Question about Hotpoint RGB745 Gas Kitchen Range
Temperature is Unstable
I've replaced the sensor and that did not solve problem. The oven heats up to temperature and then either gets way too hot or way too cold! I have to constantly monitor the thermometer in the oven.
  • Gail Wilkins Mar 31, 2008
    Replace the bake ignitor and now it works perfectly! Thank you so much, aborcass.
    President:
  • Hotpoint Master
  • 2,651 Answers
Erratic temp in oven can also be a bad oven ignitor, usually to low of a temp and not able to stay at temp, too long to preheat.replace the bake ignitor
Posted on Mar 16, 2008
My Maytag MGR5750ADW oven will take forever to preheat. It does get hot, but the preheat light takes a very long time to go out. Food takes much longer to cook as the oven does not seem to get up to temp.
Hello there and welcome to fixya
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Aug 10, 2011 | Maytag Ovens
The oven wont get hot, it will warm up and the broiler seems to get hot??
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. To determine if the heating element is burned out, you will have to test the element for resistance across the 2 ends , with the meter set on the 200 scale if you get a good reading like 000 it would indicate that the part may be ok but if yoiu get a reading of a 01 or a 1 or lomething like this it would indicate tha part is bad then you need to replace it
However you will also want to
First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem. It won't broil
Apr 11, 2011 | Frigidaire GLEB27S7A Electric Single Oven
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
What does blinking beeping F2 mean?
Hello there"
The F 2 error that you are getting is telling you that the temperature sensor is going bad and needs to be replaced the temperature sensor is what senses the ovens temperature say you have it set for 350 when it is at 350 the sensor tells the oven to stop heating up and when it gets to a certain temp below that value it will make the oven heat up again
it looks like this
May 21, 2010 | Magic Chef 9815 Electric Single Oven
Built in oven won't get hot
hello there
Usually, when an oven won't heat up or bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it. Now if the oven It bakes poorly Here are two instances of when food "bakes poorly:" When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem
Hope thisis very helpful for you
Best regards Michael .
Mar 08, 2010 | Ovens
The Oven is set to 450 does not get above 280
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • Aug 14, 2009 | GE Profile JT912 Electric Single Oven
    Oven 150 degrees off
    hi . i can help.
  • Jun 23, 2009 | Ovens
    Oven not heating properly
    Hello. You have done an excellent job of explaining your problem. Read over the info. below as it sounds like your top element is not working.
  • May 26, 2009 | Kitchen Ranges
    F2 f3 starts beeping when using stove or oven
    F2
    Oven temperature too hot
    Check and replace oven temperature sensor (RTD).
    F3
    Open oven temperature sensor (RTD)
    Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
    So i suppose its a sensor replacement is necessary.These are the fault code explanations by frigidaire.good luck with the machine.Please do post results and comments.
    Apr 15, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven will not heat up completely
    Hi!
    Try the following---
    1.) When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    2.) When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    Thanks
    Rylee
    Jan 31, 2009 | Maytag MER5870 Electric Kitchen Range
    Hotpoint RGB745 Gas Kitchen Range Logo
    448 people viewed this question
    Top Hotpoint Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Sal DeAngelo
    Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
