Question about Microwave Ovens
Possible fuse blown
How do I get to the internal fuse on a 2005 Kenmore 3850 over the range microwave
  • lmheinrichs Jan 21, 2009
    665.61639 kenmore microwave that quit working . Nothing is there at all. The plug in still works for other things
  • jazzy9104 Jan 30, 2009
    Have power to oven nothing is lighting up or working . How do I find the fuse
  • Microwave Ovens Master
  • 9,098 Answers
That would be located behind the control panel.
In essence, you unplug the oven, remove the grille from across the front, then you'll see the screw holding the control panel on.
Once that screw is removed, the control panel can be lifted up and out, then you should see the fuse.
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
Magic chef microwave
There's a fuse that has blown. look for it near the bulb socket or on the main board inside the unit.
Jan 24, 2014 | Microwave Ovens
E-Wave over the range microwave has blown main fuse
My Ewave has stopped heating eventho it appears to be running. Is is possible the power has been reduced or does the microwave need to be replaces
Nov 16, 2009 | Microwave Ovens
No power to microwave?
blown fuse take outer casing off and replace the blown fuse.
You can use a piece of tin foil around the fuse until you are able to replace the fuse.
Sep 07, 2009 | Maytag Appliances Over-the-Range Microwave...
No power-fuse and outlet are good on model 665.69689992 over the range unit.
your microwaves internal 15 or 20 amp ceramic fuse must have blown,unplug and remove outer cover be sure to discharge hi voltage capacitor with insulated screw driver,then it will be a fuse with a white colored body in a clip mount,remove and your local hdwg store has them, if new one blows then either the h.v diode/cap/or magnetron or theres a bare wire shorting to ground,you will need an ohmmeter to diagnosis this
Aug 23, 2009 | Kenmore Microwave Ovens
Microwave shorted out when metal grease filter contacted inside
It might be that the internal power fuse of the MW may have blown. You may have to just replace that fuse if possible. Other wise the electronics (most likely a circuit board) may have been blown.
Jun 29, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
I have a GE Profile spacemaker 2.0 microwave and it just quit working on me. Sounded like a fuse popped?? I verified that the electrical outlet was working. Is there a fuse to replace inside the microwave?
Hello. You have isolated the problem.
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Jun 23, 2009 | GE Profile Spacemaker Over-the-Range...
Kenmore microwave model 665.61629100
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
May 29, 2009 | Kenmore 63792 Microwave Oven
Power outage now microwave won't work
Most likely blew internal fuse. Pull the top/side cover off and check the line fuse. It should be behind the control panel in that area.
Nov 08, 2008 | Kenmore 62622 Microwave Oven
Kenmore elite microwave
Does the digital display light up at all? Is it completely dead? Are you sure it has power? Have you tried another outlet? If the outlet is good and the unit is completely dead, the internal fuse may have blown. You can try to take the cover off (with the unit unplugged) and look for a blown fuse. Try replacing the fuse with an EXACT fuse of the same rating. Try plugging the unit back in again and see if the unit comes back on. If not, you may have a power supply issue or defective Magnetron.
Please let me know what you find and we'll go from there.
Good Luck,
- Jim
Jan 28, 2008 | Kenmore 62702 Microwave Oven
Microwave Ovens Logo
332 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
