TV-PHILIPS MAGNAVOX- MODEL-32MT3305/17
TURN ON TV .JUST 4 FINE LINE IN COLORS AT HALF WAY TO THE TOP OF THE SCREEN. AND NO SOUND. [THANKYOU]
    Problem Solver:
  • 20 Answers
100 microf errid @ 150 volts needs to be replaced with 250 volts.
Posted on Mar 17, 2008
SOURCE:
Top half of tv is white it started with just a line from side to side and has become worst
half the picture on my tv screen turned completely white. ' IGN ...
www.ign.com > Boards > Community Central > The Vestibule
IGN
May 3, 2014 - 7 posts - ‎4 authors
what half? down the middle or every line of pixels? did you google the issue with your tvmodel? my samsung has issues with bad capacitors ...
samsung led ua40d5000 tv half screen turning white - Forums - CNET
www.cnet.com > Forums > Samsung
CNETMay 16, 2013 - samsung led ua40d5000 tv half screen turning white ... Interestingly after half an hour if i push back the TV from top left corner then problem ... Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Dark shade appears in the below half of the LED TV screen
Oct 23, 2014
LED Samsung Smart TV half screen lose in colour
Sep 11, 2013
Runco PL-61cx plasma tv, top half goes black
Jan 13, 2010
More results from www.cnet.com
LCD TV Samsung LN32C450 top half screen problem ...
? 3:58
https://www.youtube.com/watch?v=SawMHKpsYOA
Jun 8, 2015 - Uploaded by Vladimir P.
This is for my Samsung LN32C450E1DXZA that is having major image issues with the top half of the screen ...
Samsung ScreenTartan/Plaid Pattern on top half of screen ...
? 1:22
https://www.youtube.com/watch?v=ue9IQwj7CVM
Feb 03, 2016 | Televison & Video
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
LG 50" plasma PDP50X4 only shows top half of screen, sound and top half of screen work fine....Help!
That's a relatively easy one - you have either upper or lower Y-Sustain buffer board gone bad.
if the last chip of the upper buffer has failed you may get what you get, even that this is a relatively rare type of failure.
The same would happen if the lower buffer is bad although this is again somewhat rare for a failure for those boards.
Either way you need a new buffer board and I'd start with the lower if I were you.
I assume nobody has messed up with the TV because another possible explanation would be the two buffer boards were disconnected from each other.
The best is they are neither too expensive nor hard to replace.
Hope this helps!
Oh, here's a link with something more about those boards although I am not sure it would apply to your particular case...use it as a good educational resource, but don;t expect to have the exact problem described there:
http://blog.coppelltvrepair.com/2010/10/vertical-or-horizontal-color-lines-in.html
For more help please use www.coppelltvrepair.com/diagnose ..
Sep 30, 2012 | LG Televison & Video
I turned on my tv and it has solid black grey and colored lines on left half of screen.
It sound that the T'Con board has damaged. Your TV need a thorough check up. Contact any expereinced service technician.
Jul 13, 2012 | Insignia 42" LCD Flat-Panel HDTV
I have a hitachi 43FDX10B ultrascand HD rear
well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
Nov 29, 2009 | Hitachi 43FDX01B TV
Samsung Plasma TV has horizontal lines of colored dots
I have the same problem, currently searching for a solution. Have you resolved your problem yet? Looking to repair myself, any tips or ideas that you have/expirenced would be greatly appreciated. Thanks, Todd
Apr 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Mitsubishi VS-60705 Large Screen Projection
thanks for your detailed description of what happened.
replacing the vertical output i.c will correct the problem.
the reason it failed was bad connections on it.
Apr 22, 2008 | Mitsubishi VS-45605 50" Rear Projection...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
TV Problem
No. Are the lines white or black? Does the picture look distorted at the top? Is there a chance it is still under warranty? It sounds like a problem in the vertical retrace circuit. Probably a capacitor near an IC that's used for timing. You shouldn't be having this issue already. A tech should be able to see a distorted waveform in the vertical section. Hope this helps.
Nov 11, 2006 | Philips 32PT5441/37 32" TV
Televison & Video Logo
303 people viewed this question
Top Televison & Video Experts
Ekse
