Question about HP Color LaserJet 2600n Printer
HP 2600n printer
We have a HP 2600n printer with no manual and we have a paper jam in the output bin. How the hell do we open the machine to get the last remnants of the paper out
  • Patrick Michaels
    Patrick Michaels Mar 11, 2008
    voila...it's magique, no?
    click here for the manual
    and just in case you need more fresh drivers for that unit, click here
  • Anonymous Mar 17, 2008
    How do you open the printer...can't find the paper jam to fix it...
  • 43 Answers
1-st of all remove the dark blue/gray top cover - from the back/top of the printer there are in L and R side 2 holes. Stick a slim screwdriver to release boath locks and lift it up. Under this cover U'll find 4 scrwes. Before lifting the white cover remove the R printer cover for removing the control panel cable. Once U remove the white top cover U can access the fusssing assambley.
Good luck.
Posted on Mar 19, 2008
    Genius:
  • 3,587 Answers
Have you tried a crowbar? just kidding, really.
I'll track down that link for a manual, and post it here in a few moments(assuming I can find it)
Posted on Mar 11, 2008
SOURCE:
Can't find the paper that is jammed in the printer (laserjet 2600n) its says its in the output bin
The output bin sensor check the quantity of printed paper that remain in the upper part of the printer. When the paper is too much, the sensor report a paper jam.
Check the lever of the sensor in output bin if it's working properly
Jun 15, 2011 | HP Color LaserJet 2600n Printer
Paper Jam errror
Jam in output bin - duplex area
Error message
Jam in output bin
alternates with
Open door and clear jam
Description
Paper jam in duplex reversing area
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Jam in output bin - fuser area
Error message
Jam in output bin
alternates with
Description
A paper jam has occurred in the output bin near the fuser area.
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
My printer says there is a jam in the output bin but there is no visable jam. HP color laserjet 2600n
Just try the steps
Jam in output bin - fuser area Error messageJam in output binalternates withOpen door and clear jam DescriptionA paper jam has occurred in the output bin near the fuser area. Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.
Jam in output bin - duplex area Error messageJam in output binalternates withOpen door and clear jam DescriptionPaper jam in duplex reversing area Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Jan 28, 2010 | HP Color LaserJet 2600n Printer
Jam in bin
this is a common fault. look where the paper was jammed, you may need a torch. There is a black or white sensor there that has been dislodged. Once clipped back into place it will then report to the printer that the paper path is clear and no longer a jam.
Oct 05, 2009 | HP Color LaserJet 2600n Printer
HP 2600n Ironing transfer paper jammed around top roller
It is probably stuck permanently, and the fuser will need to be replaced. I believe the "fuser replacement" instructions are in the manual.
Jun 05, 2009 | HP Color LaserJet 2600n Printer
Jamming on Output bin...
Ok if the paper is half way coming out, Two things could be happening.
1.) Either your paper feed tires are Slipping and haven't reached the outpit bin sensor in time.
2.) second problem could be is that the fuser film is worn and is not fuser correctly and needs to be replaced.
Are you getting an Error Codes ???
Mar 06, 2009 | HP Color LaserJet 2600n Printer
How to clear paper jam in output bin
The printed page comes through the hot fuser at the top of the printer, through the exit rollers an end up in the exit bin.
We cleared a massive paper jam out of the fuser, by removing the grey surround on top of the printer. The plastic hooks that hold it in place get broken in the process, then you will the jammed paper between the fuser rollers, and the exit rollers. A technician can do it for you, but is unessersarly costly.
Dec 21, 2008 | HP Color LaserJet 2600n Printer
2600N Printer has an output paper jam
open the back cover you will see a blue knob , just turn it ,jamming paper will coming out
Dec 08, 2008 | HP Color LaserJet 2600n Printer
Paper jam
That part is the fuser unit and is hot if the printer is on. Here are instructions for you. Good Luck!
http://www.laserpros.com/pdf/HP%202600-2605%20fuser-etb.pdf
Jul 27, 2008 | HP Color LaserJet 2600n Printer
Jam in output bin
Make absolutely sure there actually is no paper jammed in there.
I came to this page with the same warning, convinced I had a software glitch. Turned out there was a page accordion-folded down to the size of a pencil lead. I didn't know paper could be folded that small.
Of course, everyone here may be a lot brighter than I am, in which case sorry to waste your time. But for me, the obvious first fix needed to be thoroughly explored before cursing HP and their machine.
Jul 08, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
1,813 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
