Question about NetGear WGR614 Wireless Router
Ntegear wgr614v5 I'm trying to istall netgear wireless router wgr614 v5 on my xp computer Home edition version 2002 service pack 2 but after setting up wires i can not get acces to the internet thru the router. when i click connect to the internet it doesnt work. I'm unable to get into the smart wizard to configure the wireless router because is no internet connection
  • bennson1 Apr 06, 2008
    when i connect all leads and cables then turn pc on i cant get internet to work and pc freezes ,i am working on millenium not xp
  • Anonymous Sep 13, 2008
    when i conected my router its not working but my modem working well
    Scholar:
  • 47 Answers
Step One: Reset the Netgear Router.
How To :
Behind the router there is a steel mesh, near the antenna mesh there is a small button insde the mesh by use of a pen you can press that button please disconnect all cables before you commence the procedure and only the power cord to be plugged in. Press the button for 10 Seconcds and then release the button.
Do not connect the internet dsl cable till the congigration is complete.
Step two : Disconnect the power cable for 3-4 seconds and plug it back in.
Step three : plugin the router with your computer/laptop with the help of the cable. use port 1.
Step Four : open the web broweser and type http://www.routerlogin.net/ or http://192.168.1.1/.
Step Five: it would ask you for username and password. enter Username : admin and Password : password .
Step Six : Confiuring the router.
1) please avoid setup wizard and confure it manually and follow the steps below.
2) you would need to click on left frame buttons for the cnigration to come on the right side.
3) in setup section on the right side please click on basic settings and configure as below:
a) Does Your Internet Connection Require A Login?
Answer : No
b) for the next three options its the first choice should be like that from default, if not please set all to automatic.
Then,
Click "Apply"
4) On the right menu now click on wireless settings in the setup section.
a) give a SSID name that is a name you want to see when connecting to the the wireless router while connecting from a wireless device. E.g. ( "mp's netowrk",etc.)
b) set security option as WPA-PSK the third option.
give a password like "abcde12345" should be 10 charactes and alpha-numerical. ( This option is to make your Wi-Fi more secure and to avoid unauthorized access. Key lifetime : 60minutes
then click Click "Apply"
5) Now on the right menu goto advanced tab and click on LAN IP Setup.
a) In LAN Tcp/ip setup change the ip address to : 192.178.1.1 (to avoid dsl ip conflict)
b) there should be a check on use router as DHCP Server.
Starting IP Address 192.178.1.2
Ending IP Address 192.178.1.7
(the ip range should not be more that five ip address as otherwise the performance output would be pathetic)
Then Click "Apply".
Router Config Done..Now on the right side click in "Logout" (bottom most option)
after the router logout is done close the web browser and remove the network cable and the the power cable from the router.
Post Configring Steps :
a) Swich off the dsl modem.
b) plug the dsl cable to the internet jack in the router.
c) plug in the router power cable back to switch on the router.
d) Switch on the DSL Modem.
Wait for 15 Seconds.
Connect to you wireless netowrk using you laptop or wireless card in your computer and provide the WPA-PSK - TKIP passord which you had given in router for preventing unauhorized access.
Bingo !! you are connected...and more secure.
Posted on Mar 16, 2008
If your computer is online when it is connected to the modem using an ethernet cable, you can disconnected the pc from the modem. Use an ethernet cable to connect your modem to the ethernet port of your NETGEAR ROUTER. Turn on power of the net gear router. Connect your pc to the NETGEAR. Right click the network connection icon(at the buttom right of your screen) then click STATUS then click details. You should get an ip of 192.168.x.x. Open your browser, type on the address field http://www.routerlogin.net
USERNAME:admin
Password:password
when you are in the router page, click on set up wizard. it should configure the router and give you internet connection after the wizard completes
Posted on Mar 12, 2008
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
I have tried every possible way to rest my netgear wgr614v5 router and the log in page will not come up. Is there any other way I can get my router to send out signals so it can be picked up bu other...
The best way to do it, though you may have tried it already, is to use a pen/pencil and push the reset button in for 5-10 seconds.
This will usually reset it to the factory default settings and reset any password protection on its wireless.
If not, it's a problem with the other computers detecting the signal, be it not in range or something else.
Mar 13, 2011 | NetGear WGR614 Wireless Router
We transferred to a new home and a new dsl account. I've reset my netgear wgr614v5 to its default settings and reconfigured it to access but now it only works for pc's that are wired into the ports....
When you reset the router the default setting for encryption is probably off. Hopefully you had encryption on in the old home - but now the wireless computers are still trying to connect using the key/encryption.
Feb 05, 2010 | NetGear WGR614 Wireless Router
Is Netgear Route WGR614V5 compatible with Windows 7?
Please note that this router is compatible with Windows 7. Please perform the below steps on your Windows 7 computer to connect to the wireless network:
1. Click START, Click Control Panel.
2. In the main screen, open up NETWORK AND INTERNET.
3. Click on Connect to a network.
4. Select your network and connect to it. If you have a Password setup on the router enter the security key.
5. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jan 04, 2010 | NetGear WGR614 Wireless Router
I have a netgear, 54 mbps wireless router WGR614 v5 and can not locate my installation disk. Can anyone tell me where I vcan get the instructions to install it?
This is Netgear Support and the page for the Netgear WGR614 version 5,
http://kb.netgear.com/app/products/model/a_id/2587
1.Software you need:
Click on the Downloads tab.
Now click on the - WGR614v5 Firmware Version 1.09, in blue.
(I would bookmark this page. After you have installed the software, you need to come back, and download the Installation Guide. While installing the software, it is best to have your internet connection closed, and all windows closed. You will then be on your desktop screen.
If you do not have your downloads set to save to your My Documents folder, {Documents for Vista}, this download will go to your desktop screen.
When you see it, double-click right on the file name. The Installation Wizard will come up. Just click on Next, Next again, and Finish. Do not be concerned when it shows you where the file is going. It will be put in the correct place. Don't change it)
2.Documentation: (Instructions for installing)
Click on the Documentation tab.
The Installation Guide is listed at the top of the list
Sep 30, 2009 | NetGear WGR614 Wireless Router
Can't access configuration for Wgr614 v5 Netgear Wireless router
Since you cannot ping the router, first thing to do here is to reset the router by pressing the reset button of the router for 30 seconds while power is On and then after the reset power off the router for 5 seconds and then when the router is already power On try to ping the IP of the router using a computer that is wired to it if still cannot be ping better contact Netgear support if the router is still underw arranty and have it replace...
Dec 22, 2008 | NetGear WGR614 Wireless Router
Problem in reconfiguring WGR614 v5 after reset
You should configure the 2wire to a bridged modem for the autentication to work on Netgear.check with your ISP for configuring your 2wire to bridged modem
Cheers !!
Feb 24, 2008 | NetGear WGR614 Wireless Router
How to install with out the cd?
Are you using XP? You shouldn't need the CD.
http://www.netgear.com/Home/Products/Adapters/GWirelessAdapters/WG111.aspx
Gives you information about the USB adapter.
http://www.netgear.com/Products/RoutersandGateways/GWirelessRouters/WGR614.aspx
That gives you information about your wireless router.
Do you need a manual to set this up? It looks like there are different version of this wireless router. Which one do you have? This can be identified on the package or the unit's bottom label.
Once we know which version you have we can continue.
Dec 11, 2007 | NetGear WGR614 Wireless Router
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Logo
308 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
