Pyramid - PS21KX  20 Amp Power Supply Car Audio Amplifier Logo
Posted on Mar 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pryamid ps36k power supply
Powers up but has low voltage
Anonymous
Level 3:
  • Master 631 Answers
  • Posted on Mar 13, 2008
Anonymous
Master
Level 3:
Answers
631
Questions
Helped
237489
Points
1200
Have you done any troubleshooting at this point?
Are you going to try to repair this yourself?
Have you tried to locate a schematic for the supply?
I obtained an OKI Pro 8432WT, but have error code 122 when start. What does this mean?
Error code 122 means " Low voltage FAN error ".
Is the FAN (bottom right of the front) of the low voltage power supply block working? Is the FAN connector connected correctly?
Check to make sure connection of the FAN connector. Replace the low voltage power supply unit. Replace the FAN motor. Replace the low voltage power supply unit.
Source: https://www.okoki.co.uk/how-to-fix-oki-printer-error-codes
3115cn power supply
"Low Voltage Power Supply" in a laser printer usually means the AC to DC power supply in from your wall outlet. The "High Voltage Power Supply" is often in the center of the printer and provides the high power required for imaging internally.
Where can I get a replacement cooling fan for a Pyramid PS36K power supply
Hi Dave,
I'm not at all familiar with the Pyramid Brand/Make, but the best I could suggest is to ask other amateurs/Cber's, and other radio enthusiasts in your local area, if the have any spare parts or non-working power supply units that you can have for a small fee or favour if needs be, and I'm sure that you can find, even if you need to trim the fan blades to suit, that this will be the easiest and cheapest way of doing the job.
I hope I have helped you with your query.
Best wishes,
Peter
1helpful
2answers
Power light is blinking and the tv won't power up.
In that case the problem of your television is the power supply.The power supply have low voltage output so that the board of your TV cannot drive,so that the TV wont turn on.The power supply have leak capacitor that may cause of abnormal voltage.The output voltage of the power supply is +5V, +12V, and +24V.So the power supply is the problem its need to repair.Thanks
Hi, i have cp2025 printer and it giving an error 58.04 could you please help thanks
Solution or Workaround:
NOTE: Replace the low voltage power supply before replacing the fuser or fuser power supply.
A firmware upgrade is available on www.hp.com that will solve this issue.
If the error will not clear after the firmware upgrade, replace the low voltage power supply.
If the error continues, replace the fuser power supply.
If the error still continues, replace the fuser.
Cause:
Low voltage power supply malfunction.
I hope this information helps
I have a printer HP CP2025, it gives me the follwoing Error 58.04. What I can do ?
Cause:
1helpful
To low output voltage 4.12 V pdp-121p
you power supply may be faulty or, or you motherboard, even try to update the bois
Replace low voltage pwer supply
To remove the low voltage power supply, Take off the side covers. the power supply is on the rear right hand side of the printer. Just remove the screw's and the cable's connected to it and your done. Don't confuse it with the Hi voltage power supply which is on the Left side of the printer as your facing it head on from the control panel.
2answers
PS36K power supply overload problem
Most of Pyramid's supplies are based on the LM723 voltage regulator. The DATASHEET should tell you most of what you'll need to know to repair it. THIS is the schematic diagram.
If the output voltage drives the voltmeter to the end of the scale, it likely has one or more shorted power transistors.
Top Pyramid Car Audio & Video Experts
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
xxxxxx xxx
Are you a Pyramid Car Audio and Video Expert? Answer questions, earn points and help others
