Question about Canon PIXMA MP160 All-In-One InkJet Printer
Printing Q Hi i can't print because i have a que but it ot letting me delete them. What should i do? Thanks
    Genius:
  • 3,587 Answers
Turn off printer..re start your computer...turn on printer, and you should see it reset
check your computers warranty here 4 FREE
Posted on Mar 11, 2008
SOURCE:
How can I clear the print que? I tried to cancel printing a document, and now the que says cancelling, but won't let anything else print
1) Try to restart you system with the printer unplugged.
2) Try to Pause the printer and then delete the items in the que
3) If this doesn't help Delete the printer and re-install it.
Aug 29, 2014 | HP Photosmart C6180 All-In-One InkJet...
Documents in printer que, but does not print
If a print job get hung up in the print que it may stop and not be able to be deleted, this will also block other print jobs from printing. Here is a link to an article that shows how to clear the print que and purge the stuck print jobs so printing can resume. I hope it helps.
http://www.ccl-la.com/blog/index.php/how-to-delete-print-jobs-that-are-stuck-in-your-print-queue/
Dec 10, 2012 | Sharp Mx-2310u Color Copy/print/scan
Print que on hp 4300 says "printing" but nothing happens and I cannot clear que
This is a common problem with Windows machines. If a print job gets corrupted in the print que it will stop and block all other jobs from printing. It will also block the job from being deleted normally. You have to stop the print que service and then delete the print jobs from the que. Here is a link to a full article that shows how to stop the que, delete the print jobs and restart the que to restore printing.
Nov 29, 2012 | HP LaserJet 4300 Printer
There has been a pending document in the que. I tried to delete the document but now it states deleting next to the document in the que. Can not print anything.
Open the Print Que and see if it will let you pause the print job. Then close the que and turn the printer off. Open the print que again and see if it will let you delete it. For some reason every now and again a que will hang. This process should reset the que. It will dump everything in printer memory and should release the document to delete the job. In any event pausing the job should release the printer to print other jobs.
Sep 05, 2010 | Office Equipment & Supplies
Job in printer que will not print or delete
go to safe mode and then delete the queue in printer
May 18, 2010 | HP Deskjet 6940 InkJet Printer
Today i was trying to print a document, but then when it came out of my printer, its not how i wanted it to be printed. So i pressed cancel on the printer itself. When i tried printing the document again,...
You must clear the que.
You should be able to download the print driver. Id try clearing the que first. do the three finger wave if necessary to find the process - terminate it - then reopen the que - see if the document is gone.
Unplug your printer - ower and signal ... go get a soda . when you get back plug the stuff back in ... remember - shut the stuff off first!
I hope this helps
a
Sep 23, 2009 | Office Equipment & Supplies
HP5510 Printer not working
WHAT IS THE OPERATING SYSTEM THT YOU ARE USING
IF THAT IS xp OR vista
GO TO THE PRINTER SPAGE AND RIGHT CLICK ON THE PRINTER AND SELECT RUN AS ADMINISTRATOR
SELECT CANCELL ALL DOCUMENTS AND SEE IF IT CLEARS THE PRINT QUE
STILL IF IT DOES NOT DELETE THE PENDING DOCUMENTS
GO TO SERVICES.MSC WHICH YOU CAN TYPE IN THE START SEARCH OR THE RUN BOX
LOOK FOR THE SERVICE NAMED AS "PRINT SPOOLER "AND MAKE SURE THAT THE SERVICE IS STARTED IF THE SERVICE IS ALREADY STARTED RESTART TEH SERVICE TWICE OIR THRICE
AND THE DOCUMENT WILL GET CANCELLED
BEFORE GOING AHEAD AND PRINTING TRY PRINTING A TEST PAGE FROM THE PRINTER P[ROPERTIES PAGE AND THEN TRY PRINTING OTHER DOCUENTS IT SHOULD PORINT OR ELSE GET BACK TO US AND WE WOULD BE MORE THAN HAPPY TO HELP YOU
THANKS AND REGARDS
HOPE THIS SHOULD WORK
BEST OF LUCK
Hamid
Apr 03, 2009 | HP Office Equipment & Supplies
Computer can't send item to be printed to printer
the delete the pending prints from the print que option aND then uninstall it will get uninstalled easily. thanks.
Jan 05, 2009 | Lexmark X5470 All-In-One InkJet Printer
I was in the process of printing some pictures when it stopped and only printed half of a picture. I checked the stauess of the printer and it said there was an error. I tried to cancel/delete the printing...
If the job is hung in the print que, and it will not delete, turn the printer off, then shut down the system. Turn the printer back on, and re-start the computer. This should clear the data spool that you were not able to delete.
Nov 20, 2008 | HP Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
Clive
Clive
old marine
old marine
Ekse
