I was wondering if you would be able to here sound ? becasue when I turn it on the white line in the middle of the screen but there is no sound either.
Comments:
Mar 12, 2008
- The line is horizontal but it is centered in the middle of the screen.
Yes, you should still have sound, providing that you have an antenna
connected and are tuned to a channel. If you have a vcr or dvd player
to hook up to it try that and see if you have sound.
No sound while viewing a tuned in channel or via a vcr/dvd player is
not a good sign. It may have cracked the PCB inside the tv. A cracked
PCB, depending on the severity, can also be repaired.
You really won't know the severity of any internal damage until it is opened up and checked over.
Is the line on the screen Horizontal (left to right) or Vertical (up
and down) and is it centered on the screen? A vertical line would
indicate that it may be a cracked PCB (Printed Circuit Board).
Comments:
Mar 12, 2008
- If you can't get sound using any of the aforementioned methods it may take a technitian some time to repair.
Sound circuits are not as easy a fix as picture.
It could still be something simple, but you could spend 2-3 hours on a
repair and still not find/correct the problem. I'm not sure what tv
tech's get in your area, but hourly fees can be anywhere form $45-85
(or more) an hour, plus parts. I wish I could take a look at it as I
love a good challenge :)
my tv wont turn on..there is just a flashing red and green light on the front panel. I have tried to...
(More)
my tv wont turn on..there is just a flashing red and green light on the front panel. I have tried to unplug for half a day, but its not turning on.. Help!!
Cable connector is loose on the back of the tv, and will not work. It's a silver box, with cable...
(More)
Cable connector is loose on the back of the tv, and will not work. It's a silver box, with cable connector coming out of it. It has f860-4A-125V Little Fuse Inc. Mark:Type 251004
We just connected to a suddenlink dvr box and new remote, tv was working fine now all the sudden...
(More)
We just connected to a suddenlink dvr box and new remote, tv was working fine now all the sudden it's not getting audio. Any ideas, i've gone over every bottom on the remote
