Question about Compaq Armada M700 Notebook
Pasward compaq harddrive pls guide it open and chang bard hard
  • Anonymous Mar 15, 2008
    i am reset the battry but samw condition of loaptop pl s guide me why open the pasward
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    hmmm? you are saying you need a password for your own hard drive?
  • 55 Answers
To reset the BIOS password you must take out the BIOS battery on the motherboard of the computer.
On most desktops this is not a hard thing. Simply take off the side of the case, then take out the quarter sized battery on the motherboard, wait 60 seconds then reinstall.
On a laptop the same thing must be done but I must recommend you take it to a local technition as this is not an easy thing to do if you have never opened up your laptop.
Posted on Mar 14, 2008
I want to change the harddisk, but I can not get the computer opened in order to so. Any suggestions?
In order to change the hard drive on this laptop you are going to have the remove the battery and the keyboard because the hard drive is directly under the keys. When you remove the battery you will see 3 screws, remove them. Open the screen and flip the laptop over to see, in the battery compartment, the keyboard release access. Insert a flexible tool and press inward to release the keyboard. Flip the laptop over and gently lift up the top part of the keyboard until it releases. You will see you have the hard drive there. Unscrew it, remove the bracket and replace the hard drive. Be careful not to loose any screws and never force a screw back into place.
Jul 06, 2011 | Compaq Mini 110c-1001NR Notebook
Unlocked cod for htc hd mini t5555 Cell Phone pls 10q vm :)
It's simple to get the Unlock code for the HTC HD Mini Model Phone,You can get the Unlock code from here
Theunlockarena and Unlock the Phone from the Network Lock..........After UNLOCK you can use any Network Sim card which support GSM Technology.
Jul 04, 2011 | Cell Phones
The screen was cracked, I had it replaced and now it is saying no hard disk its a compaq laptop
Go to BIOS and check whether the harddrive is detecte in BIOS.If it is not detected then the harddrive is either missing or there is a problem with the hard drive connection.Reconnecting the same may resolve the issue
Jan 04, 2011 | Compaq Presario CQ60-220US PC Laptop
Where is the bios battery located on a compaq evo 600c
This is HP Support, and the download page for the Compaq Evo N600C Maintenance and Service Guide. (Service Manual)
Scroll down to the heading - Service and Maintenance Information.
Left click on the file name underneath.
Compaq Evo Notebook N610C and Evo N600C Series Maintenance and Service Guide. (25 Jul 2007)
It may take a few seconds before you see the first page of this PDF file. Let it download all the way before looking through it.
Go to Page 104: Disk Cell RTC Battery.
1) Remove the AC adapter (Charger) if plugged in, remove the Battery.
2) Open the Mini PCI Compartment Cover.
[ Located on the bottom of the notebook. Notebook bottom side facing up, front facing forward towards you. The Mini PCI Compartment Cover is to the immediate right of the Battery Release Latch ]
3) The CR1220 disk shaped battery is right there in a holder. (A type of watch battery also) When reinstalling make sure the Positive ( + ) is up.
The Harddrive compartment is up towards the right corner. Located under the Intake Air Duct grille opening.
No where near the RTC {Real Time Clock} battery.
Apr 03, 2010 | Compaq EVO 600C Notebook
Where is the hard drive located ?
moz-screenshot.jpgplease copy and paste the link below to access the user manual.
search hard drive as key word for easy reading.
Apr 16, 2009 | HP Compaq Presario 2200 Notebook
Compaq presario v2000 wont reconize harddrive
check that the jumper on the hard drive is set the same as the old hard drive i.e master or slave.
Jan 03, 2009 | HP Compaq Presario V2000 Notebook
How to install hard disk and memory of my laptop?
there are 2 door on the back of your laptop (Aspire 5580).
1 is for harddrive, and the other one is for memory+wireless cards.
just open the screw + the cover and you can see the hdd and memory.
Sep 24, 2008 | Acer Aspire 5500 5570-2609 Laptop
This solution is not for the XBOX version of the game, this is only for the PC version of the game Bard's Tale.
You can still try to make the game compatible for installing it on the Windows XP 64 bit by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
The same set of Compatibility steps can be used for installation of older games installation on Windows XP 64 bit and Windows Vista.
Again, this solution is not for the XBOX version of the game.
Sep 06, 2008 | Vivendi Universal Bards Tale: Song of the...
Cannot Open when connected
I connect harddrive IBM Travelstar 20 GB Model IC25N020ATCS04-0 (made in Thailand) to PC via USB port but cannot open ,LED is light .How can I do , I have no driver.Pls. help me.
Jun 01, 2008 | IBM TravelStar 40GN 20 GB Hard Drive
Compaq 160 gig
as long as you have a compatible cable to connect your drive i suggest an external 2.5 caddy that works usb then any data you have will be accesable
Apr 09, 2008 | Computers & Internet
Compaq Armada M700 Notebook Logo
79 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
