Question about Toshiba Satellite 1135-S125 Notebook
DEAD T.V.SET TOSHIBA CF2662B
I DONT HAVE A SCHEMATIC FOR THIS SET.THE VOTAGE BEING APPLIED TO THE HORIZONTAL AMPLIFER IS 130 VOLTS. I CHANGED THE FLYBACK TRANSFORMER,WHICH DIDNT IMPROVE MATTERS.THE MOMENT I TURN HE SET ON I BLOW THE HORZ ,AMP.I BELIEVE THE VOLTAGE FROM THE POWER SUPPLY IS TO HIGH.IF ANY ONE HAS A SERVICE MANUAL FOR THIS SET I WOULD LIKE TO PURCHASE IT.OR IF YOU HAD THIS PROBLEM WHAT WAS THE PROBLEM?
    Scholar:
  • 163 Answers
H.O.T. Collector should be 120V and Run on a Variac to lower B+.(Could be Cap or Resistor also)... Sounds like the HVSD is kicking in.. Sams is great for Schematics...(Google for freebies)..
(Not familiar With this model but a good starting point)_._._
Good Luck!
Posted on Mar 11, 2008
Toshiba cf2662b the picture is "squished" Hoe do I adjust the vertical size and linearity? Thanks.
Most likely your tube is burning out. If there are any adjustments at all to fix this it will be in the menu under picture setting.
Mar 02, 2014 | Televison & Video
I have a dead tv make konka model kp2905qyt
Check the frequency of oscillation at the base of horizontal output transistor. It should be around 15.6KHz. If there is no frequency, the horizontal osciallator jungle IC should be suspected.
Nov 29, 2012 | Televison & Video
DEAD JUST STANBY LIGHT FLASHING AND HIGH VOLTAGE COMING AND COMING OUT A 1 SEC AFTER.
If the high voltage comes up and goes right down something in that area is either shorted , open or bad---only thing in power supply that could cause this is if the main voltage (130 volts plus to the high voltage area is HIGH---the high voltage will go excessive and shut the set down--xray protection.
Oct 25, 2012 | Toshiba 27A60 27" TV
No sound on toshiba tv model cf2662b
Check its speaker. If it is OK, check the audio output circuit for any damaged component. Audio out put IC should be checked.
Jul 14, 2012 | Toshiba Televison & Video
HORIZONTAL OUTPUT TRNSISTOR SHORTS WHEN POWER ON TV
ALL the next is with the tv unplugged (NO NO power)
  • resold the jungle (video processor) all around
  • following the horizontal drive pulse path and arriving to the horizontal area just after the horizontal transformer and in the base of the horizontal DRIVER there is a electrolytic capacitor (if this chassis uses this one,) Change it (maybe is dry)
  • solder all components i just told you in the last step. horizontal driver, transformer, etc
  • remember:
  • if a transistor is blowing with no reason (there is a reason: the collector receives 130 volts but cannot hold it forever, It has to be in some place. if the switching pulse doesn't arrive to it the transistor throws this 130 volts and burning itself. i hope it is help full.
Apr 15, 2009 | Televison & Video
Dead tv
check first if there's a B+ of your tv which is 95volts , if its ok check the horizontal transistor .
Sep 29, 2008 | Philips Televison & Video
SET JUST CLICKS WHEN POWER BUTTON IS PUSHED
I would check the low votage regulators, horizontal output and the flyback. The relay is the first stage of the start up process so the standby voltages are suspect as are the oscilation / Hv circuits. how are your trouble shooting skills?
May 23, 2008 | GE 46GW947 46" Rear Projection Television
Schematic / service information for Black and Decker VP 130 battery charger
Power supply for the VP130 is a 4.32v 210ma AC transformer.
The AC supply is fed to the charger battery box where there are two diodes one for each battery.
each battery is 3.6 volts.
Jan 17, 2008 | Dewalt DW056 18 Volt Cordless Impact...
Toshiba 57H81
Check all fuses in the power supply and look for any bad connrctions on the PCB. You are probably missing the 130 volt supply to the horizontal circuit. Common reasons are: Shorted horiz output transistor; flyback transformer, picture tube arcing , bad power regulator IC. In short, you need to get a qualified tech for this symptom. Hope this helps.
Oct 29, 2007 | Toshiba 57H81 57" Rear Projection...
Horizontal sync
zeutaluras, My guess would be the same as yours because the horizontal osc. is synchronized when you apply the signal to the HD inputs. I am assuming the signal with embedded horizontal sync and composite video passes through the tuner boards as you mentioned. I'll confirm with the schematic once I see it. If it is a separate board can you get one to substitute? I think you may be able to locate the problem with an oscilloscope and schematic if you can access different points in the schematic. I'll try to help once I know more. My problem prevents any type of built in diagnostics since the set doesn't power up.
Oct 03, 2006 | Toshiba 57H81 57" Rear Projection...
Toshiba Satellite 1135-S125 Notebook Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
