Drain hose leaks. can i buy a replacement house at home depot and is there any tricky issue on replacing it?
You can use generic hose.
Turn the breaker off.
Remove your unit. It may have screws holding it to the underside of the counter. You may also need to lower the front legs by turning the feet with a wrench.
Look under the machine and disconnect the drain hose. Take care as there will be water in the system.
Look under the sink and disconnect the other end of the drain.
Take to Home Depot and get a section of the same length and diameter.
Installation is the reverse of removal.
Hope this helps you. Please rate this answer if so.
Testimonial: "thanks"
