-Express Path-Through...
113 people viewed this question
old marine
old marine
