Question about Dryers
Hi - my dryer blows lint out through the vent and on to the lawn and makes a mess..Any suggestions would be AWESOME !!! (-: Thanks.... Jamie
    Novelist:
  • 131 Answers
Just clean the vent pipe and keep the lint screen clean. All dryers make lint.
Posted on Mar 11, 2008
SOURCE:
Thermal cut-off
when the thermal fuse or the high limit pops it's because the dryer is running to hot,all a dryer does is move air,when one of the fuses pops it's from a block from lint either in the lint filter duct or the vent line,if the air can't blow outside or out of the dryer the fuse will blow.if your vent line is long remove it from the back of dryer and stick a leaf blower into the vent line and blow all the lint outside,make sure there isn't a cage or anything blocking the outside hood,then pull out the lint filter,take the dryer apart,remove the lint filter duct and clean it out,also vac and blow out the cabinet and motor,you should do this once a year,your clothes will dry on time,less parts will get damaged from overheating ,your electric bill will be less and most important you won't have a dryer fire.hope this helps,the fuse will keep blowing until you clean out the dryer and vent line.
May 16, 2013 | Kenmore Elite Oasis 6808 Electric Dryer
Run for about half the cycle than stops. can restart and it will finish cycle.
Hi and welcome to FixYa. I am Kelly.
When a dryer runs for around 30 minutes and shuts off it has reached the maximum operational temperature allowed and is most likely being shut off by the high limit thermostat. This is a safety feature built in to keep from causing a fire due to over heating.
This overheating condition is usually caused by lint buildup in the following areas.
1. The outside dryer vent exit is blocked with lint
2. Flexible vent ducting has lint build-up inside
3. The lint filter in the dryer is restricting airflow
4. The lint filter trap area has a build up of lint restricting airflow across the lint filter.
5. The blower fan / blades / ducting have a lint build up causing low air flow.
Do a tedious insepction for lint buildup and all of the ducting areas that you have access to without disassembly.
Make sure to clean as much of the lint out of the areas that you can see. In the process of cleaning DO NOT use sharp objects to try and free the lint.
If you have to... sacrifice a coat hanger and bend it in half so that it is U shaped to assist you in clearing the lint in stubborn areas.
If you really want to quickly rule out the outside ducting... you can disconnet the Vent hose / duct from the rear of the dryer and then dry a load of clothes. If it does not shut off you know that your external ducting is where the problem lies. Just make sure to reconnect the vent / hose ducting after the test. (Over time can make a large lint mess)
One other thing to check is the dryer door catch to make sure it is not getting weak when the dryer is hot allowing the door open switch to kick off the dryer.
Thanks for using FixYa!
Kelly
Mar 02, 2010 | GE DBXR463EBWW Electric Dryer
Dryer heats, drum turns, hot air circulates, but clothes don't dry
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Dec 29, 2009 | Roper REX4634KQ Electric Dryer
Why doesn't my LG Dryer not dry clothes well?
Nov 26, 2009 | LG DLE2514 Electric Dryer
It takes exceptionally long to get clothes dry. I
Oct 14, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
My dryer has gotten extremely louder and takes longer to dry.
Sep 27, 2009 | Dryers
Gas dryer does not seem to heat up takes a long time to dry clothes.
Sep 12, 2009 | Dryers
Kenmore Mod#417.94052500 doesn't dry clothes completly.
Sep 11, 2009 | Dryers
Whirlpool AWZ 7303 tumbling but not drying.
Whirpool Dryer......
GAS or Elect. does not make a diffrence 95% of drying too long problems are from a clogged vent try to run a normal load with the vent off the the back letting the hot air into the house if it drys normal then you need to clean out the venting going to the outside If you are worried about the lint blowing inside you can put an old pantiehose over the vent to catch the lint dust
Jan 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
