Question about Motorola Mobility RAZR V3
External ring type/volume buttons
Is there a way to stop these buttons from changing my ring tone/volume? I keep the phone in my pants pocket and it is constantly beeping and changing the ring tone, usually to silent.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 66 Answers
There is a way to totally turn it off :/
you'd need a T6 ***** driver, and some cutting skills :D
msg me if u want to permanently disable them
Posted on Mar 12, 2008
  • silveraxe
    silveraxe Mar 13, 2008
    make that a Torque T6 :D
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
Panasonic kx-tg2303 how do I change the ring tone?
With the phone off press the volume up and down button to ensure which ring tome you have. the up and down keys will change the volume. Now, press each of the keys 1 through 9 to select the ring tone you would like. Please let each ring tone finish before selecting a different one else the one you select next will not ring to let you know what it is.
cheers
Jun 08, 2010 | Panasonic KX-TG2303B/WH Digital Cordless...
How to change ring tone? Lost manual.
usually this is done one of two ways
if the phone has a menu button
press it once then use the arrow keys until you see "ring" or "ring tone" in the display
then use the arrow keys again and you should hear different ring tones. when you find the one you like press the menu button to lock it in
if the phone has a program button and no menu button
keep pressing the program button until you see "ring tone" in the display.then use the arrow keys until you hear the ring tone you like. then press the program button several times until you exit the programming mode.
you can follow the above steps to set the ringer volume also
Jul 16, 2009 | Uniden Cordless Phone
Just got this used phone for school.how to change the ringtone It's a very annoying one now.
Jul 15, 2009 | Uniden Cordless Phone
Volume on the phone/speaker/ring is very low
You can change ring tones by pressing the flash button until you get the ring you want. When you get the ring you want press the set button.
May 24, 2009 | Innovage Speaker/Caller ID* LCD Touch...
NEC Dterm80 ring tone
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
May 20, 2009 | NEC Dterm DTP 16D-1 Corded Phone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
I like to increase the ring volume of my samsung x820
press the button on the top left hand side of the set and you can change all tones.
Dec 02, 2008 | Samsung X820 Cellular Phone
LG Prada Loud Speaker & Exculating Ring Tone
press the lock key on the side during a call to activate the speaker phone option and then press the required touch button on the screen.
Piyush
Jun 10, 2008 | LG Prada KE850 Cellular Phone
Help
Remote ring detection provides a low tone * triple beep in your wireless headset when you receive an incoming call. This feature requires a handset lifter accessory, such as the Plantronics HL1 or HL10. If you do have a handset lifter but do not hear the remote ring detection, please check the following:
  • Check the placement of the lifter. - Make sure the handset lifter positioned directly over the phone's speaker.
  • Try adjusting the phone's ringer volume. If the phone's ringer is too quiet, it may not trigger the ring detection built into the lifter. Try turning up the ringer volume of your phone.
  • Check the ring tone of the phone. - If your phone's ring tone provides short beeps or plays music, the lifter's microphone may not detect it. Try switching your ring tone to a traditional ring or long beep.
  • Does the phone have different rings? - For example internal calls vs external calls vs transferred calls. Does the phone ring the same for each type of these calls. If so try changing so all calls use the same tone.
  • Attach the optional "external ring detector" cable. This cable plugs into the lifter and provides a small, black microphone. It is included in the plastic bag of lifter accessories. Mount the microphone near your telephone's speaker. Click here for more details.
  • There are 2 versions of the Lifter accessory - HL10 and HL1. The HL1 is a larger older version of the liter with a more sensitive rind detector. Some phones will require the older version of the lifter.
  • Please view the On Line Compatibility Guide to see if the older version (HL1) will be required for your phone.
*Please note the volume of notification beep in the headset cannot be altered, it will always be a low tone triple beep .
Jan 15, 2008 | Plantronics CS50 Wireless Office Headset...
Motorola Mobility RAZR V3 Logo
141 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
