The middle button on my ipod gen 2 is jammed. How do i fix it?
    Problem Solver:
  • 5 Answers
I suggest either try getting inside and find out what is blocking it or push it back out or you can just take it to an ipod retailer and see if they can fix it
Posted on Mar 11, 2008
SOURCE:
How to fix power button
I could spend a lot of time describing how you heat round the screen, pry it off, move battery, remove 2 screws holding button assembly, relocate or shim button and reassemble it, but it's easier to point you at someone else's good work and some videos (thanks to those people)
Fix Power Button iPod Nano 6th Generation
Nottingham Solving power button problem in iPod Nano 6th gen The Computer Room...
iPod nano 6th gen power button problem The Computer Room How to
Jun 27, 2014 | Apple Ipod Nano 6th Generation Silver 8 Gb...
Unable to transfer photos. ipod 5th gen. connected to 'puter w/itunes open. click on ipod/click on photo tab/ all options greyed-out
is it recognized in itunes? sometimes you have to reset your ipod by holding down the middle button and the menu button. or in some ipods its middle button and play pause button
May 06, 2011 | Apple iPod nano 5th Generation
Ipod touch 16gb(1st) home button not working. How to fix
On the iPod touch 1st Gen device, the home button is prone to failure due to the design, most can be fixed for a nominal fee, fixed mine, it was one of the hardest iPods to repair for its time, but with practice, is usually never an issue. Once it is open, then the removal of the battery and then the logic board removal requires experience. As far as the button is concerned, Usually, the "pop" disappears and it feels stuck in the down position, simple fix by introducing an iPod Touch 4th Gen device design upgrade (as far as button is concerned.)
This particular model, the iPod Touch 1st Gen, does not have a replaceable home button module design. It is part of the logic board and so it has to be repaired and not replaced. The small outer disc can be removed and recovered, clean or replaced with another comparable size disc, if the issue is with moisture exposure, corrosion. The sign for moisture exposure issues is that it still "pops" but no longer functions.
I have repaired these successfully and with no issues. www.zfixit.com 78c71099-06cd-4a93-9b81-39199bce2261.jpg
Aug 08, 2010 | Apple iPod touch
My ipod 3rd gen froze. Any fix?
reset hold up + middle for 8 seconds after flipping hold on then off. might work hope it helps
Mar 08, 2010 | Apple iPod nano
How do you fix the cracked glass of ipod touch? how much wouild it cost?
See http://www.ifixit.com/iPod-Parts/iPod-Touch-Gen-2-Front-Panel/IF140-001 for pricing and instructions on how to replace the glass. (The link is for 2nd gen iPod Touch, but they have 1st gen parts as well)
-=/ MLF /=-
Oct 21, 2009 | Apple iPod touch
Ipod Nano 2nd Gen. just clicks. Won't turn on
  1. Step 1 Set your ipod horizontally on a flat surface with the LCD screen up. This position is best because it allows you to apply even pressure to the different buttons.
  2. Step 2 Toggle the hold switch a few times, and then make sure it is set to the unlocked position. This will ensure that the buttons on the iPod are not malfunctioning due to an active hold button.
  3. Step 3 Press the "menu" and the middle "select" button at the same time. It is very important that these buttons be pressed in unison, or the iPod will not reset.
  4. Step 4 Hold for 10 seconds. Keep the buttons pressed. You will see a black screen with an Apple logo, with a status bar at the bottom. If the reset is successful, your ipod screen will return to normal after a minute or so.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 06, 2009 | Apple iPod classic MP3 Player
Blank display on apple ipod
It sounds like your Ipod is frozen.
You can reset it by holding the middle button and the button above it for 15 seconds. It should power down and then you can turn it back on.
Jul 23, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Ipod problems
try your hardest
Aug 05, 2008 | Apple iPod nano
Frozen iPod Nano
Press and hold the center button while holding down the menu button. This will reboot your Ipod. Check your IPod cable to see if its shorted. If might have transferred a song and crash in the middle of the transfer.
Jun 22, 2008 | Apple iPod nano
55 people viewed this question
Ekse
 Grubhead
Grubhead
