Question about Toshiba Satellite A60 Notebook
Toshiba A60-672 keyboard
Letters x, c, v, m and the ' and # keys do not respond.
The driver loaded is the standard 102/103 key keyboard, not sure if this correct but cannot find any specific drivers or special software on Toshiba site.
  • Woodgnome Mar 11, 2008
    Yep, USB keyboard works.
    I have also tried a second laptop keyboard, which, has the same problem.
    Motherboard BIOS has been updated to latest release, just in case.
    What would be my next move.
    Problem Solver:
  • 25 Answers
  • 1,006 Answers
If you have another keyboard to try so do it!
Posted on Mar 11, 2008
  • arben pllana
    arben pllana Mar 11, 2008
    Buy new keyboard
My Toshiba satellite C650 laptop has certain keys that don't respond, certain letters, spacebar, shift. I replaced the keyboard, but the same problems persist. The keys that do not function are for example...
ok
solution
you need to open the computer
select c drive
right click it select properties
list will open
select
tools here you will see
drive errors click it will scan for anything not working
if not try this in search bar bottm left
type in drivers
this will open the device manager
look in list
select keyboard
update driver
done
Aug 18, 2013 | Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
Toshiba satellite a215-s5837 keyboard does not work
Yes, replace entire thing. It's really a membrane key anyway. NO contact to clean..
Feb 10, 2010 | Toshiba Satellite A215-S5837 Notebook
The keys on keyboard of Toshiba laptop does not function
check out irivista.com to order keyboard and step by step instructions, i had to replace keyboard that stop working. (not difficult)
Feb 08, 2009 | Toshiba G83C0001K210 Keyboard
Numbers don't respond
If you are trying to use the numbers in the numpad, Then make sure the Numlock is on. Even after this if the numbers are not appearing then, Install the key board driver given in the CD or through the company web site. Even after that if the key board is not functioning then, you may need to take the key board to a technician. May be a possible crack in the keyboards circuit board.
Feb 06, 2009 | Logitech Cordless Desktop EX110
Keyboard not responding to EVERY stroke
MAY BE BECAUSE THE KEYS DON'T COME IN CONTACT WITH THE PLASTIC LAYER IN KEYBOARD OR MAY BE COMPUTER DOESN'T GET CORRECT INPUT SIGNALS
Jan 22, 2009 | Logitech 967437-0403 Keyboard
Keyboard not responding or typing random letters
Sounds like the liquid has acted like a glue. You will need to get a cotton bud and dip it into some clean water. Try and clean the hole again and see if it still playing up. Also restart the computer and retry word to see if the same thing is happening.
Aug 09, 2008 | Toshiba Satellite A105 Notebook
You have stuck keys from when you removed to clean. Remove the stuck keys and see if it works OK when you press the rubber cap instead of key
The back space one may have a link under it if it is a wide one ensure it is fitted correctly
Aug 09, 2008 | HP P2360AA Keyboard/Mouse
Keyboard problems
I had a similar problem but it would also intermittently not recognize certain keystrokes like the shift key or a few letters. I pulled the keyboard off and blew it out with canned air, then reseated the micro ribbon cable to the motherboard and it hasn't failed since. Good luck
Mar 14, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Toshiba Satellite A60 Notebook Logo
152 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
