Question about GE Profile TPX24PBDCC Side by Side Refrigerator
Water filter Where do I find the water filter for my 11 year old tpx24? Thanks [email protected]
  • blah3ark Jun 11, 2008
    i also have a tpx24. looked in the back on the right for a water filter (under the temperature controls) and there is nothing there that appears to be a water filter. but the book says that's where it should be and says replacing the filter will solve my problem (which is that the ice maker is making hollow ice cubes).
    any further suggestions?
    andy
    President:
  • GE Master
  • 2,651 Answers
Are you looking for a replacement filter for your refrig or looking to locate its whereabouts in refrig???? 11 years ago its possible, sorry very probable that a water filter did not come equipped with refrigs.if so it would be in top right corner mounted on ceiling insider refrig.
Posted on Mar 12, 2008
SOURCE:
Pilot light wont stay lit once button is released unit is about 11 years old
call your plumber and have it serviced possibly just needs the thermocouple replaced .
Dec 28, 2015 | Bosch & Tankless LP Hot Water Heater
Troubleshooting a GE TPX24 icemaker
a19e2387-1433-4c2d-bb46-e670a2bac700.jpgSimple if the ice maker is not filling with water after cycling then fill ice maker until full allow water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water replace the=> WR57X10051 Water Inlet Valve If the Ice Maker does nothing with ice still inside the ice cube slots then replace the=> WR30X10093 Ice Maker Assembly These ice makers are electronic and once they fail there is no replacable parts. I am here should you have questions, Thanks Sea Breeze
Jan 13, 2013 | GE WR30X10093 Refrigerator Icemaker Kit
WE HAVE 12 YEARS OLD MODEL TPX24 BP, WHEN WATER LINE IS OPEN AND WATER DISPENSER IN USE, THERE IS LEAKING OCURES FROM UNDER THE FREEGE PLEASE HELP
You have a bad "water inlet solenoid" that needs to be replaced. It is located on the rear, bottom left side of the unit. It is really simple to replace. Here is a link to the part you need. Below is a video to show you how to replace it.
Aug 11, 2011 | Refrigerators
Last week after I filled the bath tub with water, it was rust colored. This happened one time only, then it was fine. I neglected to change my whole-house water filter for about 8 months (well water). ...
It sounds as if the thermocouple has failed and allowed the tank to contract, releasing
the rust from inside. I would recommend replacing the entire unit before it breaks as most
units are only warranted for about 6 to 9 years. Hope this helps.
Feb 21, 2011 | Water Heaters
I have 10 years old Profile, side by side refrigerator, model TPX24. Today there was water on the floor, ice was melting, and the top part of refrigerator was wormer then the bottom. I defrosted it. water...
If you can hear the compressor come on, then I would suspect that it needs either freon or a "cold control switch". Usually it is not the switch. If the compressor tries to start but just makes a brief buzzing noise and then shuts off, then the compressor may be bad.
Jun 24, 2010 | Refrigerators
Tankless water heater (Paloma) Has C2 11 error
I had this problem with the C2 11 error code. My unit is 1.5 years old. I called Paloma and they emailed me an 11 page document to clean the burners. I am not an HVAC but I got the feeling that's who the instructions were for. Very difficult but you can do it if you're handy. You basically take apart 1/2 the unit, be carfull not to lose any screws and label all the little brackets that come off. It took me 2-3 hours to get to the burners. I used a can of air (for keyboards-electronics) to blow on the burners and clear any build up. After putting it back together (carefull to make sure the 3 gas tubes make a seal when re-installed) the unit works. I did this today so I'm not sure the unit will still work in a week/month. I am dreading having to do this every year to keep the unit running.
Sep 28, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Kenmore refrigerator Model No. 106.56839600 water dispenser
Hi
The water is kept cool in reservoir in the fridg. Remove the inlet tube push for water check pressure better worse? Work your way back to valve
good luck
Apr 12, 2017 | Kenmore 21.7 cu. ft. Side-by-Side...
Status light flashes red
i would check for bad caps
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 21, 2008 | Mitsubishi WD-52628 52" Projection HDTV
GE Profile TPX24PBDCC Side by Side Refrigerator Logo
325 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
