Kp-53n77 color 53
I have a 53" Sony kp-53n77 RA-3A RM-Y906 color TV. After turning it on, there is no picture or sound. The red light comes on and stays on but does not blink.
I have tried different power sources, etc., but cannot elicit a different response from the TV. I have scoured the web for help but have not found anything that would point me to the problem.
Any help would be appreciated.
  • hagg10408576 Mar 11, 2008
    Thank you for the help.
    The manual says:
    "When you perform AUTO SETUP, all the settings in the Video and Audio menus are reset to the factory settings."
    I believe this is what you suggested that I try. However, the manual says to do this using these steps:
    "Press POWER to turn on the projection TV. Press SETUP inside the drop-down panel on the projection TV and the AUTO SETUP screen appears."
    Do I attempt these procedures even though I can't see the drop-down panel on the screen?
    Thanks.
  • hagg10408576 Mar 12, 2008
    Thank you for the responses. I will post back ASAP with test results.
  • 552 Answers
Try resetting to factory settings via tha manual at this link.
It will download onto your computer in PDF form.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KP53N77&LOC=3
Posted on Mar 11, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Mar 12, 2008
    Try unplugging the tv so you have no power going to it, plug back in and then try to pull up the menu again.
    If this does not work, to bring up the menu, then I would try it anyway.
    If that does not work , let me know and I will search for more answers.
    Regards,
    Yalmer
I have sound no picture
Check or replace the vertical IC 1501 on the D Borad.
Oct 08, 2012 | Sony KP-53XBR45 53" Rear Projection...
Tv will not turn on, red flashing light comes then turns off
tv will not turn on, red flashing light comes then turns off.
light flashes six times.
Aug 15, 2012 | Sony KP-53HS30 53" Rear Projection...
I have a sony kp-53n77 rear projection tv i cleaned the lenses but i still have alittle to much red how can i clean up the color
Older projection set:
Not knowing exactly what it looks like I suggest two things: first in the menu look for convergence to see if it is off adjustment wise--it can be adjusted in customer mode to see if that helps.
Also either turn color all the way off (Black and white) to see what color the screen is with no color--if somewhat red you will need to turn the red screen control down--I can tell you where and how.
If screen is too red, red will be the prominent background color with color off or on.
Another easy way to LOOK is go to an unused video input---should only see "Input 1" for example in green and rest of screen should be black and not red to any degree.
Let me know with a comment here what you find.
May 02, 2012 | Sony KP-53N77 TV
HI...WE HAVE A SONY PROJECTION TV, MODEL #KP 53 S 35, NO PICTURE NO SOUND, DARK SCREEN, JUST SMALL FLASHING RED LIGHT ON CONTROL PANEL (STANDBY LIGHT). NO POWER ON SOUND WHEN TURNED ON. TOLD WE NEED...
http://www.moduslinkptstvboards.com/search.php?search_query=A+1316+295+A&x=7&y=13
try this....may have to send board to them for repair.....good success, meder's tv service
Sep 22, 2011 | Sony KP-53S35 53" Rear Projection...
Where is the fuse located on a KP53S25 Sony TV?
hello there should be a glass fuse in the power supply also beware in a lot of sony sets there are soldered in fuses aswell. and circuit protectors i hope it helps
regards
shaun
Feb 05, 2010 | Sony KP-53S25 53" Rear Projection...
MY problem with Sony KP-53S35 53 in. Rear Projection Television. When the TV powers on, the red light blinks until the picture comes on, then the red light blinks go off. I had to wait more than 5 minutes...
the number of flashes of the red indicator lamp points to the possible cause of the delay of the raster or picture, but usually it's an indicator of an emission unbalance between crt(picture tube) guns. the picture will take longer to show up as the emission on either of the picture tubes goes down.
Jul 27, 2009 | Sony KP-53S35 53" Rear Projection...
The remote control stopped working.
Check the remote lens on the TV for some dust and if present remove it. You can even use some alcohol to remove the dust. You can even try pressing the small reset button on the bottom of the remote after removing the batteries. Use new batteries.
You can get some help on how to repair a remote control from:
http://www.fixya.com/manuals/w153225-repair_remote_control
If nothing helps then you need to get a new remote... you get one from: http://www.newtvremotes.com/Mfrs/Sony/SonyTV/RM-Y906.htm
Jul 20, 2009 | Sony KP-53N77 TV
53" sony projection -picture washed out w/ green horizontal lines
It sounds like your Green CRT ( picture tube ) is shorted. That's the one in the middle. Sony had issues with there tubes in those years. Sorry for the bad news. Even if you could locate the tube, it will be a matter of time before the Red or Blue does the same.
May 03, 2009 | Sony KP-53S65 53" Rear Projection...
Sony kp-46wt-500 tv help
if your set has auto focus try activating it if not you require a convergence alignment.
Apr 13, 2008 | Sony KP-53N77 TV
Sony KP-51HW40 No Picture, only sound
to thus problem its very simple .! try to resolder at the back of the picture tube board.
Nov 26, 2006 | Sony KP-53V75 53" Rear Projection...
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
