Question about George Foreman GR82
Rotisserie rod I bought the rotisserie from a closing sale and I thought it had all the parts but I got home and the rotisserie rod is missing. Where can I purchase one?
  • 1 more comment
  • sdcoach13 Jun 21, 2008
    purchase one? I have looked online, no help. I have tried their web-site, nobody home
    [email protected]
    Thanks for the manual
  • Anonymous Jan 25, 2009
    I also bought this at a sale and no rod to attach basket. Big George GR80s
  • stacyf69 May 05, 2009
    I need the rotisserie rod for the GR82R, mine is broken
Have the same problem. It is not the company in the manual. Call Fox International at 1-800-738-0245 (Customer Service). If yours is the Big, the part numer is going to be 20897 (according to my manual). The rod (bar) is around $10 + shipping to your area. Hope this helps.
Posted on Aug 12, 2008
SOURCE:
I just bought the Brinkman, and I am trying to figure out how to use the Rosterria. Can you help me?
Since a Rotisserie is an optional item for your model grill. I assume you have purchased one that is approved to be used on your model Brinkmann Grill Smoker. If not, I recommend that you Do Not use it. If it was approved, read and follow the directions that came with it regarding installation, setup and preparing to use the rotisserie.
The Rotisserie can only be used when you are not grilling anything else on the grill. Remove the grill grates directly in front of the rear infrared Rotisserie Burner. If you Don't, they will be in the way. In their place, you are going to use an aluminum pan (like a pie pan), as a drip pan for whatever you're cooking on the Rotisserie.Place that on top of the burner's flame tamers. Make sure the rotisserie motor is in place and you have electric power to it. Test the rotisserie spit, by inserting it into the motor's spit holder. If you have a Counter Balance, attach that near handle on the spit shaft just below the handle. If your rotisserie is missing the counter balance, you can not use the rotisserie.
Remove the rotisserie spit and place whatever you're planning to cook on it, following the directions that came with rotisserie kit. Make sure the spit forks are tightly embedded in the meat, whole chicken, etc. If a whole chicken, tie the legs together like a Thanksgiving Turkey around the spit..
Light the Rotisserie Burner and close the hood of the grill. Allow the temperature to reach a minimum of 250 degrees F, before opening the hood and installing the food loaded rotisserie spit.
Be careful, as the interior of the grill will be hot. Install the spit as you did earlier. Make sure it fits into both sides of the grill's hood correctly.
Turn the Rotisserie Motor ON and watch as the food turns. If it turns and then sort of bumps, when the spit turns around, adjust the counter balance to stop this. It should turn smoothly. Once all tha is completed, close the hood and allow the food to cook for whatever time, you would cook it in a kitchen oven. Rotisserie cooking is like smoking food. It's a low (temp) and slow (time) process. But, the flavor rewards are GREAT. Only check the food occasionally. The more you open the hood to peek, the longer it will take to cook. Each time you peek, add 10 minutes to the cooking time.
All of this, was sort of a thumbnail sketch of rotissering food. Search the web for recipes and techniques. You'll be amazed at what's out there.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 22, 2011 | Brinkmann 5 Burner with Smoker 8101750S
Bought the GE Rotisserie oven model 169220 used. It is missing a rotisserie spit. Where can I buy one?
Visit http:///www.gehousewares.com/Customer_Assistance.aspx,
you will be able to find there how to order parts.
Regards.
Jun 17, 2011 | Toaster Ovens
Which is the right rotisserie for the Brinkman 8534 Gas Grill? Where can I purchase it and how much does it cost?
You can find and purchase the rotisserie on Brinkmann's website. Click on the Accessories tab and then enter the correct model number for you grill.
http://www.brinkmann.net/home.aspx
May 14, 2011 | Grilling
Where can i get parts forit.I have lost my Rotisserie grilling skrewere that holds the chicken in the middle and helps to turn it round
You can find a universal Rotisserie Rod (spit) at just about any home center or hardware store that sells gas grills and accessories. Take your rotisserie motor with you, to make sure you get one that will snugly fit the coupling on the motor.
Good luck & Happy Grilling!!
Apr 24, 2011 | George Foreman GBQ100 Grill
How do i install the rotisserie on my grill..it is a pro series 8534...there are no pre-drilled holes and there is no way of closing the lid on the pit while it is cooking,,there is a slot cut out on the...
Buy the Brinkmann Universal Rotisserie Kit model #812-7102-S for $49.95. It uses 2 screws to attach a bracket to the existing tapped holes in the grill. It was that easy! I purchased my grill and the Rotisserie at Home Depot.
Oct 18, 2017 | Brinkmann Grilling
Childesign Shelby crib replacement parts
You know I just purchased a Childesigns crib from a garage sale thatI thought had everything needed. When I got home, we found it was missing one top plastic rod. Of course nothing will work without that. I found this webpage that sells a VERY similar product. http://www.productsamerica.com/page65.html. It is not exact, but to be able to use the crib, this was a good option for us. Hope this helps.
Sep 06, 2007 | Childesigns Shelby Crib
George Foreman GR82 Logo
954 people viewed this question
Top George Foreman Kitchen Appliances - Others Experts
Thomas F. Schneider
Mike
Gerry Harvey
Gerry Harvey
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
