Can not use printer from lap top plus often times not able to connect to internet from lap top. Am using Vonage telephone service and Comcast high speed internet
  • Anonymous May 11, 2010
    model # laptop? are you using a router to connect to the internet?
    Genius:
  • 3,587 Answers
Two issues..let's handle them one at a time, shall we?
get new printer drivers here first..
don't see your model or make, so it's a guess that you might find it there.
Posted on Mar 11, 2008
SOURCE:
Cannon mx 330 printer/fax. I plugged into the comcast modem for Tel 1 line then to the back of the cannon fax L. that didn't work so I connected it to the telephone line on the back of the fax..Help
The Pixma MX330 Line port needs to be connected to a POTS (plain old telephone service) line jack with an RJ-11 cable. A standard corded telephone or the base of a cordless system gets connected to the Tel port on the MX330. The Comcast modem connects devices to the internet. You might be able to use a VOIP (voice over internet protocol) service between the MX330 and the modem. You will need the appropriate hardware (MagicJack, Ooma) in between the modem and the Pixma and get an assigned telephone phone number.
Generally, you will need a compatible router to share the cable modem's internet service between any computers and a stand-alone VOIP system like the Ooma.
I hope this helps. Please add a comment with more about your Comcast hardware for additional information. I know my home's fiber-optic modem service does support POTS, in addition to the internet and TV service. Each service has their own wiring/jacks that go back to the modem.
Jun 28, 2018 | Cannon Office Equipment & Supplies
My account # is 102015295. I am being charged for messaging; I setup voice mail for #931-628-5360 but I am being charged. Please cancel the Voice mail on this #931-628-5360
This is a matter you should take up with your telephone
service provider ( at&t / Bell, Verizon, Sprint, Time Warner
Cable, Comcast, Vonage, or whomever ). Cancelling or
adding a purchased service is 'way outside the scope
of a "...can I help you ?..." internet forum.
May 09, 2016 | Lands Phones
How should the D-link be setup to work with comcast and vonage? After I set vonage or internet do not work. I tried the comcast modem to d-link and d-link to vonage.
If you want to RECEIVE telephone-calls:
COMCAST ADSL/CABLE modem <---> VONAGE <---> wireless-router
Turn each piece off.
Turn on the COMCAST modem, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the VONAGE router, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the D-link router, and wait for its lamps to settle-down to a "steady" pattern.
Restart the computer that is connected to the D-link router,
and you should have Internet access.
Dec 01, 2009 | D-Link Vonage-enabled Wireless Router...
I just Bought the HP Officejet All-in-one J4540 Printer. I am also using Vonage as my phone source. I have high speed broad band internet cable. How must my phone jack hook ups be configured to send and...
Since a fax works over an analog telephome signal this is no different when you hook up a phone to your vonage. I believe you hook up a regular telephone to your vonage router via a telephone jack in the back of it. If so plug the fax machine into it via a splitter
Nov 25, 2009 | Office Equipment & Supplies
Dell printer A940 fax trouble
Unless you have 'VOIP' telephone service with Comcast, your FAX will connect through your home's telephone line, not the internet (or modem). You would connect your phone line to the all-in-one printer, then follow Dell's instructions for use. Good luck!
Apr 18, 2009 | Dell A940 All-In-One InkJet Printer
I can't seem to get the communications connections connected to send a fax. I have internet telephone and internet service and don't know where to connect what?
FAXes are sent and received through the telephone line connection on the back of the printer. There are two RJ11 connectors - one to your house wiring, and the other to your telephone handset. At a minimum, connect to your house wiring.
The FAX drivers and software should have been installed with the rest of the software. Confirm by checking in Control Panel, Printers, to see if "Canon MX700 series FAX" is in the list.
I use Vonage as my telephone service provider, and I've had excellent results both sending and receiving.
Hope it helps!
Mike
Dec 12, 2008 | Canon PIXMA MX700 All-In-One InkJet...
My in-laws have vonage telephone service with comcast internet, before they just had at&t with no problems. Now when they are having a telephone conversation the connection seems to cut in and out and...
With choppy audio and one-way audio, either party on the call hears the audio breaking up, or no audio at all. Dropped audio is when a call is in session and both parties are unable to hear each other.
  • From your Vonage account, there is a feature called the bandwidth saver. This feature controls the amount of bandwidth used for a phone call. Try adjusting the bandwidth saver to either medium or normal. After you adjust your settings, test and see if there is a difference in the audio quality. Please note that when you change bandwidth saver it could take a few minutes for the device to reboot and take the changes. From your Vonage account, there is a feature called the bandwidth saver. This feature controls the amount of bandwidth used for a phone call. Try adjusting the bandwidth saver to either medium or normal. After you adjust your settings, test and see if there is a difference in the audio quality. Please note that when you change bandwidth saver it could take a few minutes for the device to reboot and take the changes.
  • Reboot all of your devices (Vonage device, any routers and cable / DSL modems). How Do I Restart My Phone Adapter and Network Devices?
  • Ensure that your Vonage device is at least four feet away from any other device.
  • Ensure your Vonage device is in a well ventilated area to keep from overheating.
  • Ensure no file sharing, P2P applications, or large downloads are running while you are using the phone. These activities can use up most of your bandwidth, leaving little left for your calls.
  • Connect your Vonage device directly to your cable / DSL modem, if it is not already. If this helps the audio quality, then the problem is occurring between the Vonage device and modem.
  • If your Vonage device connects to another router and not directly to your cable / DSL modem, try disabling any firewalls or SPI (Stateful Packet Inspection) on that router. Click here to learn about firewalls and SPI.
  • If you wish not to disable your firewall, then you can port forward the Vonage traffic to the adapter. Click here to learn about port forwarding.
Wireless Routers and Cordless phones — If you have a wireless router and a cordless phone:
  • Ensure all wireless devices and cordless phone bases are at least four feet away from each other.
Home wiring — If you are using home wiring:
  • Ensure the land line has been disconnected in the Demarc box. Ensure the land line has been disconnected in the Demarc box.
  • Ensure there are no more than five phones connected through the house wiring. The signal fades as more phones are connected to house wiring.
  • Test with one phone directly connected to your Vonage device. If this fixes the issue, there may be a problem with your house wiring.
If you have made it through this checklist and you are still experiencing an audio problem, our first class customer service is available to assist you. Please have handy your account ID, phone number, name of your internet service provider (ISP), and model numbers for your Vonage device and any other devices in your network.
Dec 03, 2008 | Vtech mi6896 Trio Cordless Phone
Phillips faxjet connecting to vonage telephone service
Fax machines are ANALOG devices. Vonage is a DIGITAL phone system.
Oct 22, 2008 | Philips FaxJet 375 Plain Paper Inkjet
Lap top not connecting to signial
Yes you can reconnect your router. Whoever did that at Comcast had no business doing that and should be reported and return their equipment back to Comcast asap. It could appear on the bill.
I have a Linksys modem on my Comcast router and it works fine. I don't let them touch it because it uses T-Zones at home service for phone use and it uses a special router to manage it since it has a sim card to run the phone line.
Vonage equipment can be used as well.
I wonder if they were trying to put their phone service onto your system?
Jul 18, 2008 | Linksys Wireless-G Broadband Router
Telephone connection
what router is it its a voip router like vonage
Oct 17, 2007 | D-Link AirPlus DI-524 Wireless Router
Open Questions:
BROTHER toll free phone {&$&{1'8OO;8O3*1O69} NuMbEr USA .ANITA This BROTHER USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 BROTHER USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the BROTHER USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, BROTHER USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. BROTHER USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact BROTHER USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling BROTHER USA Calling BROTHER USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from BROTHER USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with BROTHER USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare BROTHER USA's phone numbers against each other. Contacting BROTHER USA in General While I8OO8O31O69 is BROTHER USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach BROTHER USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact BROTHER USA.
Oct 18, 2019 | Brother Computers & Internet
CANON toll free phone {&$&{1'8OO;8O3*1O69} NuMbEr USA .ANITA This CANON USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 CANON USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the CANON USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, CANON USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. CANON USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact CANON USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling CANON USA Calling CANON USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from CANON USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with CANON USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare CANON USA's phone numbers against each other. Contacting CANON USA in General While I8OO8O31O69 is CANON USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach CANON USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact CANON USA.
Oct 18, 2019 | Canon Computers & Internet
DELL toll free phone {&$&{1'8OO;8O3*1O69} NuMbEr USA .ANITA This DELL USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 DELL USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the DELL USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, DELL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. DELL USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact DELL USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling DELL USA Calling DELL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from DELL USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with DELL USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare DELL USA's phone numbers against each other. Contacting DELL USA in General While I8OO8O31O69 is DELL USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach DELL USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact DELL USA.
Oct 18, 2019 | Dell Computers & Internet
HP toll free phone {&$&{[email protected]*1O69} NuMbEr USA .ANITA This HP USA phone number +1:8OO:,:8O31069 is ranked #2 out of 2 because 7,728 HP USA techs tried our tools and information and gave us feedback after they called. The reason techs call # I:8OO:,:8O31069 is to reach the HP USA toll free department for problems like Where to buy, Complaint, toll free, Repairs, Returns. As far as we can tell, HP USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. HP USA has 2 phone numbers and 4 different ways to get tech help. We've compiled information about I8OO8O31O69 and ways to call or contact HP USA with help from techs like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling HP USA Calling HP USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from HP USA toll free can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with HP USA's toll free department, you may need to provide them with information that identifies you as a tech, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare HP USA's phone numbers against each other. Contacting HP USA in General While I8OO8O31O69 is HP USA's #2 most popular phone number, it's not the only way to get a hold of their tech care team. You already know from reading above that I8OO8O31O69 is their best tech phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach HP USA help by calling them, is that other techs give their toll free at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact HP USA.
Oct 18, 2019 | HP Computers & Internet
Computers & Internet Logo
83 people viewed this question
Ekse
Alun Cox
